IMDS - Changing the Locked Weight Value
ABrandon
Long time lurker first time poster.
I am a little new with IMDS still but know enough to be dangerous. Currently I am building my tree with 3 materials. 2 plastic materials and one adhesive tape material.
Here is my layout
Component
>>Component (Plastic Materials)
>>>Material A .855g
>>>Material B .615g
>>Component (Tape) (locked weight of 0.142kg)
>>>Semicomponent
>>>>Material
Overall weight of assembly is supposed to be close to 0.0015kg or 1.5 g when finished.
I am unable to change the weight value of the tape and it is causing a massive deviation. Is there a way to make the 0.142kg only a portion of its weight? I can change the weights of mat a and mat b but not mat c?
Measured weight per item 0.142 kg (cannot change)
Calculated weight per item 0.142 kg (cannot change)
Let me know if you need any clarifications. Thanks in advance.
Kimmy
If you (or someone else) created the tape component then you cannot change it once you have inserted it into your tree. You can however, revise or create a new module of the original tape module and change the weight there. You would then save it with the new weights and insert that one into your tree.
I IMDS Error Message Question RoHS, REACH, ELV, IMDS and Restricted Substances 1
T IMDS submission without supplier's input? RoHS, REACH, ELV, IMDS and Restricted Substances 0
optomist1 Informational Training IMDS - Management of Product Chemical Regulatory Compliance RoHS, REACH, ELV, IMDS and Restricted Substances 2
W Printed Circuit Board - IMDS declaration RoHS, REACH, ELV, IMDS and Restricted Substances 3
R CPM grading by thinkstep vs. IMDS IATF 16949 - Automotive Quality Systems Standard 0
J IMDS submission details for aluminium wrought alloys APQP and PPAP 5
K IMDS Chemistry Manager RoHS, REACH, ELV, IMDS and Restricted Substances 0
J Question: How to create an IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
D IMDS for Like Components (Interior Plastic, Leather/vinyl Armrest, etc.)other than Color APQP and PPAP 1
F How to submit PPAP without IMDS APQP and PPAP 10
R IMDS for double sourced component RoHS, REACH, ELV, IMDS and Restricted Substances 3
J IMDS for Trucks in USA as a requirement RoHS, REACH, ELV, IMDS and Restricted Substances 1
F Mig Welded Components - IMDS International Material Data System RoHS, REACH, ELV, IMDS and Restricted Substances 1
S IMDS=REACH for automotive industry? REACH and RoHS Conversations 3
D I'm new in IMDS special using the IMDS application Manufacturing and Related Processes 8
D IMDS for machining - Can my customer request a IMDS number for a part? APQP and PPAP 2
L How do you send an IMDS instead of propose to a customer? RoHS, REACH, ELV, IMDS and Restricted Substances 2
W IMDS - Help (Common Warning and Error Fixes) RoHS, REACH, ELV, IMDS and Restricted Substances 9
H IMDS for material - Can my Customer create one for my material? RoHS, REACH, ELV, IMDS and Restricted Substances 4
T IMDS - Creating an MDS out of material and a made item? RoHS, REACH, ELV, IMDS and Restricted Substances 4
S IMDS helper app or program or paid service at OEM? RoHS, REACH, ELV, IMDS and Restricted Substances 0
N IMDS Warning Polymer Material Two Substances RoHS, REACH, ELV, IMDS and Restricted Substances 8
O Is it "legit" to create IMDS before Part Production? RoHS, REACH, ELV, IMDS and Restricted Substances 4
J IMDS: How to manage same Raw Material from Two Suppliers? RoHS, REACH, ELV, IMDS and Restricted Substances 2
S Use of Published IMDS Data from our Raw Material Supplier RoHS, REACH, ELV, IMDS and Restricted Substances 6
S Where is a good place to get IMDS (International Material Data System) Training? IATF 16949 - Automotive Quality Systems Standard 3
F Future Plan for IMDS (International Material Data System) RoHS, REACH, ELV, IMDS and Restricted Substances 5
K Entering Assemblies containing Welds into IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 4
B Is CADMIUM allowable in IMDS if it so what is the allowable percentage? RoHS, REACH, ELV, IMDS and Restricted Substances 4
L IMDS for a Part of a Multi-Part Assembly? RoHS, REACH, ELV, IMDS and Restricted Substances 10
R IMDS time frame submission for a very old product APQP and PPAP 1
L IMDS Overcheck Rules RoHS, REACH, ELV, IMDS and Restricted Substances 9
T IMDS - MDS request for parts supplied to multiple customers RoHS, REACH, ELV, IMDS and Restricted Substances 15
T Calculating Plating/Coating Weight for IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
V IMDS Submission for Trim Parts (Non-woven Carpets, Wood, Felts etc) APQP and PPAP 5
Jim Wynne Has Anyone Had Trouble with IMDS 8.0? RoHS, REACH, ELV, IMDS and Restricted Substances 17
T IMDS - What is the difference between propose and send buttons? RoHS, REACH, ELV, IMDS and Restricted Substances 5
S Development of ELV and IMDS in India. RoHS, REACH, ELV, IMDS and Restricted Substances 8
R Is IMDS required for Shipping cap received from our suppliers RoHS, REACH, ELV, IMDS and Restricted Substances 7
T Steel Material Entry into the IMDS system RoHS, REACH, ELV, IMDS and Restricted Substances 5
I IMDS Warning - Chromate Filming of Zinc Plating RoHS, REACH, ELV, IMDS and Restricted Substances 4
P IMDS Classification for Marking Ink RoHS, REACH, ELV, IMDS and Restricted Substances 9
J Is the AIAG IMDS Summit Productive - Worth the time/investment? Career and Occupation Discussions 8
H IMDS which has Development Sample Report Flag RoHS, REACH, ELV, IMDS and Restricted Substances 2
Q IMDS - Clarification needed for Electroplated Parts: Component or Semi-Component? RoHS, REACH, ELV, IMDS and Restricted Substances 17
Stijloor IMDS - Is a Truck Industry Parts Supplier required to register? RoHS, REACH, ELV, IMDS and Restricted Substances 2
A IMDS DIFFICULTY: Our customer requires the Wildcard portion MUST be < 0.1 % RoHS, REACH, ELV, IMDS and Restricted Substances 5
D Using IMDS database with 3rd party Intermediate Trade Company RoHS, REACH, ELV, IMDS and Restricted Substances 2
G Component IMDS for an Electronics Contract Manufacturer RoHS, REACH, ELV, IMDS and Restricted Substances 6
H Need to add a concentrate (only) to an already approved IMDS Submission RoHS, REACH, ELV, IMDS and Restricted Substances 5
