Implementation of Certificate of Acceptance/Analysis in place of IQC
L
Lyregi - 2010
Hi all,
Recently, my company is undergoing some cost down initiatives, and 1 aspect identified in the cost down initiative is to reduce the overhead costs incurred from conducting IQC of materials by requesting suppliers to provide COAs.
What I am not too sure here is what are the components to be included in the COAs as there is no detail knowledge on the materials which we are using like die attach paste. Is there any guideline on the components to be included in the COAs?
Note: Company is a SME, with limited manpower.
Thanks in advance of the input to be given. :D
brahmaiah
Hi all,
Please elaborate on your abbreviations;IQC,COA,&SME.Your mail is all greek and latin for a layman.
V.J.Brahmaiah:bonk:
L
Lyregi - 2010
V.J.Brahmaiah:bonk:
so sorry about it since it's my first post.
IQC - Incoming Quality Control
COA - Certificate of Acceptance/Analysis
SME - Small and Medium Enterprise
:D
brahmaiah
Dear mr.lyregi,
Quality inspector is non-value adding person.Most companies are drastically reducing Quality inspectors.Now coming to your problem,you can reduce inspection work in reciept area by introducing the following method:
1.Make it a contract requirement for your supplier to provide;
a)Material test certificates for all raw materials he has used including ferrus,nonferrus,polymers,Chemicals Etc.
b)Dimensional inspection report for all machined components
c)Hardness testing results for heat treated material.
d)Tensile test,Microstructure for castings and forgings.
If you are a TS 16949 company you insist on a ppap for the item supplied.
Without fail carryout strict process audit at your suppliers plant once every six months.
If you follow the above system you may not need inspectors in your reciept area.A purchase engineer can manage quality also.
V.J.Brahmaiah:agree:
L
Lyregi - 2010
Thanks Mr. Brahmaiah for the suggestions.
It seems that this implementation is going to be a painful process as my company is a relatively small player where the major suppliers are big players in the industry. Most of the time, if the proposed system to be implemented is not within their existing operation mode, they will do little to conform to the requirements set out and it won't hurt them much to lose our business. This is 1 of my biggest problem currently. In addition, carrying out site audit is also an issue since there is no pre-allocated budget to do it since most suppliers are in foreign land.
Nevertheless, what you have mentioned is indeed something which is valuable in my consideration process. Thanks alot once again.
brahmaiah
Dear mr.lyregi,
It is true that the system suggested by me is difficult to implement in small companies.Large conpanies are following the system.Because they can dictate terms to their suppliers.
Then is there no solution for small companies?
I think small companies can still maintain quality by doing following things;
1)Select suppliers on the basis of their quality reputation and not on the basis of price.
2)At the stage of assessing a supplier follow strict critaria.
3) If the quality of purchased items are poor, hold the purchaser resposible.This should be the policy of top management.
4)Carry out continuous vendor rating covering each supply and give feed back to suppliers on your findings.
5)It is quite possible that big suppliers donot heed your suggestions.Try convincing them.Keep an eye on alternative possibilities.
6)If your top management cannot bear aditional cost involved, you have to settle for the level of quality that is achievable in the circustances.
7)In such cases you cannot trumpet 'customer delight' in you quality policy.
Well all this is in good spirit!
L
Lyregi - 2010
Thanks for the suggestions. I will take a good look at each of the suggestions and come up with a framework for these changes to take place. Keep my fingers cross that all these will be smooth sailing.
