Implementation 2013/59/Euratom
Kuldeep Singh
Hello All,
I am not able to find any thread on 2013/59/Euratom , The reference to Directive 2013/59/Euratom (safety standards for protection against ionizing radiation) in GSPR 16.4(a) of EU MDR 2017/745. so i am starting this thread.
The question is , how to show compliance with this directive. Of course this directive is applicable to us, as we are manufacture of X-ray medical devices. There are 109 articles , should we create a table as we do in case of GSPR (Table in which left side contains the Article 1 to 109 requirement and column on right side contains our justification or methods to show compliance against it).
Thanks in advance , your help will be appreciated.
dgrainger
2013/59/Euratom regulates use of ionising radiations and isn't a product regulation. There are some equipment requirements in Articles 60&78 but these are more about use than placing on the market.
Kuldeep Singh
Thank you dgrainger for your reply.
So what i understand is , should we show only compliance to Article 60 & Article 78??
Most of the article seems to applicable on Radioactive materials.
dgrainger
You need to comply with these if you carry out work with ionising radiations in the EU.
The equipment requirements are mostly about what can be used rather than how it is made.
These are also directives so you need to check member state implementation.
In the UK (The Ionising Radiations Regulations 2017), the duties to comply fall on employers to select/use equipment. The exception is reg 32:
Duties of manufacturers etc of articles for use in work with ionising radiation
32.—(1) In the case of articles for use at work, where that work is work with ionising radiation, section 6(1) of the 1974 Act (which imposes general duties on manufacturers etc. as regards articles and substances for use at work) is modified so that any duty imposed on any person by that subsection includes a duty to ensure that any such article is so designed and constructed as to restrict so far as is reasonably practicable the extent to which employees and other persons are or are likely to be exposed to ionising radiation.
(2) Where a person erects or installs an article for use at work, being work with ionising radiation, that person must—
(a) undertake a critical examination of the way in which the article was erected or installed for the purpose of ensuring, in particular, that—
(i) any safety features and warning devices operate correctly; and
(ii) there is sufficient protection for persons from exposure to ionising radiation;
(b) consult with the radiation protection adviser that they appointed, or that the employer engaged in work with ionising radiation appointed, with regard to the nature and extent of any critical examination and the results of that examination; and
(c) provide the employer engaged in work with ionising radiation with adequate information about proper use, testing and maintenance of the article.
If you meet MDD/MDR requirements then you should be ok for part 1. It's part 2 you need to comply with if you install a device.
UK regulator information: Health and Safety: Ionising Radiation
Roland chung
I would also like to know, as an X-ray system manufacturer, how to present evidence of compliance with the Directive 2013/59/Euratom?
Best regards
Roland
Morne
I am struggling with the same request. I am just going to write here, into the void, and maybe someone who is really knowledgeable about this topic will jump in.
Euratom directive is a state-level directive, implementation would be conducted by Ministries, Directorates, etc., and there is nothing much that a manufacturer could prove. IF you were a manufacturer of let's say, radiography products, INSIDE the EU, you would have to register with a national level competent body to approve your work and facilities in the field of ionising radiation emitting products. your registration with this govt. body would prove compliance to Euratom, because the body responsible for your registration/certification implements Euratom directly (as an EU member-state body).
If you are OUTSIDE the EU, it becomes impossible, as far as I can tell, to directly prove compliance. Each individual country would have its own legislation controlling and monitoring radiation emitting activities, and you would be legally required to register with them. The only way for you to definitively prove compliance to Euratom Directive would be to prove beyond doubt that national legislation in your country of operation matches Euratom 1:1. I believe this is really beyond the capabilities of a regulatory compliance person working in isolation...indeed this type of project would usually take a few years when organised by governments themselves, employing teams of lawyers and other experts.
What I explained to one of my clients, who needed to prove this compliance to Euratom was the following:
This client had already purchased and installed a device inside an EU state. As per Euratom, the device was inspected and tested by a medical physicist employed by the health institution, and passed all tests. In this case, the installed, tested device inside the EU state has proven compliance with Euratom quite definitively. While the device in a factory outside the EU, is in a grey zone.
If anyone who has dealt with this before, and did find a way to prove compliance with Euratom while working in a "3rd country", that would be very helpful information.
Could a representative from an EU member state government body responsible for radiation activities come to a 3rd country and conduct an assessment? My understanding is that they do not have the legal jurisdiction to issue anything outside the EU itself...and that even should you "pass" their assessment, they couldn't legally issue you permission/certification...perhaps I am wrong here?
Louisa Ritchlin
Hello All,
Hello Kuldeep Singh, were you ever able to find how to show compliance with this directive? Thanks in advance!
Louisa Ritchlin
Thanks for asking this again, I am looking for the same answer.....
