You should make sure that your management review(s) notes or minutes highlight your concerns. Be specific but brief. Use internal audit results to show where the system is failing. Product conformance, process performance and delivery issues are results of system failure. Those should be addressed but, separately from the management system audit review.
The management review is a KEY component of the overall system. After your input management should produce some actions and/or decisions. If you present the information correctly, then those actions/decisions should highlight a course of action - either continuing with the cert. audit (with corrective action) or delaying.
Back to the original post: In my opinion, you do not have to meet the overall quality objectives to become certified. BUT you should have clear actions in place to achieve those goals. It would help if by the time of the audit that some of the corrective action was effective (if not meeting the goal, at least moving in the right direction).
Unfortunately - you have to abide by the decisions of management. If the organization goes ahead with the cert. audit at least you presented the options. Most likely - based on what you have provided - the organization will have to make some corrective action to make the system compliant (at best)....but this time the directive will come from the cert. auditors.
Good luck!
Good luck!
