Ignoring a Failed Gage R&R and upcoming external audit
UncleFester
#11
Hi JohnH, it looks like you're trying to maintain your certification, but as you say - you're "being told to flatout ignore the 2018 failed gauge R&R / do nothing to correct it and present the 2006 Gauge R&R."
To me, it's the culture of the organisation that's really at fault if that's the attitude of your seniors. If this is just one instance I'm sure there could be more.
As it's been written before, "Culture eats strategy for breakfast".
Judegu
#12
If I found that your measurement system did not pass. rather than ask you why you are hiding it, I would consider to check for your deviation and containment processes.
Hi, sir. Here is one question. In this case, only variable Gage R&R failed. Is it necessary to implement a containment process?
Mr.Ruiz
#13
Hi Judegu, if your Gage R&R study failed, a common containment action is to segregate the device used for the study from your production process, since the GR&R shows that is not a reliable equipment, but, you cannot leave the manufacturing process without an equipment to perform those measures (process controls). That's where a deviation process should be consider as defined in 8.5.6.1.1 sub-clause.
per 7.1.5.2 at the bottom of the clause states:
"The organization shall determine if the validity of previous measurement results has been adversely affected when measuring equipment is found to be unfit for its intended purpose, and shall take appropriate action as necessary."
Most of the companies already have those "containment actions" in place, but, for some of them this is just a knowledge acquired thru experience, and has never been consider to be documented.
Sometimes, we use to perform this Gage R&R studies just to cover some sort of requirement, but we are losing the primary intention of it. Remember that a failed Gage R&R could be just a formal notice that something is not going according to the plan. (Page 128 MSA 4ed).
Judegu
#15
Hi Ruiz. I think when Gage R&R failes, the "bad" machine is only one of the possible causes, right? If we identify it is the machine which causes the fail, we should pull it out of the production. If we find out it is the inspector' being lack of training, we can keep the machine in the line, and train the incompetent inspector instead, right?
Mr.Ruiz
#16
Hi Judegu,
Yes, it is possible, however, two things should be carried out prior to letting the equipment in production floor.
1-a new analysis to make sure that the cause was the measurement taken by the operator and not the equipment, and;
2-Limit its use until new analysis.
ezekieltemple
#17
It seems you need to get to the root cause of the difference in Gauge R&Rs... (AFTER that we can offer helpful/informed advice...)
Additionally, regarding to "having to repeat"a gauge R&R study... There are many threads discussing that Gauge R&Rs do not "HAVE" to be done more than once (if done correctly) - although it can be for a variety of reasons... (did your auditor see operators that needed training and suggest the Gage R&R to help you realize that...?)
REFERENCED THREADS:
Re: Gauge R&R studies - How often do you have to repeat a gage R&R study?
The fact is a correctly performed gage R&R never needs to be redone. There is no time function to gage R&R. It has one fundamental function: determine if the gage is the correct gage for the job. The portions of MSA that have a time function are calibration, stability, etc. They verify the gage system is still working correctly.
Often customers will ask for annual gage R&R's. They do it for one of three reasons -1. they believe they were not performed correctly the first time, 2. they think you likely changed the gage system and did not report it or 3. they have very little understanding of gage R&R themselves. However, those anomalies themselves do not justify multiple, ongoing gage R&Rs.
Ever read through a thread as an outsider and see clearly that people are talking about two different topics? This seems to be the case here (though Bob and Bev are trying well to point this out too).
Gage R&R is a test to see if a measurement method (Gage and use of that gage) is appropriate for measuring a particular feature/characteristic.
It either is appropriate or is not appropriate...period.
Three years of waiting will not chage its appropriateness. Heavy use will not change its appropriateness.
A new customer will not change its appropriateness.
Based on this alone, Gage R&R is a one time proof.
When operators change, it may be worthwhile to verify that the new ones are using the same method. This does not require Gage R&R, though you may choose to use that tool.
When a gage is used heavily and may drift, it may be worthwhile to verify that the gage is still accurate and repeatable. This does not require Gage R&R, though you may choose to use that tool.
Bottom line is that Gage R&R does not have to be run again...the test method is appropriate for that which is being tested.
You may choose to run it again for some other purpose...but there is no need to check for appropriateness again.