A ISMS implementation - ISO 27001: 2013 Company Objectives IEC 27001 - Information Security Management Systems (ISMS) 1
P Recommended books on ISO 27001:2013 Implementation and Internal Auditing IEC 27001 - Information Security Management Systems (ISMS) 4
V Implementation of QbD based FDA Reviews is set to start from Jan'2013 US Food and Drug Administration (FDA) 1
P MDSAP Implementation Canada Medical Device Regulations 4
D Implementation deadline - non significant change acc. to MDCG 2020-3 EU Medical Device Regulations 3
Sidney Vianna Informational ISO 45002:2023 General guidelines for the implementation of ISO 45001:2018 Occupational Health & Safety Management Standards 1
C ISO Certified Company ERP implementation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
H Regarding confusion of the validity of the European implementation of IEC standards Other Medical Device Related Standards 1
J Implementation, establishment and certification of IATF 16949. IATF 16949 - Automotive Quality Systems Standard 6
J UKCA direct marking implementation UK Medical Device Regulations 0
J0anne QMS Implementation Iran ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
O Quality Management System Implementation framework and Gap analysis checklist Manufacturing and Related Processes 7
Pmarszal BS EN 20417:2021 - Implementation Timeline Aligned With MDR? Other ISO and International Standards and European Regulations 1
L UDI implementation in Saudi Arabi (KSA) Other Medical Device Regulations World-Wide 1
B ISO13485 Risk managment implementation for suppliers ISO 14971 - Medical Device Risk Management 2
P ISO 20400:2017 Sustainable Procurement Implementation Sustainability, Green Initiatives and Ecology 0
R ISO 27001 implementation IEC 27001 - Information Security Management Systems (ISMS) 3
R MEDDEV 2.12-1 rev 8 (Vigilance guidelines) still applicable with the MDR implementation? EU Medical Device Regulations 3
S Implementation of QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Talja SOC2 preparation and trainings for implementation team Other ISO and International Standards and European Regulations 2
SABRINA DJILALI SAIAH Implementation of the ISAS-MEDIA 9001 standard in a TV channel ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S ISO9001:2015 Implementation / update plan template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M ISO14971:2019 - Verification of implementation and effectiveness of risk control ISO 14971 - Medical Device Risk Management 14
S ISO 9001 implementation in a Gold exporting business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Practical Implementation of ISO 14971 ISO 14971 - Medical Device Risk Management 6
G Issues/Roadblocks with APQP implementation APQP and PPAP 10
Dean Bell Implementation of Controls as per SOA for Stage 2 Audit IEC 27001 - Information Security Management Systems (ISMS) 0
O ISO13485 implementation - Are internal audits expected before stage 1 audit? Design and Development of Products and Processes 3
N ERP Software Implementation Manufacturing and Related Processes 3
C New to Site - Request Help with API Q2 Implementation Oil and Gas Industry Standards and Regulations 9
F Will the EU postpone 2017/745 MDR Implementation - COVID-19 Impact Medical Device and FDA Regulations and Standards News 11
J MDD to MDR transition - Time required for the implementation of the MDR EU Medical Device Regulations 7
L AS9146 Implementation and Compliance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Looking for a template SOP for UDI implementation for EU Medical Devices EU Medical Device Regulations 2
G Defining performance metrics for DFMA implementation Design and Development of Products and Processes 2
Cats Clause Design and implementation of process audits as defined within IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
B ISO 9001 Implementation Time Frame ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
M UDI transition period and implementation EU Medical Device Regulations 6
G Strategy for IEC62304 implementation half way into the software development process IEC 62304 - Medical Device Software Life Cycle Processes 9
M Informational EU – EMA revised guidance – Questions & Answers on Implementation of the Medical Devices and In Vitro Diagnostic Medical Devices Regulations ((EU) 201 Medical Device and FDA Regulations and Standards News 2
R ISO 13485 QMS Implementation Training ISO 13485:2016 - Medical Device Quality Management Systems 7
D Preventive Maintenance Implementation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
K China UDI Implementation for October 1st 2019 China Medical Device Regulations 4
R ISO 13485 QMS sequence of implementation ISO 13485:2016 - Medical Device Quality Management Systems 4
M Informational From RAPS – EU MDR/IVDR: US Raises ‘Serious Concerns,’ Urges 3-Year Implementation Delay Medical Device and FDA Regulations and Standards News 3
M Informational TGA – European implementation of Medical Device and IVD Regulations – Implications for Australia Medical Device and FDA Regulations and Standards News 0
M Informational Medtech Europe presentation – – Industry Perspective on the Implementation Status of the MDR/IVDR Medical Device and FDA Regulations and Standards News 0
