Since ISO 9001 is so big on processes, should a repair procedure be specified so the same procedure is used in each case of rework?
I am a pretty new Quality Manager and I work for a company that makes fiberglass reinforced pipe, we had a procedure in place that specifically dictated how to do rework for each defect type. The process engineer went out of spec and backed a repair technique that doesn't match our documented rework procedure.
I have no problem with the new procedure, but I asked him to amend the specification to reflect his new way of of reworking defects. He basically refused, left the documented repair procedure the same, and added to the specification, "If a different method of repair is to be used, Process Engineering should be consulted for approval". So we have a procedure that tells how to make the rework, implying that this is the way the repair is to be done, but a caveat in there that basically they can do it however he pleases.
I'm interested in the take on this from the standpoint of Quality Managers and engineers alike.
