If we do not have Preventive Action, is it an ISO 9001 Nonconformance?
Big Jim
#31
Re: If we do not have Preventive Action, is it a nonconformance?
Nope. The purpose of PA is the prevention of nonconformities.
If you have an occurrence of a nonconformity, your PA process has failed. ;)
Stijloor.
That's a bit harsh but I think you are on the right track.
howste
Thaumaturge
#32
Further, the standard requires that "the organization shall determine" (but not necessarily 'TAKE') "action to eliminate the causes of potential nonconformities";
Why would you determine action to take, but not take the action? Let's see how that logic would work with another important clause of the standard:
ISO 9001:2008 clause 4.1 said:
The organization shall
a) determine the processes needed for the quality management system and their application throughout the organization (see 1.2),
b) determine the sequence and interaction of these processes,
c) determine criteria and methods needed to ensure that both the operation and control of these processes are effective...
By the logic above, we would determine the processes of the system, but not actually implement them. We would determine interactions of the processes, but not actually have interactions. We would also determine criteria and methods to ensure that the processes were effective, but choose instead to have ineffective processes. Oh wait -- the processes coudn't be effective anyway because we didn't implement them to begin with... :notme:
Essentially that logic rips the guts out of the whole QMS. No thanks. I choose to believe that if the standard requires us to determine something, it also requires us to implement it.
Stijloor
#33
Thank you Jim.
I always look at this from a Customer's point of view. We must protect the Customer from receiving sh*tty product. See, this customer could be you or me. :yes:
Stijloor.
Sorin
#34
Well...sigh...you took the quote of 4.1 out of context. The whole clause reads:
The organization shall establish, document, implement and maintain a quality management system and continually improve its effectiveness in accordance with the requirements of this International Standard.
c) determine criteria and methods needed to ensure that both the operation and control of these processes are effective,
d) ensure the availability of resources and information necessary to support the operation and monitoring of these processes,
e) monitor, measure where applicable, and analyse these processes, and
f) implement actions necessary to achieve planned results and continual improvement of these processes.
These processes shall be managed by the organization.....
Richard Pike
#35
Because that is exactly how Business is conducted!
Risk acceptance is based on, amongst other things, Cost Benefit Analysis. During FMEA for example, a number of recomend actions are often put forward, however not all are implemented.
Theoretically if enough resources are thrown at a process, most things can be prevented!
Poka Yoke is another example, yes most things can be fool proofed, but the available resources coupled with Cost Benefit will determine "what" is fool proofed.
Again I maintain that it is not the Auditors business to interfere with the specifics of what should be prevented and what should not.
Stijloor
#36
<snip> Again I maintain that it is not the Auditors business to interfere with the specifics of what should be prevented and what should not.
Reporting a sloppy Preventive Action process IS the auditor's business.
Stijloor.
Sorin
#37
Stijloor.
Not really....an occurrence of the same kind of NC could mean that the real root cause was not yet found. And the PA process could be really working.
It's all nice and dandy in organizations that have the time and manpower to go through in-depth, to the bone, root cause analysis, but in real life , small to medium size companies, most of the time, the trial and error is still the most, single used approach (I am not advocating, just stating what I saw).
And the reason behind that is that those companies can move really fast in terms of trials, where in big organizations, it could be a real headache.
It's just a different approach. But I would not raise a NC for occurence of the same NC IF it's part of trial and error approach.
Richard Pike
#38
Thanks for that!
Far too many Auditors want to inflict their morals and ambitions onto an Organization, instead of doing what they get paid for - Audit.
A year ago there was evidence that an effective Preventive Action Process was in place.
What did that "approved" procedure require in respect to the raising of preventive actions. If those procedures do not adequately cover the continued formulation of Preventive Actions - then the NC is Procedures don't adequately cover the requirements !!! and state exactly what is missing.
I reiterate, if no new processes or products are introduced during the subsequent year, then what preventive action is being looked for?
If new processes / products were introduced, then did the organization follow their own procedures? If they did, then what is the problem, if they didn't (follow their own procedures) then there would surely be no argument on the non-conformance?
Richard Pike
#39
Stijloor.
Who says its sloppy? That is an assumption based on some very limited information provided by the originator.
Because the Organization chooses NOT to implement certain preventive actions does not imply it is sloppy.
What is sloppy, is a half constructed NC without any supporting evidence coupled with poor auditing technique which jumps to the conclusion that because the auditor is not presented with "a preventive action" (whatever their interpretation of that is) then the Preventive Action Process is non compliant.
Many other examples of what constitutes preventive action (aside from a "preventive action") have been quoted in this thread.
From what I am understanding there are a couple of auditors here that would have been happy had the Organization simply documented a couple of Preventive Actions; and that in my opinion is what would indeed have been "sloppy" !
