If we do not have Preventive Action, is it an ISO 9001 Nonconformance?
SpongeMouse
#11
Re: If we do not have Preventive Action, is it a nonconformance?
i agree with the guys, as i understand the "preventive" word, it is part of the continuous improvement process, of which it is a requirement.
my 2 cents ;)
samsung
#12
Both Howste and Sorin have provided reasonable amount of explanation and rational before coming to a concluding remark. I do agree with the reasoning they provided in support of their statements.
However, the auditors' observations/NC's are generally contextual and it's also possible that, while going through the Internal Audit reports, he might have come across such issues which could have been easily prevented before those were detected by the auditors.
jkuil
#13
I understand the principle, but I mostly disagree. The auditor shouldn't be deciding where the organization "should have taken" preventive actions. The organization should be the ones prioritizing
We do not dissagree on the definition of "should have take", thanks for adding the clarification.
Considering the above: better wording would even be "didn't execute the (CA)PA process where the organisation should have. Because the outcome of the PA process may be a justifyable not to implement any PA. If the risks associated with a non-conformity are low, but the costs to prevent them are excesively high a PA may not be required. But if the absense of the PA is not justified by a documented risk assessment, this still is a non-conformity. Again, the criteria for the risk assessment must be specified by the compagny and should be used by the auditor as audit criteria.
samsung
#14
hi
in our last audit,IMQ auditor issues a NCR coz our organization do not have any preventive actions.is it correct? i said to him it is not correct but i can not prove it . please help me to prove it to this company(IMQ I mean)
let you know that our records is for 3 months.
If you want a straightforward answer to your query, look at this pretty clear explanation.
Big Jim
#15
If the auditor is/was able to show you a POTENTIAL NC and you were not able to produce a PA, then I may conclude that the auditor was right.
BUT, if the auditor wrote you up ONLY because you did not have any PA, then he/she is full of ****.
The clause quoted in this topic:
ISO 9001:2008 clause 8.5.3
The organization shall determine action to eliminate the causes of potential nonconformities in order to prevent their occurrence.
So...we have 2 key words here: potential and determine. It is up to the organization to identify the POTENTIAL NC and DETERMINE the necessary action (aka PA) in order to eliminate the cause of POTENTIAL NC.
Can you provide the exact text of the NC? - the one from the auditor?
I should add that whenever I write a nonconformance for no preventive actions, I always establish with the auditee that they had some that they did not bother to record. They are ALWAYS so prevelant that it is not hard to do.
Richard Pike
#16
Yes that indeed is pretty clear.
As is often the case, we may not have all the information surrounding the NC so I wouldn't be to quick to criticize the auditor in question.
Being a little sadistic when it comes to incompetant auditors (and as i said I am not implying this auditor was incompetent) it would be interesting to receive the NC and then present the Auditor with the official interpretation.
Any predictions to what his/her response may have been or could have been?
howste
Thaumaturge
#17
This interpretation is specific to 8.5.3a, not to the whole preventive action clause. If you read it in isolation, it sounds like preventive actions are optional. They're not.
Sorin
#18
It sounds like your auditor is correct. If you have not been taking preventive actions, it's a nonconformity.
I wrote a nonconformance for exactly that last week. The company had been registered for a year, and not one preventive action had been written. It is not optional.
Yes, it is required and the auditor is right. You can refer this guidance document from ISO which details the 8.5.3 section on auditing of PA.
I think that we are dealing with a wrong interpretation of the standard.
The way I see it, I (as an audited company) may be written up IF I have no tools in place to foresee potential NCs (analyzing trends, etc.)
However, IF the tools are in place, IF the trends are being discussed and IF there is evidence that the company DETERMINED there is no need for a CA, I would really like to be written up for not having PAs.
So….the PAs ARE optional. What is important is:
1.Tools in place to foresee potential NCs.
2. Analyzing the trends as revealed at no 1.
3. Take action aka PA (IF determined as necessary by the COMPANY).
howste
Thaumaturge
#19
The certification body can't grant registration to the standard until there is evidence of effective implementation of all the requirements of the standard. If there are no records of preventive actions taken, how can they do that?
Sorin
#20
The essence of clause 8.5.3 is not the existence of documented PAs but the steps taken to foresee and analyze the possibility of potential NC and the steps taken (if necessary) to prevent the apparition of those potential NCs.
IMO implied...
