IMDS (International Material Data System) - Is there a minimum weight?
G
gio.cs
Hi there,
new to IMDS and to this forum. A new automotive customer asked us for IMDS for our cabling assembly. The weight of the whole cabling is 20g only (microconnectors). Does exists a rule for a minimum weight of an assembly wich permits to not produce IMDS? I ask this because, for a similar cabling, another automotive customer said to us that, for the small weight (20g), we have not to produce an IMDS coding.
Is it right? Or it depends on the final weight of the product?
Thanks in advance
Kales Veggie
People: The Vital Few
Hi there,
Thanks in advance
In general, there is no minimum weight requirement in IMDS. So an IMDS is needed. Small parts (e.g. fasteners) can contain restricted substances (e.g lead or cadmium plating) and must be declared.
If your customer waves the requirement, please keep that as part of your records forever.
Kimmy
We make small springs (most under 10 grams) for primarily the automotive industry and we have never been told that we do not have to report because they don't weigh much. They even reject submissions if I forget to add the minuscule amount of non-hazardous oil coating which is usually under .001 grams per part.
Sturmkind
Hi!
IMDS decimal precision is, I believe, up to 1 millionth of a gram. A recent automotive directive requires the mass reported for the full assembly to be as accurate as possible and should be within 1-2% of the math model mass.
Good luck!
CalRich
I've got a small u-nut that I need to add as a component for an assembly. It is an off the shelf item. When I asked the manufacturer, they said they cannot provide MDS, but offered a material data sheet only.
I was wondering, too, if it is small enough (5g) to exclude it. Not the case.
Don't know how I'm going to address this....
Kales Veggie
There is no minimum weight limit. You have to include it. Below 5g, you do not have to include norms/standards.
What does the material data sheet say? What material? Any plating? What does your drawing specify?
CalRich
Yes, getting the material data sheet from the manufacturer today.
Now, if I've got the material certification from the supplier, can I enter the MDS for this component myself? Even though they seem to supply fasteners, etc. for the automotive industry exclusively, they seem to be IMDS-shy.
Awww.. GM likes to keep us guessing. They haven't yet provided a print for the part we're making or the clip I'm asking about. They just sent an informal email stating to use this GM part number u-nut.
Kales Veggie
Yes, if you have the material composition from the supplier, you can enter that yourself or use the standard materials (published by IMDS, ILI or Stahl und Eisenlist). Second option is preferred.
TPMB4
I'm new to this too but I just find any MDS that matches material grade whether entered by supplier, the committees or others. For example if I buy a processed item in a grade of steel I'll use a likely source of the steel that supplied my supplier or further up the chain. I figure tata steel in my case. A nice circle then, tata steel taking a circular route into a tata vehicle via many middlemen!!
I'm guessing the main deal with imds is an accurate description of everything going into a vehicle. I hope so anyway, otherwise I've messed up.
With weight there's no minimum I've noticed and I've entered it in low grammes many a time. There is a maximum amount of the composition that can be put down as propriety and doesn't need to be defined I think. Could this be used to "cover" any gaps in the composition of a component that can't be identified due to lack of supplier information?
