ILAC Regulations - Expression of Units on the Calibration Certificate
MetroBioCen
Hello
We have been given the task of investigating all matters relating to the ISO 17025 accreditation of ourcalibration laboratory and in conversation with some other colleagues a doubt has arisen.
Is there any ILAC regulation stating that results of measurement on a Calibration Certificate must be expressed SI units?
For instance. The Calibration Certificate of a thermometer graduated on ?C should have the measurements in Kelvin?
Any help regarding this most welcomed
Thank you very much in advance
Best regards
dgriffith
Hello
Best regards
A quick read of ISO 17025 suggests that no such requirement exists for that document. Whether 17025 must be compliant with any ILAC requirements, I don't know. But if it does then by inference ILAC has no requirement either.
I don't have access to any ILAC documents except P14. I don't see it in there, either.
Measurements must be traceable to the SI, but I don't see where the reported calibration units must be SI units.
In fact, the documents speak about units that are not themselves directly traceable to the SI, and how to handle them.
*If you are seeking to create an ISO 17025 accredited lab, then you should buy a copy of 17025 (and study it) and reach out to prospective accrediting bodies and get some advice from them.
dwperron
I looked at the available ILAC documents, and I cannot find any ILAC requirement to report calibration results in SI units.
You should check with your accreditation body, I believe in your case it is the National Accreditation Body of the Republic of Cuba (ONARC), to see if they have any specific requirements regarding reporting results in SI units. Most accreditation bodies have their own rules that you will need to follow above those of 17025 and ILAC.
dgriffith
Wondering if this wouldn't fall under agreed customer requirements. I suppose if they wanted units reported in millstones per fortnight, they could have it. The lab, however, may have to keep a record internally in compliance with accr. requirements.
MetroBioCen
Indeed it is (ONARC), I'm searching for their normatives right now, but up to this moment I have not found anything related with this matter. I keep searching.
Thank you all very much for your answers.
Hershal
Metrologist-Auditor
Short answer is no, ILAC and the Recognized Region for the Western Hemisphere, IAAC, do not require it. It actually goes by economy and/or customer needs. For example, in the US temp can be expressed in either C or F. Uncertainty is sometimes presented in K, but generally even the uncertainty will be the same unit as the main result.
If Cuba uses metric for normal activities in the economy, then you likely will report in metric. Also, if you report only in metric, you don't need to be concerned about conversion calculations, and neither does the customer.
Hope this helps.
H Regarding the validity of EMC & Safety test reports without NABL & ILAC-MRA mark. CE Marking (Conformité Européene) / CB Scheme 2
Sidney Vianna Informational IAF and ILAC Seek Contractor for Establishment of a Single International Organization for Accreditation ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
dinakim_zv CB report or ILAC-MRA report ISO 17025 related Discussions 11
Sidney Vianna Informational IAF and ILAC to merge. A Global Accreditation mammoth? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 1
Hershal ILAC is preparing to start the possible revision to ISO/IEC 17025 ISO 17025 related Discussions 2
4 Understanding ILAC policy P14:12/2010 6.3 part a) General Measurement Device and Calibration Topics 28
S Peer Review using ILAC-G11 as Criteria ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 4
K Any Information on April ILAC 2012 meeting? Measurement Uncertainty (MU) 2
Jerry Eldred New ILAC Requirements Regarding Repeatability - Your thoughts on this please Measurement Uncertainty (MU) 11
DietCokeofEvil ILAC-g8:03/2009 - Reporting Results with Measurement Uncertainty General Measurement Device and Calibration Topics 7
M ILAC p14:12/2010 - Accredited Calibration Certificate Uncertainty General Measurement Device and Calibration Topics 2
Hershal ILAC P14 and its implications General Measurement Device and Calibration Topics 0
Sidney Vianna IAF and ILAC World Accreditation Day ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 0
C BMU=CMC for every Calibration? ILAC Policy Clarification Measurement Uncertainty (MU) 3
Sidney Vianna ILAC & IAF 2009 meeting - 11 days long! ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 3
A ILAC explanation - IEC60601-1 testing certified by an A2LA laboratory IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Hershal Congratulations L-A-B and PJLA - Signatory status - ILAC Resolution GA12.03 General Measurement Device and Calibration Topics 0
Marc Definition ILAC - the International Laboratory Accreditation Cooperation Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
Marc International Laboratory Accreditation Cooperation (ILAC) General Measurement Device and Calibration Topics 0
D Accreditation Scheme:relationships between ANSI, NIST, NCSL, ILAC, APLAC, NCCLS, etc. General Measurement Device and Calibration Topics 3
B FDA regulations medical device prescription fulfillment DME question US Medical Device Regulations 0
G Regulations for research products in Europe EU Medical Device Regulations 0
J Applicable Great Britain regulations for a custom-built test rig or evaluation kit used for research purposes only. Design and Development of Products and Processes 0
E The FDA regulations (21 CFR 312.3): Is it allowable that IND sponsor involves more than one individual or organization? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
A Korean KGMP regulations on facility relocation Other Medical Device Regulations World-Wide 5
G Brazil Regulations RDC 270/2019 Other Medical Device Related Standards 0
G No new regulations in Austria medical device register after 26th Mai, 2022 EU Medical Device Regulations 0
C Is there a list of products or classifications subject to medical device regulations in El Salvador? Other Medical Device Regulations World-Wide 0
B Rework of a medical device EU regulations EU Medical Device Regulations 5
L Single-cell lithium ion battery regulations IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
L Saudi regulations for Japanese non sterile scopes Japan Medical Device Regulations 0
L ANVISA’s RDC 665 replaces previous regulations including RDC 16/2013 and IN 08/2013, and comes into effect on May 2, 2022 Other Medical Device Regulations World-Wide 2
M Seeking mentor/consultant for orthopaedic soft goods regulations Job Openings, Consulting and Employment Opportunities 0
D Regulations covering Sterile product shipments ISO 13485:2016 - Medical Device Quality Management Systems 1
R Medical device regulations in African countries Other Medical Device Regulations World-Wide 1
R Regulations on Controlled Document Size (Paper Size) Document Control Systems, Procedures, Forms and Templates 4
Z Swiss Authorized representative & non-medical device regulations Other Medical Device Regulations World-Wide 0
N How to validate Regulations and Standards? ISO 13485:2016 - Medical Device Quality Management Systems 12
G How to record Regulations and Standards as Design Inputs? Design and Development of Products and Processes 15
L EOL milestone in Medical Devices Regulations 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
dgrainger Informational DRAFT: The Medical Devices (Coronavirus Test Device Approvals) (Amendment) Regulations 2021 UK Medical Device Regulations 1
dgrainger Informational DRAFT: The Medical Devices (Northern Ireland Protocol) Regulations 2021 UK Medical Device Regulations 1
B Regulatory Affairs Certification (RAC) Book - Fundamentals of Medical Device Regulations Medical Device and FDA Regulations and Standards News 0
J In-house (NHS) manufacture and use (by staff) of non-medical devices.. any regulations apply? UK Medical Device Regulations 6
N Competitor not complying with regulations (EU) EU Medical Device Regulations 1
Q Software as a medical device vs software not sold as medical device: local regulations for sale? EU Medical Device Regulations 4
V Regulations renewal IATF 16949 - Automotive Quality Systems Standard 1
J Medical Device Regulations in Lebanon? Other Medical Device Regulations World-Wide 2
M Labelling - Is there a guidance or regulations that specifically defines the 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Draft of New UK Regulations? UK Medical Device Regulations 2
