Illegible Calibration Stickers - Gages used in oily, dirty environment
Looking for some ways to show proof of calibration on gages where the stickers do not stay on and do not remain legible.
M Greenaway
It is acceptable to etch a unique reference code that ties up to a calibration record kept in an office/PC.
Jerry Eldred
I'm not sure exactly what your compliance requirement is (i.e.: ISO17025, etc..). But in general terms, your creativity is one of the main considerations.
I have seen a very wide variety of methods used. I had a lengthy debate with a quality manager (very knowledgable one, by the way) about why we even had to have the labels. This is ONLY my opinion. But theoretically, he convinced me that we truly did not absolutely have to have labels. What we had to have was assurance that measurements are properly traceable (with all implications that entails). So bottom line, you need a method to be sure that people using your gages only use calibrated ones. Or if it is the case that these are gages installed in a system, have a method to assure that people either only read them when they are in calibration, or whatever you intend for the use of the label to be.
One question that could be asked is what you actually use the labels for. If it is a reminder to users to turn them in for cal, you need a method to assure that that happens. What ever the purpose is for the labels, you have to have a good method to assure that function happens.
The most desirable method and the simplest to prove is to put labels on the units. It is possible that you could find some other way to make that happen.
All that philosophical input aside, I am still a proponent of using labels, as it is the easiest to implement. I had a plan in place at a previous position to associate calibration and due dates with a data base so that if a tech attempted to use any test equipment out on the factory floor, he/she would have to enter it through bar code or other means. And the system would not let the tech complete the maintenance with a past due item.
If you decide you are best off with labels, there are two halves to the decision process:
1. Adhesion of the labels. Do a little research into labels with proper adhesives for your application. There are labels with a variety of adhesives available for a variety of challenging environments. You could make labels without use of adhesives - hanging from the unit in a "luggage tag" style enclosure, for example.
2. Writing on the label. If the issue is with the writing coming off, think out of the box as far as methods to write. I recall there being some mil-std contracts in my past where we had to meet mil-std legibility requirements. In some cases we had to etch, others, we had to test out various inks.
Any way, hopefully the above may be of some help to you.
Bill Ryan - 2007
We have, on some jobs, put the stickers on a letter sized piece of paper (or whatever), put some protective sheet over it, and posted the sheet at the site the gages are used.
Just a "simple" idea we have come up with.
Bill
TommyT - 2003
Color coded paint works.........
In some cases, the environment is to harsh for labels to work.
If you have apolicy that defines it, you can use color to indicate OK/NG calibration.
Policy says:
Gages that are subject to environments that will remove or destroy a calibration label, are marked with colored paint to indicate the calibration status.
Master List says:
Yellow - due March, '02
Green - due May, '03
Also, some gages can't have a label.
Policy says:
Some gages, such as pin gages and weights, cannot be painted or labeled without interfering with the gage function or accuracy. In these cases the gage container is labeled.
Good Luck.
TommyT
E Record Legibility and Initials - Signing Records with sometimes Illegible Initials ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
Crimpshrine13 Calibration of pH Meter Probe Calibration and Metrology Software and Hardware 3
F ESD workbench "calibration" Manufacturing and Related Processes 2
F Nist traceable calibration certificates General Measurement Device and Calibration Topics 1
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
T Calibration or Verification -> Cm and Cmk, etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Photovoltaic Tester Calibration General Measurement Device and Calibration Topics 0
B Temperature loop: partial calibration General Measurement Device and Calibration Topics 10
G Glass scale calibration at 74 degrees F? General Measurement Device and Calibration Topics 4
A Digital Timer Calibration Requirements General Measurement Device and Calibration Topics 3
Ron Rompen Barcode Verifier Calibration and Use Calibration and Metrology Software and Hardware 5
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
A Calibration of Power Supplies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D Calibration Process Flow Map Example Wanted General Measurement Device and Calibration Topics 3
M Calibration or Verification? What terminology to use ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
N Calibration Requirements for Production Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
