If ew(t)=2339, how do I find T? Please help on Maths Problem
N
neoth
Hi All,
i need some help to solve the maths equation.
please see attached pic.
If ew(t)=2339, how do i find T?
please show me the workings or T=.......
showing the final ans does not help me.
Thanks a million.
Tim Folkerts
I don't know that there will be any way to invert this function (at least not any easy way).
If I were doing this, I would
1) calculate ln(2339) and substitute into the equation
2) create a spreadsheet to calculate the value of right hand side of the equation for various values of T
3) Look for places where the right hand side is close to ln(2339) ~ 7.76
4) recalculate using values of T in that neighborhood to get a more accurate estimate of T
NOTE: There could potentially be several solutions, so you might have to look for a while to make sure the first solution you find is not the only solution.
Steve Prevette
Deming Disciple
Another option is to use a non-linear optimization routine, such as Excel's "Solver" input. Subtract 2339 from the right hand side, and use that as the objective function. Tell the Solver to give a value for T such that the right hand side is as close to zero as it can get. You may have to start from several different starting values for T, as non-linear optimizations can sometimes get "stuck" on local sub-optimal values.
D Any recommendations on where to find experienced quality hires in Chicago area? Job Openings, Consulting and Employment Opportunities 3
M Find updates to REACH and Rohs regulations REACH and RoHS Conversations 1
N Where to find Regulations for Reprocessing and Reuse of Single-Use Devices Other Medical Device Related Standards 2
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
S How to find technical specification for facilities maintainance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Where can I find examples of PPAP? APQP and PPAP 6
J Where can I find the latest update to Reach and ROHS? REACH and RoHS Conversations 9
G Where to find Proficiency Test provider for photometrics (spectral %R, %T, photo density) General Measurement Device and Calibration Topics 9
C TL-9000 Certifying Body Issue - Auditor failed to find an issue for 10 years TL 9000 Telecommunications Standard and QuEST 16
R How to find out the UMDNS code for medical devices CE Marking (Conformité Européene) / CB Scheme 1
M Plating standards - Where to find information AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D Where I can find an ISO 13485:2016 Audit Schedule example? ISO 13485:2016 - Medical Device Quality Management Systems 4
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
N Where I can find an Excel sample/template for recording Delivery Time and Cost Excel .xls Spreadsheet Templates and Tools 2
R Specification on flare testing extruded aluminum - Where to find Design and Development of Products and Processes 1
A AS9100 Rev:D in Spanish - where can I find a Spanish version? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
I Moving into Clinical Trials and need to find GMP Suppliers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Where can I find an English version of Japan's PMD Act? Other ISO and International Standards and European Regulations 2
S Where to Find DEV and DFE numbers on FDA Website Other Medical Device and Orthopedic Related Topics 3
P Calibration in the UK to ISO 17025..cant find anyone ISO 17025 related Discussions 8
N Where to find a Qualified FDA Supplier Auditor located in China China Medical Device Regulations 7
G Where I could find any project HSE plan templates Occupational Health & Safety Management Standards 4
A Where to find a Draft Copy of IATF 16949:2016? IATF 16949 - Automotive Quality Systems Standard 23
M How to find the number of required data - Correlation with 4 variables Using Minitab Software 2
I Where to find VDA 6.3 Robust Production Process (rpp) PDF file ? VDA Standards - Germany's Automotive Standards 1
P Where to find the UMDNS code for CE Mark CE Marking (Conformité Européene) / CB Scheme 1
X Where to find UAE medical device registration regulation and guidelines Other Medical Device Regulations World-Wide 3
I Non-functional Corrective Action - Could Not Find some Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
P Where to find conformance statistics for ISO 15189 Other Medical Device Regulations World-Wide 1
J Where can I find a product's CE Mark Number? CE Marking (Conformité Européene) / CB Scheme 20
L Find Local Authorized Representative (LAR) for medical device EU Medical Device Regulations 5
H How to find a good ISO 9001 Implementation Consultant in Calgary, Canada? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Process Capability - Changing Limits to Improve Cpk or find Root Causes? Capability, Accuracy and Stability - Processes, Machines, etc. 6
R Where to find 21 CFR Part 820 Translated into Czech, Spanish, and German 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Where can I find the NADCAP Audit Criteria for all the processes? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L Where to find ISO27000 Annex A? General Auditing Discussions 2
W Where to find the Daimler DBL 6992 10 new (old) standard Customer and Company Specific Requirements 1
V Where I can find an AAR form on Ford Covisint? APQP and PPAP 1
L Find the right Test to fail method according to the standards of LV 124 FMEA and Control Plans 1
G Where to find the ANSI Z1.9 Rosetta Stone Capability, Accuracy and Stability - Processes, Machines, etc. 9
M How to find a Good Registrar (Certification Body) for ISO TS 16949 certification Registrars and Notified Bodies 3
R How and Where can I find IFU (Instructions For Use) examples? ISO 13485:2016 - Medical Device Quality Management Systems 6
Marc Just for fun - How did you find the Elsmar Discussion Forum Forum News and General Information 9
V Where to find Red/White Rust Rating Requirements? APQP and PPAP 4
P VDA 2 - Where to find EMPB (Erstmusterpr?fbericht) bilingual forms VDA Standards - Germany's Automotive Standards 2
A How can I find out if a medical device is prescription only? Other US Medical Device Regulations 4
K Where do I find Frequencies and Composite Scale in Minitab? Using Minitab Software 2
V Where do I find Adverse Event Database for Medical Devices? Quality Manager and Management Related Issues 2
S Searching Patent Applications - How to find out when a patent is abandoned? Design and Development of Products and Processes 3
W How to find a good D-MAH (Marketing Authorization Holder) for Japan Japan Medical Device Regulations 2
