IF formula - Excel 2003
P
poppy666
I'm a total novice looking for some help.
I would like to enter a date into a cell in sheet 2-14 and have a specific cell in sheet 1 have a tick (check) mark. If no date entered then no tick.
Can anyone help me with this please?
L
lk2012
hi, using the IF formula is a good idea. This formula will be in your cell no1. It will be like IF(cell2-14 contains XYZ,"tick", <leave empty>).
Best thing is to check online tutorials for the edition of Excel you're using to make sure you've got the right format.
Ninja
Looking for Reality
Howdy,
The "Tick mark" will be a bit involved...but having it give a value or text is not so hard:
The difference being one is a symbol, and the other is a value.
Both are possible.
{I'll assume the cell where the date goes is cell A113}
For the cell where you want the result...put the IF in as
=IF(A113 > 0 , "tick" , "" )
If you want the result to be text, you need the quotations around the result.
If you want the result to be a number, you do not need the quotes.
The "" end result is the character for {blank}.
HTH
Steve Prevette
Deming Disciple
I usually use an "X" rather than a tick mark. There is probably a check mark in the special character list, but is a pain to try to deal with.
Darius
=+IF(O347=0,"",CHAR(252)) or =+IF(O347=0,"",?)
and changing the character format to Wingdings
change O347=0 to the comparison that suits you.
