Implementing ISO 9001 for a small fabrication company
StuartM38
Hello All,
I am looking for a step in the right direction and a heads up where to start.
I ave just been employed as a small steel fabrication company to implement and get them ready for ISO 9001. I am an Internal Auditor and have been a QA coordinator for the past three years, for a subsea company with both iso9001 and 29001 and I have 8 months to go before I complete my CQI course in Quality Management.
They do not have anything in place as such and all designs are made from customer owned engineering drawings, so do all requirements of section 7 apply.
They are all on board with what is required and I will have the support and any resources made available to me, costs not a problem.
I know that I have to look at their processes and procedures but which ones do I tackle first?
I am thinking I will need between 10-15 procedures to cover everything? Is this too many or not enough?
This is a step up from what I do so don't really want to muck it up.
AndyN
Moved On
Hello All,
Well, you start with not doing it yourself! It will become "your" system and everyone will avoid it, pretty much, when it comes time to do anything or fix something when it's audited.
Get the management team together and map the entire process of taking work in (from quoting) to delivery. Do not fall into the trap of thinking about "numbers of procedures/processes" - that's also a mistake. Gather up anything they use as part of practice today, so that you can "fit" them to the process as you map it out. Keep a running list of issues that each person tells you they have problems with, as you go through each process, end to end. When you have the whole thing mapped out, warts and all - no changing it because people are embarrassed by the problems - then you can help them document additional controls which may be decided are necessary, get them under doc control etc.
Billy M
Andy is correct in stating that don't do it all yourself. You have to get participation by everyone. I like to take each section of the standard and determine someone that is the section owner for that section and they will be responsible for the activities in that section. Some of those will be you, but others would be purchasing, manufacturing, engineering, etc.
If you are working on ISO/TS 29901 be aware of the control features that API requires. There are only 6 procedural requirements within ISO 9001 but API requires control features on 16 other items, so consider this with your documentation. I like to do Flowcharts for those items.
Andy was also correct in stating to get everyone together and determine the processes needed and document that way. It should be a total team involvement effort. Too many times the Quality Manager or person responsible for implementing the system gets stuck with the task of doing everything.
Big Jim
I completely agree on getting everyone on board from the start. It is my belief that ISO 9001 fosters a participative management style. Things go much smoother when everyone is working together.
On flow charting, my advice is to not go overboard. You don't need to define everything down to the minutia. A consultant that went into a shop before me told the shop owner that the first thing they needed to do was to flow chart the entire operation to the extent that anyone from the outside could step into any roll and function from the flow chart. Four months later they had generated several pages of flow charts, but had not progressed to the consultants satisfaction to where they could define their processes. This was for a 15 person company.
As a consultant, I usually can get a client through the determining of the core processes and a simple interaction chart in less than two hours. Those with less experience and less exposure to many organizations may take more time, but it needn't be an all day affair.
Even if your were able to get to that ideal state of flow charting to the point that someone from the outside could step in and function, it would not stay that way for very long, because things change.
Also, your documentation needs to provide some flexibility so that it need not be revised at the drop of a hat.
KISS (keep it simple)
G ISO 9001 - when implementing customer requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
G Heavy Civil Construction Company Implementing ISO 9001:2015 for Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q Easy Way of "Implementing" Risk in ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
L Implementing ISO 9001 in small Trading Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
F Implementing ISO 9001:2008 in a new Food Processing company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Implementing ISO 9001 in an Assembly Plant ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Implementing ISO 9001 and ISO 22000 systems at the same time Document Control Systems, Procedures, Forms and Templates 2
C Implementing ISO 9001 - Getting whole team buy-in? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
M ISO 9001 - Implementing 7.3.2 - 7.3.7 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C Starting a Quality Department from Scratch and Implementing ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
S Implementing ISO 9001 and ISO 17025 separately or together ISO 17025 related Discussions 6
C Implementing ISO 9001:2008 in a small Sales and Service company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
L Implementing ISO 9001: 2008 in a Dietary Supplement Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T Implementing ISO 9001 in a Home Business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
L Implementing ISO 13485 with an ISO 9001:2008 QMS ISO 13485:2016 - Medical Device Quality Management Systems 3
G Implementing Dual Standards in a Company - ISO 9001 & AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
H Implementing ISO 14001 versus Implementing ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C Suggestion for Implementing ISO 9001 in a Start-Up Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
S Implementing ISO 9001 at our company for the first time ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R Quality Manager Training Methods - Learning and Implementing ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
B Understanding and Implementing ISO 9001 in a Small Manufacturing Business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Implementing ISO 9001 - One Department at a Time - Internal Provision Only ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
Z ISO 9001 Implementing Performance in all Countries of the World ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Implementing ISO 9001:2008 - Had a New Center Merged with Our Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Lost Cause for Understanding and Implementing ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
E Implementing ISO 9001 and an Example of a Quality Manual anyone? Document Control Systems, Procedures, Forms and Templates 6
A The Journey, the Audits, my Experience - Implementing ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B Need Assistance for Implementing ISO 9001 in our organisation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
G Requirements for Implementing an ISO 9001:2008 Quality Management System (QMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
M Implementing ISO 9001 in a Training Center ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T Implementing ISO 9001 in an Architectural Practice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Structure for Implementing ISO 9001 - Detailed action plan of the significant steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Where and What Template to Purchase for implementing ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
Q How to find definitions from ISO 9001 when implementing ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 8
S Implementing ISO 9001:2008 - Where to Start? Document Control Systems, Procedures, Forms and Templates 15
Marc Implementing ISO 9001 in a Business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
K Implementing ISO 9001 - I need it all! Please tell me the bare bones! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
T Training & Induction Records - Implementing ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
L Implementing ISO 9001 in a Startup Business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
K Culture Shock and Things Need to Change - Implementing ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
K Template for preparing Consultant's Proposal for Implementing ISO 9001:2000 Consultants and Consulting 29
A How has your Organization Benefited from Implementing ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
D Are we going through the right steps while implementing ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Implementing ISO 9001 in a school (Education) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
N Practically implementing ISO 9001:2000 Clause 7.2.2 Contract Review Contract Review Process 10
J Reasons for Implementing ISO 9001 - Findings from a Survey of 326 Businesses The Reading Room 0
L Implementing ISO 9001 - Document every clause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S How do I get started implementing ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
D Implementing ISO 9001:2000 in a Restaurant ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 54