Judegu
#18
Hi ezekietemple, your opinion is quite new to me. IMO, manafaturing process does not always stay unchanged. If the manufacturing pocess has been improved significantly, the variation of its output i.e. products would be largely decreased. In this case, though the gage is still in its good condition, the result of Gage R & R would not stay the same, the result would get worse. And the gage may not be suitable to measure this improved process. Moreover it is possible that the operators who use this gage would be also changed. In order to know whether this measuring system works well or not, the Gage R&R should be run again, right?
#19
Your example raises a valid point, but you would not have to repeat the entire study. You could take the original study, substitute the new process variation and calculate the revised metrics. One scenario that I can think of that would make it advisable to repeat the entire study would be a process change that impacts the variation in form in such a way that it would affect how the gage measures. However, the gage would be more sensitive to a deterioration in the process than to an improvement.
Judegu
#20
Hi Miner. Would you please give me an example which could show me how to do it. I myself still have troubles in fully understanding the whole mechanism of Gage R & R. The easy way for me to perform the Gage R & R is via Minitab.
Yes, I totally agree. In practice, improvement is much harder to achieved than deterioration is. What is more, even the result of the gage R&R got worse due to this kind of process improvement, there would be still low risk for the customer if we do nothing about the gage.
F Ignoring portions of GGG-P-463c is "globally" practiced? General Measurement Device and Calibration Topics 4
D Transformation of Data Normality Failed Using Minitab Software 11
C TL-9000 Certifying Body Issue - Auditor failed to find an issue for 10 years TL 9000 Telecommunications Standard and QuEST 16
A Failed the AS9120B Exam Twice.....Need Help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S FDA electronic submission gateway (ESG): FAILED eMDR Submission Other US Medical Device Regulations 3
Q How to manage with customer % failed product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Will A Few Failed Solder Joints Make Me RoHS Non Compliant? RoHS, REACH, ELV, IMDS and Restricted Substances 9
R Registrars offering to perform Second Party Audits - Have they failed their role? Registrars and Notified Bodies 105
N Final Inspection Retesting for Failed Batches Nonconformance and Corrective Action 6
S Statistics and Sampling - Accounting for Failed Tests Statistical Analysis Tools, Techniques and SPC 10
D Failed 350-018 exam Professional Certifications and Degrees 3
G Gage Recall Analysis - Threaded Plug Gage has failed Calibration General Measurement Device and Calibration Topics 10
P Is it necessary to perform Root Cause Analysis for each failed part? Problem Solving, Root Cause Fault and Failure Analysis 16
S ISO/TS 16949 In Doldrums - Just failed disappointingly in the ISO9001 System Audit General Auditing Discussions 7
Q Micrometers to Measure Coating Thickness - Failed Calibration Flatness & Parallelism General Measurement Device and Calibration Topics 9
I I failed my CQE Exam Professional Certifications and Degrees 21
S Heating Test Failed - Capacitor in secondary exceed its rated temperature IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Marc A NASA Failure Analysis of the April 28 2010 failed balloon launch World News 0
Moncia Traceability System to trace Failed Product for Corrective Action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
Marc Saturn: Why one of Detroit?s brightest hopes failed World News 4
R My C=0 sampling failed to detect parts are out of round Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
S Supplier Development Process failed - Question regarding sub-suppiler audits IATF 16949 - Automotive Quality Systems Standard 4
J Canadian Medical Device License Requirements - What if we failed to meet it? ISO 13485:2016 - Medical Device Quality Management Systems 4
M Readiness Review Failed - Stage one audit for TS16949 IATF 16949 - Automotive Quality Systems Standard 7
Marc Has an Implementation by a Consultant EVER Failed? Consultants and Consulting 62
E Jumpstarting a Failed System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M About companies that have failed a surveillance audit Registrars and Notified Bodies 2
A Employee Support after Failed Promotion - Feelings of rejection, disillusionment, etc Career and Occupation Discussions 1
A Failed Re-Certifications - 9th Cycle Survey posted on the ISO website Registrars and Notified Bodies 2
P Thread plug gauge failed calibration - Must I remeasure everything measured with it? General Measurement Device and Calibration Topics 23
S Failed Calibration - Plain Plug Gages - They grow! General Measurement Device and Calibration Topics 24
S MSA for attribute relation gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
