IEC60825 - Laser Safety - Calculating Maximum Permissible Exposure Correctly
jradford
Are there any laser safety experts here? I am having touble convincining our distributor in China that we have calculated MPE correctly.
Table 7 says for our wavelength the light is collected in a 3.5mm aperature.
The Chinese SFDA says we have to use our spot size of 0.89um for a worse case exposure.
I keep pointing to the standard, and they disagree with it I guess. This is a difference of being class 1M and class 3A.
Any experts here who can help me?
Hershal
Metrologist-Auditor
Re: IEC60825 - Laser Safety - Calculating MPE Correctly
If you needed calibration, all over it. But laser safety is outside my technical competence. I am sure someone here can help though.
S Copy of LED Standard IEC60825 Other ISO and International Standards and European Regulations 1
Judy Abbott The impact of laser power on biocompatibility of the products Manufacturing and Related Processes 6
V Laser Welding Process - Impact on Electrical Properties Reliability Analysis - Predictions, Testing and Standards 4
M Lean: Conducting Capacity Study, calculating Cycle times on laser cutting machines Lean in Manufacturing and Service Industries 2
Z Is IQ necessary for laser marking validation? EU Medical Device Regulations 3
Beliz Biocompatibility Testing for Laser Epilation Device EU Medical Device Regulations 2
M Cleaning Process after laser marking on orthopaedic implants Other Medical Device and Orthopedic Related Topics 3
M Informational US FDA Laser guidances Medical Device and FDA Regulations and Standards News 2
V Class IV Laser Regulations IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E Requirements for hand-held laser welding equipment Other ISO and International Standards and European Regulations 0
J Installation Qualification (IQ) and Operational Qualification (OQ) for Laser Marking 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Medical Device Classification - Laser Guided Positioner EU Medical Device Regulations 2
Pmarszal Precise Laser Printer: Recommendation Manufacturing and Related Processes 2
M Laser Micrometer Suggestion (if any) for diameters that are +/-.0001 inch General Measurement Device and Calibration Topics 1
G Traceability of laser based x-y measuring machine General Measurement Device and Calibration Topics 5
T A question on Calibration on In-line Laser Micrometer General Measurement Device and Calibration Topics 1
M Laser Etching Advice for Permanent Device Marking Manufacturing and Related Processes 5
A How to Calibrate Laser Beam Tester & Radiation Monitor General Measurement Device and Calibration Topics 3
G Metrology Laser Reliability General Measurement Device and Calibration Topics 2
B IEC 60825-1 Class 3R Laser Off-The-Shelf or Custom Label Needed Other ISO and International Standards and European Regulations 3
A Is IEC 80601-2-60 necessary for Dental Laser? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Innovation in Laser Welding Manufacturing and Related Processes 2
J Kanomax hand held Laser Particle Counter Calibration Calibration Frequency (Interval) 6
A Standards for Emergency Button for a Dental Laser IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
G Laser Wavelength Traceability for Laser Interferometers General Measurement Device and Calibration Topics 4
G Laser Precision Linear Measurement - Inherrent Accuracy of 10 -6 - Nice PDF Paper General Measurement Device and Calibration Topics 1
A Dental Laser Certification IEC 62304 for a Firmware IEC 62304 - Medical Device Software Life Cycle Processes 1
A Type of Materials to comply with IEC 60601 (Dental Laser Case) IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P White Light vs. Laser Scanner - Investing in a 3d Scanner Quality Tools, Improvement and Analysis 6
S FDA releases Updated Laser Products Regulation Other US Medical Device Regulations 1
P Laboratory Scope for a Laser Fabrication Shop IATF 16949 - Automotive Quality Systems Standard 2
F Process FMEA for Welding and Laser Cutting FMEA and Control Plans 3
Fender1 PPAP-PSW Accuracy Concern - Laser Cut Holes In Formed Fabricated Steel Part APQP and PPAP 15
E Laser Marking effects on the Fatigue Strength of Alloys CE Marking (Conformité Européene) / CB Scheme 6
R How to determine Failure Tolerance Time of Laser Equipment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 27
H Laser Etching on Stainless Steel Knobs - Quality Issue Manufacturing and Related Processes 17
P 400 micron Difference between CMM Results and Laser Tracker Results General Measurement Device and Calibration Topics 7
D FMEA for Laser Cutting of Die Cast parts in AM60B Magnesium FMEA and Control Plans 1
J Method to determine the Uncertainty of the readings of a Laser Scanner Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Laser Weld Strength - Laser Welding Medical Instruments Reliability Analysis - Predictions, Testing and Standards 8
Q Do FDA Laser Regulations Apply to Components? US Food and Drug Administration (FDA) 1
D How to do MSA on a Laser Mike, Rules, and Pressure Gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P Internal Calibration for Laser Temperature Gauges Manufacturing and Related Processes 3
A Substantial Equivalence for Laser Wavelength - Class 2 Aesthetic Product Various Other Specifications, Standards, and related Requirements 2
E Faro Laser Tracker Calibration Source Needed General Measurement Device and Calibration Topics 5
D Laboratory where we can have parts checked for Thickness with a Laser Micrometer General Measurement Device and Calibration Topics 6
D Laser Micrometer for checking Thickness of Steel - Any Recommendations or Comments General Measurement Device and Calibration Topics 3
H Reusable Soft Tissue Surgical Laser Fiber Sterilization Method US Food and Drug Administration (FDA) 3
E Blade Inspection - Does anyone use blade scaning software for a CMM or laser scanner? Design and Development of Products and Processes 3
