IMDS for double sourced component
Rodo
Hello to all. First, thanks to all of you for making this forum possible. This is my first post as a member, In the past, however, I have come here to learn once in a while. Really, this forum is great.
I have a question on IMDS. I am implementing a double sourcing for a component I use as part of an automotive good.
Since I have two different suppliers I created a second IMDS - Completely new ID - which is approved on the IMDS portal. So now I have an "Old IMDS ID" for my current production, and a "New IMDS ID" for the production using the new sourced component. Customer part number is the same for both conditions.
Normally, a few days after achieving ID approval the "approved ID" reference becomes also visible on the customer quality management portal. This is not happening and I cannot find the reason. The quality guy from the customer side has blocked PPAP due to the lack of IMDS approved on customer portal.
So here are the questions
1.- Is it valid to have two IMDS IDs for a single customer part number?
I received recommendation from my IMDS approver to simply update the old IMDS ID adding the new source. I don't think it is right. In my mind I understand I have to always have an IMDS which is representative from my production.
So, If I have two sources, I believe I should keep two IMDS IDs. Am I wrong?
2.- Have any of you faced this problem before? I suppose it is fairly common to have companies with double material sources...
Any advice?
I hope this is clear. Thanks in advance.
sinned
Registered Visitor
Same issue is happening in my company. And the problem is that our policy allow dual, or even multiple, sourcing of a raw mat'l from different suppliers at the same time. The supply chain can base on price to switch between these supplier without noticing production.
- dennis
Kimmy
So the parts are made from the same raw material but you buy them from different sources? We make springs and will use raw material from a couple of different sources to make the same parts. The material is purchased to an ASTM specification so the chemical composition range is the same regardless of who we buy it from. I only have one IMDS for the parts.
sinned
Registered Visitor
Yes. If the raw material is of standard metal grade to certain international standard like JIS, we can use the MDS published from IMDS committee. However for other materials, different suppliers may report slightly different composition.
R CPM grading by thinkstep vs. IMDS IATF 16949 - Automotive Quality Systems Standard 0
J IMDS submission details for aluminium wrought alloys APQP and PPAP 4
K IMDS Chemistry Manager RoHS, REACH, ELV, IMDS and Restricted Substances 0
J Question: How to create an IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
D IMDS for Like Components (Interior Plastic, Leather/vinyl Armrest, etc.)other than Color APQP and PPAP 1
F How to submit PPAP without IMDS APQP and PPAP 10
J IMDS for Trucks in USA as a requirement RoHS, REACH, ELV, IMDS and Restricted Substances 1
F Mig Welded Components - IMDS International Material Data System RoHS, REACH, ELV, IMDS and Restricted Substances 1
S IMDS=REACH for automotive industry? REACH and RoHS Conversations 2
D I'm new in IMDS special using the IMDS application Manufacturing and Related Processes 8
D IMDS for machining - Can my customer request a IMDS number for a part? APQP and PPAP 2
A IMDS - Changing the Locked Weight Value RoHS, REACH, ELV, IMDS and Restricted Substances 1
L How do you send an IMDS instead of propose to a customer? RoHS, REACH, ELV, IMDS and Restricted Substances 2
W IMDS - Help (Common Warning and Error Fixes) RoHS, REACH, ELV, IMDS and Restricted Substances 8
H IMDS for material - Can my Customer create one for my material? RoHS, REACH, ELV, IMDS and Restricted Substances 4
T IMDS - Creating an MDS out of material and a made item? RoHS, REACH, ELV, IMDS and Restricted Substances 4
S IMDS helper app or program or paid service at OEM? RoHS, REACH, ELV, IMDS and Restricted Substances 0
N IMDS Warning Polymer Material Two Substances RoHS, REACH, ELV, IMDS and Restricted Substances 7
O Is it "legit" to create IMDS before Part Production? RoHS, REACH, ELV, IMDS and Restricted Substances 4
J IMDS: How to manage same Raw Material from Two Suppliers? RoHS, REACH, ELV, IMDS and Restricted Substances 2
S Use of Published IMDS Data from our Raw Material Supplier RoHS, REACH, ELV, IMDS and Restricted Substances 6
S. Moore Where is a good place to get IMDS (International Material Data System) Training? IATF 16949 - Automotive Quality Systems Standard 3
F Future Plan for IMDS (International Material Data System) RoHS, REACH, ELV, IMDS and Restricted Substances 5
K Entering Assemblies containing Welds into IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 4
B Is CADMIUM allowable in IMDS if it so what is the allowable percentage? RoHS, REACH, ELV, IMDS and Restricted Substances 4
L IMDS for a Part of a Multi-Part Assembly? RoHS, REACH, ELV, IMDS and Restricted Substances 10
R IMDS time frame submission for a very old product APQP and PPAP 1
L IMDS Overcheck Rules RoHS, REACH, ELV, IMDS and Restricted Substances 9
T IMDS - MDS request for parts supplied to multiple customers RoHS, REACH, ELV, IMDS and Restricted Substances 15
T Calculating Plating/Coating Weight for IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
V IMDS Submission for Trim Parts (Non-woven Carpets, Wood, Felts etc) APQP and PPAP 4
Jim Wynne Has Anyone Had Trouble with IMDS 8.0? RoHS, REACH, ELV, IMDS and Restricted Substances 17
T IMDS - What is the difference between propose and send buttons? RoHS, REACH, ELV, IMDS and Restricted Substances 5
S Development of ELV and IMDS in India. RoHS, REACH, ELV, IMDS and Restricted Substances 8
R Is IMDS required for Shipping cap received from our suppliers RoHS, REACH, ELV, IMDS and Restricted Substances 7
T Steel Material Entry into the IMDS system RoHS, REACH, ELV, IMDS and Restricted Substances 5
I IMDS Warning - Chromate Filming of Zinc Plating RoHS, REACH, ELV, IMDS and Restricted Substances 4
P IMDS Classification for Marking Ink RoHS, REACH, ELV, IMDS and Restricted Substances 9
J Is the AIAG IMDS Summit Productive - Worth the time/investment? Career and Occupation Discussions 8
H IMDS which has Development Sample Report Flag RoHS, REACH, ELV, IMDS and Restricted Substances 2
Q IMDS - Clarification needed for Electroplated Parts: Component or Semi-Component? RoHS, REACH, ELV, IMDS and Restricted Substances 17
Stijloor IMDS - Is a Truck Industry Parts Supplier required to register? RoHS, REACH, ELV, IMDS and Restricted Substances 2
A IMDS DIFFICULTY: Our customer requires the Wildcard portion MUST be < 0.1 % RoHS, REACH, ELV, IMDS and Restricted Substances 5
D Using IMDS database with 3rd party Intermediate Trade Company RoHS, REACH, ELV, IMDS and Restricted Substances 2
G Component IMDS for an Electronics Contract Manufacturer RoHS, REACH, ELV, IMDS and Restricted Substances 6
H Need to add a concentrate (only) to an already approved IMDS Submission RoHS, REACH, ELV, IMDS and Restricted Substances 4
T Can an Automotive Supplier require an IMDS # for a Non-Automotive part? RoHS, REACH, ELV, IMDS and Restricted Substances 7
G IMDS (International Material Data System) - Is there a minimum weight? RoHS, REACH, ELV, IMDS and Restricted Substances 15
G Newbie in IMDS - Please help me understand what I have to do RoHS, REACH, ELV, IMDS and Restricted Substances 4
T Difference between IMDS, RoHS, REACH-SVHC, Material composition declaration certs. RoHS, REACH, ELV, IMDS and Restricted Substances 13
