IMDS submission without supplier's input?
TPMB4
I've got to submit an MDS to our customer as part of PPAP. The part basically consists of one raw material that we basically cut to size. Simple as anything. However we are struggling to get our supplier to submit an MDS for the raw material or semi component is the technical term for IMDS purposes.
What are the acceptable options if we can't get a supplier MDS? We are tied in with this supplier's material now so we can't simply go to their competitors.
Hello, did you find a solution to your problem?, I'm in a similar situation at the moment with a supplier who is far too slow with answering my requests.
The end customer is not happy at the moment.
optomist1
A Sea of Statistics
Hi TPM48 & M.Schulz,
IMDS is important, and must be complete/accurate, I urge you both to escalate; clearly state the problem and the potential implications of wrong/late IMDS to your management...ASAP...
Hope this helps..
TPMB4
Not sure if this is acceptable but our customer instructed us to create our own MDS for the raw material then use that in the final part MDS. It's not my preference as that seems against the system but we did it and the customer accepted the MDS so we could move on with the PPAP.
I don't know if that helps. In our case the customer was unlikely to question and knock back the solution they instructed us to do. It was a senior buyer or manager too so there was weight behind that instruction that you might not have as cover.
I hope you get a better solution. I'd be very interested what it is if you do.
That thought has crossed my mind too, since its just a small and easy material in my case but then I guess that the responsibility for that material would fall on my company and not the supplier.
There are a boatload of rules put out by the committee to comply in EU
Ultimately the customer you Ppap to and submit the IMDS has ultimate authority
I have had submissions where the recipient company rejected when data was entirely within the rules
I have had submissions where the recipient company accepted when data was not within the rules
ALL I DO IS IMDS
J IMDS submission details for aluminium wrought alloys APQP and PPAP 5
R IMDS time frame submission for a very old product APQP and PPAP 1
V IMDS Submission for Trim Parts (Non-woven Carpets, Wood, Felts etc) APQP and PPAP 5
H Need to add a concentrate (only) to an already approved IMDS Submission RoHS, REACH, ELV, IMDS and Restricted Substances 5
Z 'Duty to Declare' substance - Is submission of IMDS sufficient? RoHS, REACH, ELV, IMDS and Restricted Substances 2
I IMDS Error Message Question RoHS, REACH, ELV, IMDS and Restricted Substances 5
optomist1 Informational Training IMDS - Management of Product Chemical Regulatory Compliance RoHS, REACH, ELV, IMDS and Restricted Substances 2
W Printed Circuit Board - IMDS declaration RoHS, REACH, ELV, IMDS and Restricted Substances 3
R CPM grading by thinkstep vs. IMDS IATF 16949 - Automotive Quality Systems Standard 0
K IMDS Chemistry Manager RoHS, REACH, ELV, IMDS and Restricted Substances 0
J Question: How to create an IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
D IMDS for Like Components (Interior Plastic, Leather/vinyl Armrest, etc.)other than Color APQP and PPAP 1
F How to submit PPAP without IMDS APQP and PPAP 10
R IMDS for double sourced component RoHS, REACH, ELV, IMDS and Restricted Substances 3
J IMDS for Trucks in USA as a requirement RoHS, REACH, ELV, IMDS and Restricted Substances 1
F Mig Welded Components - IMDS International Material Data System RoHS, REACH, ELV, IMDS and Restricted Substances 1
S IMDS=REACH for automotive industry? REACH and RoHS Conversations 6
D I'm new in IMDS special using the IMDS application Manufacturing and Related Processes 8
D IMDS for machining - Can my customer request a IMDS number for a part? APQP and PPAP 2
A IMDS - Changing the Locked Weight Value RoHS, REACH, ELV, IMDS and Restricted Substances 1
L How do you send an IMDS instead of propose to a customer? RoHS, REACH, ELV, IMDS and Restricted Substances 2
W IMDS - Help (Common Warning and Error Fixes) RoHS, REACH, ELV, IMDS and Restricted Substances 9
H IMDS for material - Can my Customer create one for my material? RoHS, REACH, ELV, IMDS and Restricted Substances 4
T IMDS - Creating an MDS out of material and a made item? RoHS, REACH, ELV, IMDS and Restricted Substances 4
S IMDS helper app or program or paid service at OEM? RoHS, REACH, ELV, IMDS and Restricted Substances 0
N IMDS Warning Polymer Material Two Substances RoHS, REACH, ELV, IMDS and Restricted Substances 8
O Is it "legit" to create IMDS before Part Production? RoHS, REACH, ELV, IMDS and Restricted Substances 4
J IMDS: How to manage same Raw Material from Two Suppliers? RoHS, REACH, ELV, IMDS and Restricted Substances 2
S Use of Published IMDS Data from our Raw Material Supplier RoHS, REACH, ELV, IMDS and Restricted Substances 6
S Where is a good place to get IMDS (International Material Data System) Training? IATF 16949 - Automotive Quality Systems Standard 3
F Future Plan for IMDS (International Material Data System) RoHS, REACH, ELV, IMDS and Restricted Substances 5
K Entering Assemblies containing Welds into IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 4
B Is CADMIUM allowable in IMDS if it so what is the allowable percentage? RoHS, REACH, ELV, IMDS and Restricted Substances 4
L IMDS for a Part of a Multi-Part Assembly? RoHS, REACH, ELV, IMDS and Restricted Substances 10
L IMDS Overcheck Rules RoHS, REACH, ELV, IMDS and Restricted Substances 9
T IMDS - MDS request for parts supplied to multiple customers RoHS, REACH, ELV, IMDS and Restricted Substances 15
T Calculating Plating/Coating Weight for IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
Jim Wynne Has Anyone Had Trouble with IMDS 8.0? RoHS, REACH, ELV, IMDS and Restricted Substances 17
T IMDS - What is the difference between propose and send buttons? RoHS, REACH, ELV, IMDS and Restricted Substances 5
S Development of ELV and IMDS in India. RoHS, REACH, ELV, IMDS and Restricted Substances 8
R Is IMDS required for Shipping cap received from our suppliers RoHS, REACH, ELV, IMDS and Restricted Substances 7
T Steel Material Entry into the IMDS system RoHS, REACH, ELV, IMDS and Restricted Substances 5
I IMDS Warning - Chromate Filming of Zinc Plating RoHS, REACH, ELV, IMDS and Restricted Substances 4
P IMDS Classification for Marking Ink RoHS, REACH, ELV, IMDS and Restricted Substances 9
J Is the AIAG IMDS Summit Productive - Worth the time/investment? Career and Occupation Discussions 8
H IMDS which has Development Sample Report Flag RoHS, REACH, ELV, IMDS and Restricted Substances 2
Q IMDS - Clarification needed for Electroplated Parts: Component or Semi-Component? RoHS, REACH, ELV, IMDS and Restricted Substances 17
Stijloor IMDS - Is a Truck Industry Parts Supplier required to register? RoHS, REACH, ELV, IMDS and Restricted Substances 2
A IMDS DIFFICULTY: Our customer requires the Wildcard portion MUST be < 0.1 % RoHS, REACH, ELV, IMDS and Restricted Substances 5
D Using IMDS database with 3rd party Intermediate Trade Company RoHS, REACH, ELV, IMDS and Restricted Substances 2