F Mig Welded Components - IMDS International Material Data System RoHS, REACH, ELV, IMDS and Restricted Substances 1
S Where is a good place to get IMDS (International Material Data System) Training? IATF 16949 - Automotive Quality Systems Standard 3
F Future Plan for IMDS (International Material Data System) RoHS, REACH, ELV, IMDS and Restricted Substances 5
G IMDS (International Material Data System) for Heavy Vehicles RoHS, REACH, ELV, IMDS and Restricted Substances 10
S IMDS (International Material Data System) - OEM Requirements RoHS, REACH, ELV, IMDS and Restricted Substances 8
M Career in IMDS (International Material Data System) Career and Occupation Discussions 11
S PPAP and the IMDS (International Material Data System) RoHS, REACH, ELV, IMDS and Restricted Substances 60
J IMDS (International Material Data System) Training needed RoHS, REACH, ELV, IMDS and Restricted Substances 17
C What's IMDS? International Material Data System (automotive) RoHS, REACH, ELV, IMDS and Restricted Substances 11
R International Material Data Systems (IMDS) and ELV-1 - Looking for Info RoHS, REACH, ELV, IMDS and Restricted Substances 53
E How do I enter materials into IMDS (International Material Data Sheet)? RoHS, REACH, ELV, IMDS and Restricted Substances 10
D International Material Data System - IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 6
D End of Life (EOL) Vehicles (ELV) - International Materials Database System (IMDS) RoHS, REACH, ELV, IMDS and Restricted Substances 8
I IMDS Error Message Question RoHS, REACH, ELV, IMDS and Restricted Substances 1
T IMDS submission without supplier's input? RoHS, REACH, ELV, IMDS and Restricted Substances 0
optomist1 Informational Training IMDS - Management of Product Chemical Regulatory Compliance RoHS, REACH, ELV, IMDS and Restricted Substances 2
W Printed Circuit Board - IMDS declaration RoHS, REACH, ELV, IMDS and Restricted Substances 3
R CPM grading by thinkstep vs. IMDS IATF 16949 - Automotive Quality Systems Standard 0
J IMDS submission details for aluminium wrought alloys APQP and PPAP 5
K IMDS Chemistry Manager RoHS, REACH, ELV, IMDS and Restricted Substances 0
J Question: How to create an IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
D IMDS for Like Components (Interior Plastic, Leather/vinyl Armrest, etc.)other than Color APQP and PPAP 1
F How to submit PPAP without IMDS APQP and PPAP 10
R IMDS for double sourced component RoHS, REACH, ELV, IMDS and Restricted Substances 3
J IMDS for Trucks in USA as a requirement RoHS, REACH, ELV, IMDS and Restricted Substances 1
S IMDS=REACH for automotive industry? REACH and RoHS Conversations 3
D I'm new in IMDS special using the IMDS application Manufacturing and Related Processes 8
D IMDS for machining - Can my customer request a IMDS number for a part? APQP and PPAP 2
A IMDS - Changing the Locked Weight Value RoHS, REACH, ELV, IMDS and Restricted Substances 1
L How do you send an IMDS instead of propose to a customer? RoHS, REACH, ELV, IMDS and Restricted Substances 2
W IMDS - Help (Common Warning and Error Fixes) RoHS, REACH, ELV, IMDS and Restricted Substances 9
H IMDS for material - Can my Customer create one for my material? RoHS, REACH, ELV, IMDS and Restricted Substances 4
T IMDS - Creating an MDS out of material and a made item? RoHS, REACH, ELV, IMDS and Restricted Substances 4
S IMDS helper app or program or paid service at OEM? RoHS, REACH, ELV, IMDS and Restricted Substances 0
N IMDS Warning Polymer Material Two Substances RoHS, REACH, ELV, IMDS and Restricted Substances 8
O Is it "legit" to create IMDS before Part Production? RoHS, REACH, ELV, IMDS and Restricted Substances 4
J IMDS: How to manage same Raw Material from Two Suppliers? RoHS, REACH, ELV, IMDS and Restricted Substances 2
S Use of Published IMDS Data from our Raw Material Supplier RoHS, REACH, ELV, IMDS and Restricted Substances 6
K Entering Assemblies containing Welds into IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 4
B Is CADMIUM allowable in IMDS if it so what is the allowable percentage? RoHS, REACH, ELV, IMDS and Restricted Substances 4
L IMDS for a Part of a Multi-Part Assembly? RoHS, REACH, ELV, IMDS and Restricted Substances 10
R IMDS time frame submission for a very old product APQP and PPAP 1
L IMDS Overcheck Rules RoHS, REACH, ELV, IMDS and Restricted Substances 9
T IMDS - MDS request for parts supplied to multiple customers RoHS, REACH, ELV, IMDS and Restricted Substances 15
T Calculating Plating/Coating Weight for IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
V IMDS Submission for Trim Parts (Non-woven Carpets, Wood, Felts etc) APQP and PPAP 5
Jim Wynne Has Anyone Had Trouble with IMDS 8.0? RoHS, REACH, ELV, IMDS and Restricted Substances 17
T IMDS - What is the difference between propose and send buttons? RoHS, REACH, ELV, IMDS and Restricted Substances 5
S Development of ELV and IMDS in India. RoHS, REACH, ELV, IMDS and Restricted Substances 8
R Is IMDS required for Shipping cap received from our suppliers RoHS, REACH, ELV, IMDS and Restricted Substances 7
