Implementing Paperless for small IT Staffing Firm <10 Employees
Chase Wheeler
Hello all, I just found this board today and thank god. :bonk: I am fresh out of college and have an IT/Process background. I was hired by a small IT staffing firm in the Bay Area to help begin an ISO 9001:2008 implementation until I start my full time job. Currently I am trying to implement a completely paperless system through an excel dashboard. We have very few employees so the system cannot be a document time suck. My questions are these:
1. I am trying to have the dashboard be an all in one do it all document including electronic approvals. Should I just password protect the "Approved" cells so only management can type in them?
2. We use a hosted DB system called Bullhorn (BH) to store data on Candidates, Clients, Client Jobs, and Placements (a candidate placed on an open client job/engagement) as well as for email, and I was wondering if I could leverage this for our product realization records.
3. I use 824 Monitoring and Measuring, as our product realization procedure, but am confused as how to measure our process. Basically I have records implemented in our DB system that say candidates were interviewed, rated, matched to a client job, placed, and approved, but have no way of measuring our placement process, b/c it is subjective based on how well our recruiters do their job/their opinion of candidates after they've been interviewed and added to the system.
4. For my client feedback procedure I am simply asking the clients if they would hire the candidate again and if no, why not. Is this enough?
Attached is my dashboard along with my process flow.
View attachment F-423-001 QMS Master Dashboard.xls
Thanx in advance for any help provided, this forum is a godsend. :tg:
Pancho
wikineer
Hi, Chase, welcome to The Cove! :bigwave:
Currently I am trying to implement a completely paperless system through an excel dashboard... Attached is my dashboard along with my process flow.
You've obviously put quite a bit of effort into it.
If only management is authorized to approve procedures, then by all means. Who can do this should be spelled out in your P-P-423 Document Control procedure (which you get to write).
I'm not sure what you mean by your "product realization records". But, again, you get to write what is appropriate for your organization. If the database keeps the information you need in order to determine that the work was done in conformance with your own procedures and your client's requirements, then yes, you can leverage it for your "product realization records".
The designation "824 Monitoring and Measuring" is not from ISO 9001. What do you need this procedure for? Or, in other words, What are you trying to measure and why?
I looked for your Quality Policy and Quality Objectives in your Dashboard, but didn't find them. Write these docs first. They will help you decide what you want to measure. And whatever it is that you measure, make sure it is useful.
Here is a comprehensive list of "Key Performance Indicators". Pick what helps your company deliver quality.
I think their opinion about the candidate is helpful, but only one incidental characteristic of your service. How about asking them (1) Will you hire our company again? (2) Did you feel you got your money's worth? (3) Would you recommend our company to others?. You could also ask about speed, quantity of potential candidates, match between candidate and position, etc.
:topic:
You may consider using a wiki instead of the Excel dashboard. With a wiki, each of your excel sheets can become a wiki page, but you only need one bit of data for each entry. This bit of data is the title of the document, which, by enclosing it in brackets, also becomes the link to the document itself. All versioning and authoring gets done automatically. The time you spend learning to use the wiki you will save many times over in the first few changes to the documentation.
Good Luck!
Pancho
Chase Wheeler
Hey Pancho,
Thanks for all the great tips. :thanks:
-824 Monitoring & Measuring refers to clauses 8.2.3-8.2.4 I've titled the procedure 8.2.4 Monitoring & Measuring of Product Realization, sorry for the confusion. I've used my procedure for these two clauses as the one that details how we produce our product, that is, the steps we perform to find a candidate, screen, match them to a job, vett them, then place them on a client engagement. I chose these clauses, because our product realization process, is essentially one big monitoring and measurement of candidates to make sure they have the prerequisite experience and skills required for the client engagement. Do you think I should switch the product realization process to clause 7.5.1-7.5.2?
-Also how well candidates meet the job requirements provided by the client is up to the opinion of our relevant recruiter, thus I am unsure as how to measure this process. Any tips?
