If a control operator add a photo as a visual aid, can you improve Occurrence?
diegofromitaly
Dear,
if a control operator add a photo as a visual aid, you improve Occurrence?
Or Detection??
Or nothing????
Thanks!!!
:confused:
somashekar
Dear,
Or Detection??
Or nothing????
Thanks!!!
:confused:
Hi diego, Welcome to the cove.
Let me understand you more correctly.
A control operator add a photo as a visual aid ....
You mean that a visual depiction is provided as a means of instruction within the work instruction as an approved release ?
Such a visual aid is very helpful in giving clarity to the finished task and must be so clear, with the visual aid showing not just one visual, but at least three which depicts Good, Acceptable, Bad. This has to be clear in a way the operator can see, check and decide quickly. Such a visual aid must be used and outputs checked for consistency.
We will be looking for improving detection.
Chennaiite
Never-say-die
Dear,
Or Detection??
Or nothing????
Thanks!!!
:confused:
Adding a robust Visual Aid as described by Somashekar, improves the Detection of relevant defect at the Control Station and reduces the Occurrence of 'defect outflow' from the Control station.
diegofromitaly
My request are present in a PFMEA ISO TS exam question....
There are only a correct response:
1) detection
2) occurrence
3) none of above
:truce:
I think that FMEA AIAG Manual 4° Ed. considers a visual check a prevention control, then should reduce Occurrence and not Detection,....but i'm not sure...
somashekar
1) detection
2) occurrence
3) none of above
:truce:
After all said and done, the visual aid is just finally hanging over there waiting to be used correctly. It cannot directly control an operation (leading to occurrence of a good task) but can only aid in correct decision (leading to detection of a good task)
Jen Kirley
Quality and Auditing Expert
*sigh* I often wonder who writes questions like this one, and how they are permitted to end up on the exam for use. But here we go, let us think about the PFMEA's RPM factors. From page 13:
Severity: an assessment of the level of impact of a failure on the customer.
Occurrence: how often the cause of a failure may occur.
Detection: an assessment of how well the product or process controls detect the cause of failure or the failure mode.
When we compare the three side-by-side we can see that Occurrence is process related and Detection is operator/inspector related. It is in finding what has already happened, so lowering the ranking means we are more likely to notice a problem. If a visual aid helps to do that - and I think it would because it can reduce or eliminate confusion about what's good or bad - then implementing the visual could, in fact lower the Detection ranking.
I hope this helps!
Stijloor
True prevention controls (poka yoke / error-proofing) have a direct impact on occurrence. A s result, occurrence rankings will be lower. (In FMEA speak "better")
A visual aid such as a picture is not a prevention control because it still relies on the operator to make a determination between ok and not ok. Any time a control depends on an operator (detection), occurrence rankings are not affected very much.
Stijloor.
Stijloor
@ Jennifer Kirley
Thank you, Jennifer
But I thought it was a forum to help, not a place to write arrogant reviews about people.
Does not seem the best way to conduct a forum to offend people
My interpretation of Jennifer's post is that she was referring to the people that actually develop/write these FMEA exam questions. It was in no way directed to you or folks who ask questions about FMEA...
Hope this clarifies.
Stijloor, Forum Moderator.
qusys
1) detection
2) occurrence
3) none of above
:truce:
Hi Diego,
I think that they both are directly linked, but given that you are talking about inspection I guess that detection could be surely improved because at the beginning the operator did not have any picture and then he/she is helped by having one and be more confident in detecting what is ok and what is not ok.
Hope this helps:bigwave:
Jen Kirley
@ Jennifer Kirley
Thank you, Jennifer
You are correct and completely within your rights to call me out on this issue. :agree1: I apologize for the misunderstanding. Stijloor is correct, I was referring to the people who wrote the test you were taking, but I was too vague. I should have said "I do not know why exam writers come up with questions like this one and allow them to be presented in high-stakes tests."
