If 4.1 is a process, how to assign KPIs for this process?
armani
It is correct to consider 4.1 as a process? Consequently, being a process a KPI could be established for this process?
I am thinking about smth. like "identifying the right strenghts and weaknesses".....but, again, how do u measure "right"??
BoardGuy
In and of its self it would not be considered an individual process. 4.1 is used to develop the purpose and scope of the organization's QMS based on how the organization views itself. It is, however, subject to review during the Management Review process required by 9.3. Management Review could have a KPI.
I should also noted that it is not necessary to use quantitative measurement of process effectiveness per ISO/IAF ISO 9001 Auditing Practices Group Guidance on Processes document published 13 January, 2016.
randomname
Audits are a way of measuring process performance.
Q
QAMTY
I would suggest that based on opportunities and weaknesses, try to develop plans for issues detected, which will fall in processes of the system. then
to such processes have assigned KPIs with goals.
Additionally you could add a KPI to top management, e.g. % compliment of processes
Hope this helps
BoardGuy
[FONT=&quot]Yes, some of our process measurements are linked to successful audit of the process. Key here is to remember that Clauses from Standards and procedures/work instructions of the organizations are not processes.[/FONT]
armani
OK, then...no KPI for this particular process...but if u agree this is a process, then why not?
Q
QAMTY
A process is comprissed of inputs->performing activities->output, in this context it is a process.
I understand your point, you try to be sure you are doing things well by using kpis.
But If you start trying these events as processes, you will end up full of hundred of processes and kpis, as a result you will overburden your system, in practice such events are not treated as such.
Try to identify your main processes, once identified, assign them KPIs and goals.
What the standard requires, it is to assign KPI but not in everything, only where applies.
and in this case, is sufficient kpis on main processes.
A lot of work you will have focusing only in processes that really are important.
Try to spend time on things that really "Add value".
Finally if some processes dont comply, and you do a cause and effect analysis, for sure, will indicate that 4.1 and 4.2 where not analyzed very well.
I hope this helps
Kronos147
A better question is, why? Will it make the system more effective if you measure this?
No faster way to disengage people than asking them to perform tasks that don't seem to add value, IMO.
Sidney Vianna
Post Responsibly
:agree1: Especially when these disengaged people are top management. Doing something that is perceived as non value added just make top management even more distanced from the QMS.
BoardGuy
Process measurements should only be used if they add value to the company or are required by ISO 9001. But under the 2015 revision of 9001 you can just as easily state which requirements of your QMS are organizational activities and which ones are processes.
M RFQ Process Manufacturing and Related Processes 3
D Way to stream line in-process nonconformance? Nonconformance and Corrective Action 2
P Process Validation - OQ & PQ Other Medical Device and Orthopedic Related Topics 2
D Process FMEA Owner, Designer or Manufacturer ? APQP and PPAP 9
adztesla Design change and Process change Class 3 medical device Medical Device and FDA Regulations and Standards News 2
T IVD Self-Test Notified Body Conformity Assessment Process EU Medical Device Regulations 0
H Regarding UL Certification process CE Marking (Conformité Européene) / CB Scheme 12
L Process Interaction push back during Stage 1 IATF 16949 - Automotive Quality Systems Standard 7
T Guiding document or resource to process AS9100 audit findings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
R ILAC G24 - defining process control measures, ISO 17025 related Discussions 2
L CQI-9 Special Process: Heat Treat System for Sinter parts IATF 16949 - Automotive Quality Systems Standard 0
L Cpk in relation to individual process parameters. Reliability Analysis - Predictions, Testing and Standards 1
was named killer PROCESS OWNERSHIP (QUICK QUESTION) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
T What does "fully verify" mean exactly in process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M Feedback process ISO 13485:2016 clause 8.2.1 ISO 13485:2016 - Medical Device Quality Management Systems 2
T New process capability analysis required when changing a product on the same line? IATF 16949 - Automotive Quality Systems Standard 6
P Supplier Development Process description Process Maps, Process Mapping and Turtle Diagrams 1
S Customer Defective Part Return Process Process Maps, Process Mapping and Turtle Diagrams 2
DuncanGibbons How to determine process stability for a process whose outputs should be steadily increasing? Capability, Accuracy and Stability - Processes, Machines, etc. 4
J Document hierarchy for Process mapping for ISO13485 ISO 13485:2016 - Medical Device Quality Management Systems 7
A Cosmetic product registration process EU Medical Device Regulations 0
A Sample size selection for process validation - continuous data Reliability Analysis - Predictions, Testing and Standards 9
Q Failure mode, Process Excursion and Failure mode cause ISO 14971 - Medical Device Risk Management 3
Sidney Vianna IAQG News IAQG 9401-1:2022 Changes & Organization Certification Analysis Process - OCAP Demo AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
E Process capability in a single batch Capability, Accuracy and Stability - Processes, Machines, etc. 3
Ashland78 IATF Process Control Plans not including customer name Manufacturing and Related Processes 13
S Sample size considerations in medical process qualification Reliability Analysis - Predictions, Testing and Standards 11
M Process flowcharts ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
A Small Company Implementing ISO 13485 Timeline/Process/Steps Advice ISO 13485:2016 - Medical Device Quality Management Systems 5
G Help Needed: Quality Control / Assurance process Quality Manager and Management Related Issues 3
T AS9100 Process Sequence and Interaction Map Example AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D Seeking help in validating a cleaning process. Manufacturing and Related Processes 5
R CNC process validation Manufacturing and Related Processes 1
T Process Sequence and Interaction Map AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
C Product compliance process REACH and RoHS Conversations 10
M Clinical evaluation process of FDA and MDR Medical Device and FDA Regulations and Standards News 2
V Countries without Formal Regulatory Approval Process Other Medical Device Regulations World-Wide 0
J Crimp inspection and process verification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Crimpshrine13 Bulk Process (Electroplating), Control Plan, and Process Change IATF 16949 - Automotive Quality Systems Standard 1
S Process Owner IATF 16949 - Automotive Quality Systems Standard 10
Bev D Development Process: FMEA, Critical Characteristics, Spec Setting and Controls Misc. Quality Assurance and Business Systems Related Topics 0
T Document Review Process Map AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Validation Plastic Injection Molding Process protocol ISO 13485:2016 - Medical Device Quality Management Systems 5
M Use of statistical techniques for Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 9
A Question regarding new VDA_AIAG fmea approach for process FMEA FMEA and Control Plans 0
S 9001 + 14001 Internal Auditing Process checklist, flowchart or questionnaire ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L CQI-30 Special Process: Rubber Processing System Assessment - Mixing & Molding IATF 16949 - Automotive Quality Systems Standard 4
O Process Flow Diagram, DFMEA, PFMEA, Control Plan integrated softwares FMEA and Control Plans 7
C. Tejeda Process validation of rework assembly methods (medical devices) Medical Device and FDA Regulations and Standards News 3
L Looking for feedback on Nonconformity Process Flowmap ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