-I have a quality manual thats still pretty rough, so I didn't include it, but it's getting there.
-In terms of quality objectives and the list of KPI's you posted (which are great by the way), do I need to relate my KPI's to specific procedures?
-I like your customer feedback ideas, but I'm curious as to we should record the process. Would an email trail suffice? Also, what would be the best way to metric and analyze the feedback during management review meetings?
Thanks again for the help.
-Chase
Pancho
wikineer
Hi again, Chase,
Oh, I see where the number came from. Thanks for the clarification.
I think controlling the conditions of production (7.5.1) is quite different from the monitoring and measurement of the product or service (8.2.4). The first enables your staff to do their work, while the second provides evidence that they did. You should address them both.
Maybe you can create a checklist of client requirements in the planning stage (when you get an order), then compare against that checklist the candidates that you submit? That'd be much more objective than relying on your recruiter's post-fact opinion. I'd imagine many of the client requirements are analogous from one assignment to the next, so your checklist customization at time of assignment, if any, could be simple.
I don't think so. But your KPIs should be related to your Quality Objectives and should be measurable against your goals and prior achievements.
I'd advise against relying on individuals' email boxes to keep your records, but other than that, printed or properly archived and backed-up emails are as good a record as any.
One idea for feedback tallying: Ask customer satisfaction questions in a list of independent, positive affirmations (i.e. "The service was timely.") with seven boxes to the right of each. The boxes are labeled from "Strongly Agree" at the left through "Neither Agree nor Disagree" at the center, and to "Strongly Disagree" on the right. Then assign a value of 0 to "Strongly Disagree" and 7 to Strongly Agree. You can then present the data in bars, lines, averages, or whatever you like.
Hope this helps!
Pancho
Chase Wheeler
Once again thank you for all your help. Instead of a checklist we work with the client to develop job descriptions and then make sure that our candidates meet the requirements outlined in this document. Unique job descriptions are made for each new client job we receive. Would this suffice or would we need something more formal?
Chase Wheeler
Also our database system stores both the job descriptions and resumes of all candidates.
Pancho
wikineer
If you have a way of demonstrating that you met your clients requirements, then it suffices.
Chase Wheeler
Hey Pancho,
It's up to our clients to hire a candidate, so if an offer is extended to the candidate we submitted, that would demonstrate we met the client's requirements. Basically a client won't hire one of our candidates unless they like them. Would that work or do I need something more?
Pancho
wikineer
Chase,
Whether such record is sufficient is entirely up to you and your management. Record your client's actions consistently and that may be all that you need to start off. As you use the system you will discover ways to improve it -- that's one way you will know its working.
Good luck!
Pancho
R Implementing a Paperless Documentation, Forms and Records System Records and Data - Quality, Legal and Other Evidence 6
H Implementing ISO14001:2015 ISO 14001:2015 Specific Discussions 4
A Small Company Implementing ISO 13485 Timeline/Process/Steps Advice ISO 13485:2016 - Medical Device Quality Management Systems 5
E Theoretical project: Implementing ISO 13485:2016 into a start up acrylic bone cement manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 4
G ISO 9001 - when implementing customer requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K Is implementing Electronic Signatures a Significant Change to the QMS? ISO 13485:2016 - Medical Device Quality Management Systems 10
Moncia Implementing ISO 50001 Sustainability, Green Initiatives and Ecology 21
H Implementing ISO22301 on a Limited Scope Business Continuity & Resiliency Planning (BCRP) 2
J Implementing an ISO 13485 QMS Software ISO 13485:2016 - Medical Device Quality Management Systems 11
Sravan Manchikanti How to interpret '8.3 Control of nonconforming product' for SaMD device while implementing ISO 13485 & MDSAP ISO 13485:2016 - Medical Device Quality Management Systems 7
L Implementing the PRRC role in a company EU Medical Device Regulations 8
A Implementing ISO 20000-1 - Where to start Other ISO and International Standards and European Regulations 4