And, though I am usually in favor of unambiguous test questions that do not invite thinking in tangents, the question does require us to understand the difference between a process-related RPN factor and an operator/inspector-related factor. I suppose I will also be subject to such questions as I will soon enough be taking a closed-book test on the FMEA Manual; I am reminded that I have been warned to avoid over-thinking questions in that exam. So In addition to offering you an apology I thank you for a quick view of what to expect. :thanks:
R Operator's manuals as prevention design control FMEA and Control Plans 2
S Control Plan Details vs. Operator Instruction Sheets - Document Contents IATF 16949 - Automotive Quality Systems Standard 9
C Operator understanding of what Control Plans are and how they are used Document Control Systems, Procedures, Forms and Templates 13
M TS 16949 Control Of Documents - Operator Instructions IATF 16949 - Automotive Quality Systems Standard 6
S Using an "operator copy" of control plan? IATF 16949 - Automotive Quality Systems Standard 21
S Control Plans vs. Operator Instructions FMEA and Control Plans 5
K Control Plan - Does not replace information in detailed operator instruction FMEA and Control Plans 1
Forum Administrator Operator Instructions and Lot Control - Touch Screens? Document Control Systems, Procedures, Forms and Templates 1
I Integrating CAPA and Change Control processes ISO 13485:2016 - Medical Device Quality Management Systems 3
A Can a Form Template be altered in a 13485 document control system? ISO 13485:2016 - Medical Device Quality Management Systems 4
R ILAC G24 - defining process control measures, ISO 17025 related Discussions 2
MaHoDie How deep should be risk control tracebility IEC 62304 - Medical Device Software Life Cycle Processes 3
S Control of Drawings in Production Environment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
T OTS (Off-the -Shelf) Software involved in error control and messaging US Food and Drug Administration (FDA) 1
D Control Limit Calculation with multi-cavities molding Statistical Analysis Tools, Techniques and SPC 5
G Clause 8.5.1 -- Is non Identification evidence of ineffective control of production ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
J Document Control Requirements within Oracle System Document Control Systems, Procedures, Forms and Templates 1
Q IATF / AIAG: Control Plans and CC / SC requirements FMEA and Control Plans 4
Ashland78 IATF Process Control Plans not including customer name Manufacturing and Related Processes 13
M What should be measurement method in control plan if you are defining Control method as work instruction. Manufacturing and Related Processes 5
G Help Needed: Quality Control / Assurance process Quality Manager and Management Related Issues 3
T Document Approver System AS9100 Doc Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T Terms & Conditions Document Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G Control of Externally Provided Processes, Products, and Services AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
Crimpshrine13 Bulk Process (Electroplating), Control Plan, and Process Change IATF 16949 - Automotive Quality Systems Standard 1
giavannatabbs ISO 9001:2015 Control of Records - QMS Communications? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Introducing a document control system benefits Document Control Systems, Procedures, Forms and Templates 13
N Effective use of a Risk Register - Bumper sticker or Mission Control ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
L To control the essential design outputs Medical Device and FDA Regulations and Standards News 4
G Root cause for outsourced pest control service not in approved supplier list ISO 13485:2016 - Medical Device Quality Management Systems 4
A Digital Document Control - Revision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
O Process Flow Diagram, DFMEA, PFMEA, Control Plan integrated softwares FMEA and Control Plans 7
V Over 60 dimensions CMM measurement in control plan APQP and PPAP 8
A Document control system for QMS in Google Drive? Document Control Systems, Procedures, Forms and Templates 6
V Opinion on gauge control graphic General Measurement Device and Calibration Topics 5
S ISO 14001 Operational Planning and Control - Proving evidence of communicating environmental requirements to suppliers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
V How to control odour outside paintshop ISO 14001:2015 Specific Discussions 1
G FMEA versus control plan IATF 16949 - Automotive Quality Systems Standard 6
K ISO 2859-5 (single run production) control plan issues FMEA and Control Plans 2
E Control Charts ISO 17025 related Discussions 7
E Control of Sterile Barriers made by the supplier Design and Development of Products and Processes 4
E Do anyone have document of automotive production risk and control of risk? Lean in Manufacturing and Service Industries 1
M X-MR Control Chart Rules (Particularly the MR) Statistical Analysis Tools, Techniques and SPC 3
I Clinical study suppliers (service providers) -- extent of control ISO 13485:2016 - Medical Device Quality Management Systems 4
P Product Requirements Control during Design Changes Design and Development of Products and Processes 4
T Control Excel template Document Control Systems, Procedures, Forms and Templates 5
J Document Control of Online Management Software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R 8.7 Control of Nonconforming Outputs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
W Document control Document Control Systems, Procedures, Forms and Templates 10
S Control plan - Multiple batches Manufacturing and Related Processes 2