:biglaugh:
SABRINA DJILALI SAIAH Implementation of the ISAS-MEDIA 9001 standard in a TV channel ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S ISO9001:2015 Implementation / update plan template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M ISO14971:2019 - Verification of implementation and effectiveness of risk control ISO 14971 - Medical Device Risk Management 3
S ISO 9001 implementation in a Gold exporting business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Implementation 2013/59/Euratom CE Marking (Conformité Européene) / CB Scheme 4
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Practical Implementation of ISO 14971 ISO 14971 - Medical Device Risk Management 6
G Issues/Roadblocks with APQP implementation APQP and PPAP 7
Dean Bell Implementation of Controls as per SOA for Stage 2 Audit IEC 27001 - Information Security Management Systems (ISMS) 0
O ISO13485 implementation - Are internal audits expected before stage 1 audit? Design and Development of Products and Processes 3
N ERP Software Implementation Manufacturing and Related Processes 3
C New to Site - Request Help with API Q2 Implementation Oil and Gas Industry Standards and Regulations 9
F Will the EU postpone 2017/745 MDR Implementation - COVID-19 Impact Medical Device and FDA Regulations and Standards News 11
J MDD to MDR transition - Time required for the implementation of the MDR EU Medical Device Regulations 7
L AS9146 Implementation and Compliance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J Looking for a template SOP for UDI implementation for EU Medical Devices EU Medical Device Regulations 1
G Defining performance metrics for DFMA implementation Design and Development of Products and Processes 2
C Design and implementation of process audits as defined within IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
B ISO 9001 Implementation Time Frame ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
M UDI transition period and implementation EU Medical Device Regulations 6
G Strategy for IEC62304 implementation half way into the software development process IEC 62304 - Medical Device Software Life Cycle Processes 9
M Informational EU – EMA revised guidance – Questions & Answers on Implementation of the Medical Devices and In Vitro Diagnostic Medical Devices Regulations ((EU) 201 Medical Device and FDA Regulations and Standards News 2
R ISO 13485 QMS Implementation Training ISO 13485:2016 - Medical Device Quality Management Systems 7
D Preventive Maintenance Implementation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
K China UDI Implementation for October 1st 2019 China Medical Device Regulations 4
R ISO 13485 QMS sequence of implementation ISO 13485:2016 - Medical Device Quality Management Systems 4
M Informational From RAPS – EU MDR/IVDR: US Raises ‘Serious Concerns,’ Urges 3-Year Implementation Delay Medical Device and FDA Regulations and Standards News 3
M Informational TGA – European implementation of Medical Device and IVD Regulations – Implications for Australia Medical Device and FDA Regulations and Standards News 0
M Informational Medtech Europe presentation – – Industry Perspective on the Implementation Status of the MDR/IVDR Medical Device and FDA Regulations and Standards News 0
M Informational EU – Employment, Social Policy, Health and Consumer Affairs Council Public session (Health) – AOB – medical devices Implementation of the regulation o Medical Device and FDA Regulations and Standards News 0
M Informational EU – Medical devices: Implementation of Regulation (EU) 2017/745 on medical devices (MDR) – Information from the Irish and German delegations Medical Device and FDA Regulations and Standards News 0
M Informational Medtech Europe – Open letter to the European Commission on the implementation and readiness status of the new Medical Device Regulation (MDR) Medical Device and FDA Regulations and Standards News 0
M Informational Publication of Draft Health Canada Implementation Guidance for the International Medical Device Regulators Forum Table of Contents Format Medical Device and FDA Regulations and Standards News 0
A New Supplier implementation - PPAP vs APQP APQP and PPAP 9
M Startup Company - Implementation of ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 19
D AS9100D implementation question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
L Implementation of ISO 27001 as part of the GDPR compliance journey Other Medical Device Related Standards 2
J Implementation of Total Quality Management/Starting a Quality Department Reliability Analysis - Predictions, Testing and Standards 9
P IATF 16949 implementation needs and requirements IATF 16949 - Automotive Quality Systems Standard 3
A Policies Mandatory or essential for ISO 27001 implementation IEC 27001 - Information Security Management Systems (ISMS) 6
A ISO/IEC 27001 - Issue during implementation of system IEC 27001 - Information Security Management Systems (ISMS) 3
A ISMS implementation - ISO 27001: 2013 Company Objectives IEC 27001 - Information Security Management Systems (ISMS) 1
V ISO 9001:2015 Implementation Packages ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
G IEC 61010 - Single Fault Condition - Protective Impedance Implementation IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A EMS - ISO 14001:2015 Implementation ISO 14001:2015 Specific Discussions 4
a_bardi ISO 9001:2015 - Implementation in 4 Plants Different Countries ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A CAQ Software - Implementation of a Software for FMEA's and Control Plans FMEA and Control Plans 0
M Partial Implementation of ISO 9001 in a Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
