IMDS - Help (Common Warning and Error Fixes)
W
webere
All:
I am having some trouble with IMDS, I have submitted information to a User of IMDS, but my submission contain the Warning Below "Different types of nodes (components, semi-components, materials) are used at the same level."
I have been using IMDS for some time and I have seen this warning but this has never stopped a User from accepting the IMDS Submission. I have been trying to read about the warning and fixes for it, but nothing is working. Has anyone ever dealt with this before, and know how to fix it??
W
webere
Yes, I have send an email to the Help Desk. I have received no response as of about an hour ago. I have found on the online, common fixes to Errors and Warnings.
This the fix provided "Go to the component or semi-component in question and add a component or semi-component on the fly and add the rest underneath"
But it doesn't work I have tried to add new components and remove them, but I still have the same warning. As I have said I don't think the reject is valid, but I am trying to find a way to remove the warning.
Kimmy
Did you check IMDS Recommendation 001? It discusses node structure. I have made that mistake before but I always corrected it before I tried to send it.
W
webere
Kimmy,
Thanks, but what is that??? I have seen the recommendation for this. But How does that fix the structure??
Kimmy
Ok. It is tricky, especially when you get into assemblies.
Once you create a component module for your part, you can insert one or more semi component modules OR material modules OR other component modules underneath but you cannot mix them. So you can’t insert a semi component AND a component. You also cannot insert a material module AND another component or semi component.
Let me give you an example of one of our parts, a coiled spring assembly called Spring XYZ.
Spring XYZ assembly consists of a coiled spring made from steel wire which is painted black and then a plastic bushing is inserted into the end of the spring.
I would need the following material modules to start: A material module for the steel wire with the substances that make up the wire underneath, a material module for the paint coating with the substances that are in the paint listed underneath, a material module for the plastic that the bushing is made from with the substances listed underneath.
I create a component module called Bushing xyz and insert the material module for the plastic under it.
I create a Spring xyz module and insert the material module for the music wire AND the material module for the paint underneath that.
Now I assembly my part by creating a Spring XYZ Assembly component module. Under that, I insert the bushing xyz module and the spring xyz module.
Does this help?
I just stumbled across this question in a Google search. I wanted to let y'all know that you can reach out to me with any IMDS questions. I have been doing IMDS for 9 years for companies at all tiers in the supply chain making a variety of parts and assemblies.
The IMDS help desk deals with administrative issues. It is not intended to answer "How do I..." or "What does this mean?" questions.
I am unable to clear the error - very confusing - can you provide step by step "Different types of nodes (components, semi-components, materials) are used at the same level." - helpdesk solution is not a solution for me "Go to the component or semi-component in question and add a component or semi-component on the fly and add the rest underneath" - I have emailed helpdesk several times with no help provided - they just keep sending me the same fixes - how to I clear this type of error? Thank you for your help
Kimmy
Open your submission that you are trying to send to your customer, Under the MDS tab click on "Create MDS report". Once you create it save it and then attach it as a file to this thread. We can take a look at how you have it structured and find the solution.
Does this help?
I am an IMDS newb, and this post from Kimmy is literally the most concise and useful tutorial I have found. I'm sure there is much more to IMDS than just taking supplier info and packing it into your part, but I assume that is all a high percentage of users do with IMDS.....Kimmy, Thank you! I was seriously getting stressed reading the IMDS User Manual and lame tutorial videos.