K CAPA (Corrective and Preventive Action) - ISO 13485 Nonconformance and Corrective Action 1
M Preventive Action Process question - ISO 9001 Clause 8.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
I ISO 9001:2000 Preventive Action Procedure: Seeking examples ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Corrective Action and Preventive Action clauses - ISO 9001 - Corrective Action Nonconformance and Corrective Action 6
P Definition Corrective and Preventive Action definitions - ISO 9001 vs. ISO 14001 Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 31
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
C If it doesn't prevent a non-conformance, is it a preventive action? IATF 16949 - Automotive Quality Systems Standard 13
R Evaluating the need for preventive action Preventive Action and Continuous Improvement 3
B Stakeholder Initiated Corrective and Preventive Action Misc. Quality Assurance and Business Systems Related Topics 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
M Training in 8D Problem Solving as a Preventive Action? Problem Solving, Root Cause Fault and Failure Analysis 9
J If Corrective and Preventive Action were truly Effective IATF 16949 - Automotive Quality Systems Standard 3
R Preventive Action - confusing ISO 13485:2016 - Medical Device Quality Management Systems 5
Q Preventive Action - How to call the prevention when there is not a clause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
somashekar The Preventive Action Demystified ISO 13485:2016 - Medical Device Quality Management Systems 8
Q Evaluating Effectiveness of a Preventive Action after Closure Preventive Action and Continuous Improvement 7
A Preventive Action and Risk Assessment Audit Process Audits and Layered Process Audits 5
J Software and Methods for Tracking CAPA (Corrective and Preventive Action) items US Food and Drug Administration (FDA) 3
A Preventive Action or Corrective Action - Paper cuts Nonconformance and Corrective Action 14
M Corrective and Preventive Action - Prevent Recurrence is not Preventive Action? Nonconformance and Corrective Action 24
K Definition Correction, Corrective Action and Preventive Action - Definition of terms Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 28
F Software recommendations for corrective and preventive action Quality Assurance and Compliance Software Tools and Solutions 2
K Corrective and preventive action for Non Conformance on PFMEA FMEA and Control Plans 30
B Struggling With Writing PA (Preventive Action) Procedure Preventive Action and Continuous Improvement 11
E Can anyone share a Preventive Action Form or Template ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
W Compliance to 8.5.2 Corrective action 8.5.3 Preventive action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
P Customer Complaint Preventive Action Assistance Preventive Action and Continuous Improvement 3
T Corrective Action and Preventive Action in a Holding Company Nonconformance and Corrective Action 6
M What is Preventive Action taken as part of a Corrective Action? Nonconformance and Corrective Action 5
MarilynJ6354 Definition Improvement Suggestion vs. Preventive Action - Clear Definitions and Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
C The prudence of combining non-conformance reports with corrective/preventive action Nonconformance and Corrective Action 10
N Corrective and Preventive Action in 8D Problem Solving Nonconformance and Corrective Action 21
B Near Miss = Preventive Action Request (PAR)? Miscellaneous Environmental Standards and EMS Related Discussions 1
M Boosting a Preventive Action System Quality Manager and Management Related Issues 2
D CAPA (Corrective and Preventive Action) Flow Chart example wanted Preventive Action and Continuous Improvement 3
J Can Corrective Action be the same as Preventive Action? Nonconformance and Corrective Action 33
sagai Preventive Action vs. Corrective Action as defined by 21CFR820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
R Does FDA require monitoring competitor device failures for preventive action? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C Nonconformance, Corrective and Preventive Action Procedure(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Recommendations for criteria on creating a CAPA (Corrective and Preventive Action) ISO 13485:2016 - Medical Device Quality Management Systems 8
L How to deal with too many CARs (Corrective Action Requests), PARs (Preventive Action) Nonconformance and Corrective Action 25
B Certification Body insist on evidence of Preventive Action during Stage 2 audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P Lessons Learned Identification - Potential Preventive Action Responsibilities Preventive Action and Continuous Improvement 4
N Combining both Corrective Action and Preventive action procedures into one SOP Nonconformance and Corrective Action 4
T Action plan: How to manage actions, preventive actions and opportunities of improv? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
sagai Should Corrective Action be segregated from Preventive Action? ISO 13485:2016 - Medical Device Quality Management Systems 10
B Electronic Corrective/Preventive Action Report for our Customer Service Department Nonconformance and Corrective Action 9
B Corrective and Preventive Action Procedure for Customer Service Nonconformance and Corrective Action 5
Q Recover a Damaged CAPA (Corrective and Preventive Action) Project Preventive Action and Continuous Improvement 6