Big Jim
#40
I'm having trouble following your line of thought. I'm wondering if you have a basic misunderstanding of the difference between corrective action and preventive action. A repeating nonconformance would be a corrective action issue. What you do to prevent a recurrance is still corrective action not preventive action.
K CAPA (Corrective and Preventive Action) - ISO 13485 Nonconformance and Corrective Action 1
M Preventive Action Process question - ISO 9001 Clause 8.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
I ISO 9001:2000 Preventive Action Procedure: Seeking examples ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Corrective Action and Preventive Action clauses - ISO 9001 - Corrective Action Nonconformance and Corrective Action 6
P Definition Corrective and Preventive Action definitions - ISO 9001 vs. ISO 14001 Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 31
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
C If it doesn't prevent a non-conformance, is it a preventive action? IATF 16949 - Automotive Quality Systems Standard 13
R Evaluating the need for preventive action Preventive Action and Continuous Improvement 3
B Stakeholder Initiated Corrective and Preventive Action Misc. Quality Assurance and Business Systems Related Topics 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
M Training in 8D Problem Solving as a Preventive Action? Problem Solving, Root Cause Fault and Failure Analysis 9
J If Corrective and Preventive Action were truly Effective IATF 16949 - Automotive Quality Systems Standard 3
R Preventive Action - confusing ISO 13485:2016 - Medical Device Quality Management Systems 5
Q Preventive Action - How to call the prevention when there is not a clause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
somashekar The Preventive Action Demystified ISO 13485:2016 - Medical Device Quality Management Systems 8
Q Evaluating Effectiveness of a Preventive Action after Closure Preventive Action and Continuous Improvement 7
A Preventive Action and Risk Assessment Audit Process Audits and Layered Process Audits 5
J Software and Methods for Tracking CAPA (Corrective and Preventive Action) items US Food and Drug Administration (FDA) 3
A Preventive Action or Corrective Action - Paper cuts Nonconformance and Corrective Action 14
M Corrective and Preventive Action - Prevent Recurrence is not Preventive Action? Nonconformance and Corrective Action 24
K Definition Correction, Corrective Action and Preventive Action - Definition of terms Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 28
F Software recommendations for corrective and preventive action Quality Assurance and Compliance Software Tools and Solutions 2
K Corrective and preventive action for Non Conformance on PFMEA FMEA and Control Plans 30
B Struggling With Writing PA (Preventive Action) Procedure Preventive Action and Continuous Improvement 11
E Can anyone share a Preventive Action Form or Template ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
W Compliance to 8.5.2 Corrective action 8.5.3 Preventive action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
P Customer Complaint Preventive Action Assistance Preventive Action and Continuous Improvement 3
T Corrective Action and Preventive Action in a Holding Company Nonconformance and Corrective Action 6
M What is Preventive Action taken as part of a Corrective Action? Nonconformance and Corrective Action 5
MarilynJ6354 Definition Improvement Suggestion vs. Preventive Action - Clear Definitions and Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
C The prudence of combining non-conformance reports with corrective/preventive action Nonconformance and Corrective Action 10
N Corrective and Preventive Action in 8D Problem Solving Nonconformance and Corrective Action 21
B Near Miss = Preventive Action Request (PAR)? Miscellaneous Environmental Standards and EMS Related Discussions 1
M Boosting a Preventive Action System Quality Manager and Management Related Issues 2
D CAPA (Corrective and Preventive Action) Flow Chart example wanted Preventive Action and Continuous Improvement 3
J Can Corrective Action be the same as Preventive Action? Nonconformance and Corrective Action 33
sagai Preventive Action vs. Corrective Action as defined by 21CFR820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
R Does FDA require monitoring competitor device failures for preventive action? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C Nonconformance, Corrective and Preventive Action Procedure(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Recommendations for criteria on creating a CAPA (Corrective and Preventive Action) ISO 13485:2016 - Medical Device Quality Management Systems 8
L How to deal with too many CARs (Corrective Action Requests), PARs (Preventive Action) Nonconformance and Corrective Action 25
B Certification Body insist on evidence of Preventive Action during Stage 2 audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P Lessons Learned Identification - Potential Preventive Action Responsibilities Preventive Action and Continuous Improvement 4
N Combining both Corrective Action and Preventive action procedures into one SOP Nonconformance and Corrective Action 4
T Action plan: How to manage actions, preventive actions and opportunities of improv? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
sagai Should Corrective Action be segregated from Preventive Action? ISO 13485:2016 - Medical Device Quality Management Systems 10
B Electronic Corrective/Preventive Action Report for our Customer Service Department Nonconformance and Corrective Action 9
B Corrective and Preventive Action Procedure for Customer Service Nonconformance and Corrective Action 5
Q Recover a Damaged CAPA (Corrective and Preventive Action) Project Preventive Action and Continuous Improvement 6