G Newbie in IMDS - Please help me understand what I have to do RoHS, REACH, ELV, IMDS and Restricted Substances 4
G PPAP 4? + IMDS - Heavy Metals Laws - Help RoHS, REACH, ELV, IMDS and Restricted Substances 3
P IMDS Multiple parts RoHS, REACH, ELV, IMDS and Restricted Substances 1
R Withdraw IMDS submission RoHS, REACH, ELV, IMDS and Restricted Substances 3
C Multiple Part Numbers, IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 2
I IMDS Error Message Question RoHS, REACH, ELV, IMDS and Restricted Substances 5
T IMDS submission without supplier's input? RoHS, REACH, ELV, IMDS and Restricted Substances 5
optomist1 Informational Training IMDS - Management of Product Chemical Regulatory Compliance RoHS, REACH, ELV, IMDS and Restricted Substances 2
W Printed Circuit Board - IMDS declaration RoHS, REACH, ELV, IMDS and Restricted Substances 3
R CPM grading by thinkstep vs. IMDS IATF 16949 - Automotive Quality Systems Standard 0
J IMDS submission details for aluminium wrought alloys APQP and PPAP 5
K IMDS Chemistry Manager RoHS, REACH, ELV, IMDS and Restricted Substances 0
J Question: How to create an IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
D IMDS for Like Components (Interior Plastic, Leather/vinyl Armrest, etc.)other than Color APQP and PPAP 1
F How to submit PPAP without IMDS APQP and PPAP 10
R IMDS for double sourced component RoHS, REACH, ELV, IMDS and Restricted Substances 3
J IMDS for Trucks in USA as a requirement RoHS, REACH, ELV, IMDS and Restricted Substances 1
F Mig Welded Components - IMDS International Material Data System RoHS, REACH, ELV, IMDS and Restricted Substances 1
S IMDS=REACH for automotive industry? REACH and RoHS Conversations 6
D I'm new in IMDS special using the IMDS application Manufacturing and Related Processes 8
D IMDS for machining - Can my customer request a IMDS number for a part? APQP and PPAP 2
A IMDS - Changing the Locked Weight Value RoHS, REACH, ELV, IMDS and Restricted Substances 1
L How do you send an IMDS instead of propose to a customer? RoHS, REACH, ELV, IMDS and Restricted Substances 2
H IMDS for material - Can my Customer create one for my material? RoHS, REACH, ELV, IMDS and Restricted Substances 4
T IMDS - Creating an MDS out of material and a made item? RoHS, REACH, ELV, IMDS and Restricted Substances 4
S IMDS helper app or program or paid service at OEM? RoHS, REACH, ELV, IMDS and Restricted Substances 0
N IMDS Warning Polymer Material Two Substances RoHS, REACH, ELV, IMDS and Restricted Substances 8
O Is it "legit" to create IMDS before Part Production? RoHS, REACH, ELV, IMDS and Restricted Substances 4
J IMDS: How to manage same Raw Material from Two Suppliers? RoHS, REACH, ELV, IMDS and Restricted Substances 2
S Use of Published IMDS Data from our Raw Material Supplier RoHS, REACH, ELV, IMDS and Restricted Substances 6
S Where is a good place to get IMDS (International Material Data System) Training? IATF 16949 - Automotive Quality Systems Standard 3
F Future Plan for IMDS (International Material Data System) RoHS, REACH, ELV, IMDS and Restricted Substances 5
K Entering Assemblies containing Welds into IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 4
B Is CADMIUM allowable in IMDS if it so what is the allowable percentage? RoHS, REACH, ELV, IMDS and Restricted Substances 4
L IMDS for a Part of a Multi-Part Assembly? RoHS, REACH, ELV, IMDS and Restricted Substances 10
R IMDS time frame submission for a very old product APQP and PPAP 1
L IMDS Overcheck Rules RoHS, REACH, ELV, IMDS and Restricted Substances 9
T IMDS - MDS request for parts supplied to multiple customers RoHS, REACH, ELV, IMDS and Restricted Substances 15
T Calculating Plating/Coating Weight for IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
V IMDS Submission for Trim Parts (Non-woven Carpets, Wood, Felts etc) APQP and PPAP 5
Jim Wynne Has Anyone Had Trouble with IMDS 8.0? RoHS, REACH, ELV, IMDS and Restricted Substances 17
T IMDS - What is the difference between propose and send buttons? RoHS, REACH, ELV, IMDS and Restricted Substances 5
S Development of ELV and IMDS in India. RoHS, REACH, ELV, IMDS and Restricted Substances 8
R Is IMDS required for Shipping cap received from our suppliers RoHS, REACH, ELV, IMDS and Restricted Substances 7
T Steel Material Entry into the IMDS system RoHS, REACH, ELV, IMDS and Restricted Substances 5
I IMDS Warning - Chromate Filming of Zinc Plating RoHS, REACH, ELV, IMDS and Restricted Substances 4
P IMDS Classification for Marking Ink RoHS, REACH, ELV, IMDS and Restricted Substances 9
J Is the AIAG IMDS Summit Productive - Worth the time/investment? Career and Occupation Discussions 8
H IMDS which has Development Sample Report Flag RoHS, REACH, ELV, IMDS and Restricted Substances 2
Q IMDS - Clarification needed for Electroplated Parts: Component or Semi-Component? RoHS, REACH, ELV, IMDS and Restricted Substances 17
