If the inspection and analysis of raw material is very expensive?
blue moon
#11
this is his system
no certificate for the small quantity
for big quantity we get a copy from the certificate
somashekar
#12
this is his system
You could do these .....
1. Purchase the big quantity if it is OK with your inventory system
2. Get PO terms to include certificate of analysis for small quantity (cost may perhaps include premium for certificate of analysis)
3. Approach any third party analytical lab for testing and report by providing sample.
If traceability is your requirement, any one of the above will work for you.
blue moon
#13
really friend
i try to do this
we can't buy big quantity , we buy as customer requirement
can i accept the material with out certificate as the history of supplier ?
P
pga_gold
#14
The bottom line is you have absolutely no way of knowing the material meets your requirements, which creates quite a risk for your organization. There are numerous things you can do differently on future orders (as outlined by somashekar and me). But, what should you do with this order? What if you run nonconforming raw material? Your finished product will not meet your customers expectations, perhaps causing loss of business. The product may pose a safety or health risk if used improperly. Simply, I would reject this material and send it back unless the supplier provides the certificate you are looking for. I wouldn't put myself or organization at risk.
Actually, the supplier should be happy that you trust them enough to only receive material based on the certificate of conformance. If they are adamant about not giving up the certificate, I would strongly consider outside testing as a means to verify one of the "larger" shipments actually meets the requirements you set forth. It may not be a bad idea to spot check your supplier a couple times per year with outside lab testing. I'm sure the cost of that testing offsets the cost of potential risks.
I am interested to hear what you finally decide and how things shake out.
blue moon
#15
how i get buy a material with 200 USD and pay 400 USD for anaylsis
it is better to refused the order
tracebility is not required so we didn't do it
P
pga_gold
#16
I may not have been too clear about suggesting outside testing. Please allow me to clarify my statement.
I would return this particular lot of material because you do not know what it is.
I would send a sample from a batch of material that I do have a certificate with. I would then compare those 3rd party results with the supplier results. This would be done twice per year as a means of keeping the supplier honest. You are only looking at spending $800 USD (400 x 2 tests per year). Not a bad price for supplier ensurance. The 3rd party test results will confirm or deny your practice of accepting material based on this suppliers certificate results, too.
blue moon
#17
this mean if i do the outside anaylis
then i will not need a certificate for each time i get the material
arios
#18
Salam Aliki!
1. I have seen cases where the supplier uploads their certificates to a web site so they don't need to be contacted to provide one with every shipment. The client just gets to the given site and finds the one belonging to their batch and prints them out. Ask if they do something similar, if they do, that will be really nice.
2. If you have good quality history with the supplied product, and the vendor has a good QMS you can consider exploring other acceptance methods (e,g, skip lot inspection), but I certainly don't feel comfortable with the apparent lack of cooperation of your vendor. If they can't support you on this easy task, I don't know what to expect from them on bigger issues.
P
pga_gold
#19
You would need a certificate for every shipment you receive from this supplier, according to your current receiving procedures.
The outside testing would validate your supplier certificates. If the outside testing and the supplier certificates provide the same results, then you can be confident in the supplier certificates. I only mentioned outside testing because I wouldn't trust a supplier that doesn't provide me the CofA on "small" shipments but does on "large" shipments.
U
Umang Vidyarthi
#20
he is the avialabel supplier
we have no soloution.
this is his system
It seems that you have reached an impasse with your supplier, and have no solution in sight to break the dead-lock. I have a small question: Why is it necessary to have a Material test certificate from the vendor? Does your proceedure necessitates a T.C. for all incoming materials? If yes, then you may review and modify your procedure since this is not a mandatory requirement by ISO. Have a look:
Clause7.4.3. Verification of purchased product:
The organization shall establish and implement the inspection or other activities necessary for ensuring that the purchased product meets specified purchase requirements.....
"HOW" is for the management to determine. Does your purchase order embodies all the specifications of the ordered material of 'small quantities'? If yes, then modification of your procedure order may be the solution to your problem. If not then there is no problem!
really friend
i try to do this
Depends on two things. 1. Does your customer wants the TC? Is it mentioned in his Purchase Order? 2. Is there any complaint from 'small quantity' customer about poor quality of the raw material?
If the answer is no, then why bother.
:caution: It is'nt good to disregard a customer of low volumes. Some day he may be in high volumes, and then he will remember your support.
Testing from outside agencies is good for a cross check once in a while, the frequency of the same may be decided by the management.
Umang :D
L IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA) - Visual Inspection IATF 16949 - Automotive Quality Systems Standard 14
V Analysis of 'Value Added' System & Process Steps - Inspection Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
A Inspection Capability Study (Kappa Analysis / Attribute R&R) as Certification Req't Training - Internal, External, Online and Distance Learning 7
automoto Visual Inspection of a Weld - MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Z MSA (Measurement Systems Analysis) for gages used in final inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Time Based Inspection Data Analysis Quality Tools, Improvement and Analysis 1
B Automated Vision Inspection System MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Automated In-Line Inspection MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
N PFMEAs and Inspection Process - Feasibility Analysis FMEA and Control Plans 5
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
K Visual Inspection Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
B 4DINSPEC Inspection Equipment General Measurement Device and Calibration Topics 0
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Industrial RX inspection of welds (Oil&Gas industry) Reliability Analysis - Predictions, Testing and Standards 0
C In-process inspection - Tooling and assembly lines for automotive companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D FAA inspection at my repair station - Rating Check Federal Aviation Administration (FAA) Standards and Requirements 0
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
R Inspection and Work order process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
Y What are different Special Inspection Level 1-4 and General spesification 1-3 ? AQL - Acceptable Quality Level 0
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
B GM GP-12 Exit Criteria - Additional Safe Launch Inspection - (Also see GM1927-28 ) Customer and Company Specific Requirements 2
S Process Inspection -Sub assembly process inspection sheet Lean in Manufacturing and Service Industries 3
C OEE and In-process Inspection Manufacturing and Related Processes 2
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
I Mother bobbin final inspection criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
G Inspection Logs - Asked to remove an Inspection Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Skooma Receiving Inspection - Boss trying to save money AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
T Nonconforming product at customer detected by a routine inspection by field service Nonconformance and Corrective Action 9
A Definition of customer in ITP (Inspection & Test Plan) Contract Review Process 3
A DCMA inspection for a drop-shipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S QUALITY OBJECTIVEs for third party garments factory inspection ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Lean and Elimination of QC Inspection Points in a New factory Lean in Manufacturing and Service Industries 9
F FDA-registration and inspection cost 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
I Receiving Inspection Requirement in IATF IATF 16949 - Automotive Quality Systems Standard 3
R Supplier related drawings and verification of process requirements - Source Inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Good Acceptance Activity/Inspection flowchart for reference - Wanted Please Process Maps, Process Mapping and Turtle Diagrams 2
K Inspection Certificate EN 10204 2.1 - Distribution company Other ISO and International Standards and European Regulations 4
S Improving Quality inspection gate in one piece flow manufacturing process Manufacturing and Related Processes 0