B Lessons Learned Implementing ISO 50001 (Chemical Engineering Progress) Other ISO and International Standards and European Regulations 0
C How medical device manufacturers are implementing standards like GDPR and HIPAA Other ISO and International Standards and European Regulations 5
M Informational EU – Commission Implementing Decision (EU) as regards the designation of expert panels in the field of medical devices Medical Device and FDA Regulations and Standards News 0
R Implementing Design History Documents/ Technical Documents in the QMS ISO 13485:2016 - Medical Device Quality Management Systems 3
tnorton Lessons learned from implementing Customer Complaints Customer Complaints 1
M Informational Update – MDR and IVDR implementing measures rolling plan – 2 more NBs designated under the new regulations Medical Device and FDA Regulations and Standards News 0
S Implementing a 45001 Health & Safety standard - Internal audit plan wanted Internal Auditing 1
M Informational Commission Implementing Decision (EU) 2019/939 of 6 June 2019 designating issuing entities designated to operate a system for the assignment of Unique Medical Device and FDA Regulations and Standards News 0
J Implementing Machine Replacement Part Reverse engineering technology Manufacturing and Related Processes 4
Q Does anyone have experience implementing a QMS without ISO certification? Quality Manager and Management Related Issues 2
M Informational EU – April 2019 update of the MDR and IVDR implementing measures rolling plan Medical Device and FDA Regulations and Standards News 0
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
M Medical Device News Last update of the MDR and IVDR implementing measures rolling plan – December 2018 Medical Device and FDA Regulations and Standards News 0
J Implementing EN 62304:2006 on existing and proven medical devices IEC 62304 - Medical Device Software Life Cycle Processes 6
M Medical Device News MDR and IVDR implementing measures rolling plan EU Medical Device Regulations 0
B Implementing an Escalation Process and Andon system Supplier Quality Assurance and other Supplier Issues 1
K EQMS question - Implementing an electronic QMS to support ISO 13485:2016 Quality Assurance and Compliance Software Tools and Solutions 4
Talja Is there any requirement to be compliant with IEC 62304 while implementing ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 5
armani Compliance Obligations - Implementing 6.1.1 and 6.1.3 NOTE - Determine risks and... ISO 14001:2015 Specific Discussions 1
G Heavy Civil Construction Company Implementing ISO 9001:2015 for Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
K Implementing ISO13485:2016 in the Middle of a New Device Project ISO 13485:2016 - Medical Device Quality Management Systems 1
D Implementing 5S for Multiple Shop Floor Layout Workstations Lean in Manufacturing and Service Industries 2
N FDA Guidelines for implementing Continuous Improvement Process US Food and Drug Administration (FDA) 5
Q Easy Way of "Implementing" Risk in ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N Implementing ISO 17025 in a Calibration Laboratory ISO 17025 related Discussions 8
E Does anyone have experience implementing a Tiered QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Implementing an AS9100 Aerospace Quality System AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
L Implementing ISO 9001 in small Trading Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
C Implementing a set of bore gages at a machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Implementing Risk Management in a Medical Device "Distributor Only" company ISO 13485:2016 - Medical Device Quality Management Systems 6
T Implementing a Suspect Counterfeit Identification Program Quality Manager and Management Related Issues 3
O Implementing Lean Intranet Sharepoint Lean in Manufacturing and Service Industries 6
F Implementing ISO 9001:2008 in a new Food Processing company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J ISO 22301 - Implementing a Business Continuity Management System Business Continuity & Resiliency Planning (BCRP) 15
M Does anyone here have experience implementing PCI DSS (Data Security Standard) IEC 27001 - Information Security Management Systems (ISMS) 10
L Implementing a new quality management system for a new engineering company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Implementing ISO 9001 in an Assembly Plant ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D Understanding and implementing ISO 17025 ISO 17025 related Discussions 9
