Importing a DC motor to UK that is less than 50VDC
sakatoony
Hi
Need a quick response please from forum experts.
I am importing some BLDC motors from China to UK. They have been tested and test data is available by the manufacturer. However i am not sure what else the manufacturer needs to supply (documentation, certification) to make the product compliant. Hope i have made sense.
Before i ask the manufacturer i need to know what paperwork i should ask them to supply.
Motor is to be used as part of an electromechanical assembly, runs on 24Volts.
Added info. Requirement spec was provided from uk and it was custom made in china. don't know if it means anything but thought i'd add it anyway
sakatoony
The manufacturer does have iso9001 compliance certificate. does thismean all their manufacturing processes comply with EU standards?
sakatoony
Thank you for your reply.
Its a motor so comes under Machinery (correct me if i'm wrong).
But EMC, LVD directive doesn't apply to it (less than 75Volts DC).
Is conformity assessment is needed?
The main problem for me is having to categorise this motor.
2nd point which i mentioned. The manufacturer conforms to ISO 9001. does that mean all products coming out of the factory comply with CE?
If so what documents should normally accompany this motor (construction file, CE certificate, etc etc????) Thanks
Ronen E
Problem Solver
Moderator
sakatoony
Thanks for the directive Ronen
Quick glance and things are a bit clearer now.
The motor can be classed as a component as it cannot serve any purpose on its own. So no CE certification is necessary. The manufacturer was adamant this was the case it it may well be true. However manufacturer needs to prove compliance with ROHS otherwise i have heard horrible stories of customs impounting stuff uk-bound from China that simply gets destroyed.
Not necessarily.
Why do you say that. Wouldnt it mean that they no longer comply with Iso 9001? I donot see why a manufacturer would risk that. Also dont these certifications need to be audited or reviewed periodically?
Ronen E
Problem Solver
Moderator
I understand that you probably don't have the resources to overnight become an expert on all EC & UK regulatory and/or customs requirements, but on the other hand it's not a simple matter. The right way to go is to search for and review all applicable legislative instruments (a pain, I know) and make sure you comply with them all to the letter, or at least to a very good extent. Of course, it helps if one is already knowledgeable in the subject field. I'm not an expert on general use DC motors; I come from the medical devices field, with a basic good understanding of CE marking principles in general. The machinery directive was just an illustration; I didn't search for other applicable instruments so I can't tell you whether or not you should pay attention to any other such instrument. Please note that I gladly volunteer my time here; in the "real" world, when I take on a job such as this I can properly study all relevant details and the legislation, and come out with a responsible answer, "do this and that and you'll be fine".
In general you could go in 2 ways: The first is what I described so far. The second is relying on your supplier's word and sporadic info you can get from other people in the field, and seeing how you go through customs. Then you could sort out the missing pieces (if any) with your supplier.
Regarding ISO 9001 -
There may be more to meeting the EC regulation than compliance with ISO 9001. Your supplier may have valid certificates (yes, they're up for periodic audit and renewal) and be in actual full compliance, and yet miss on some other requirement(s).
Cheers,
Ronen.
sakatoony
I appreciate your input on this Ronen and Thank you for that.
I have basic understanding of engingineering principles but don't know much about regulation compliance thats why i came here :D
To search for every legislation and check for compliance i donot think someone with my knowledge can safely do that, compounded by the fact that the wording in these legislations can be vague at best of times.
What i do know is that this motor is unlikely to present higher level of danger in its operation mode due motors size and capacity so a lot of the regs are not applicable (eg BSEN, 294, 349,418,574, etc etc).
It wont be operating at dangerous temperatures either so now.
Probably beginning to sound like a broken record but as the operating volts doesn't reach 75Volts DC none of the EMC directives apply.
These factor are inclining me to believe what the manufacturer is telling me.
What does worry me that there is a website i came across that lists all of the chinese products that were picked up by border customs that didn't meet safety requirements. All items that cannot be proven safe and worthy of consumer utilisation gets destroyed.
I plan to import a good few hundred of these and cannot afford such risks. but if one was to end up in a situation like that how could they prove compliance to Regs and legislation. will they take my word like i said above that none of these regs apply? will i need to prove its ROHS compliant?
D Importing a general wellness low risk product Other US Medical Device Regulations 3
I Importing prototype without CE (dos and don'ts ) EU Medical Device Regulations 11
S Importing Medical devices class I in EU Other Medical Device and Orthopedic Related Topics 5
O Importing a Medical Device into the US from abroad 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
M Importing a Registered Class II Device, the Applying Our Label - Need New 510(k)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
F Mexico Medical Device Importing and Servicing Other Medical Device Regulations World-Wide 2
ScottK Importing medical device for use in fit testing of packaging Other US Medical Device Regulations 3
M Importing medical devices to EU, Germany EU Medical Device Regulations 6
M Importing a Demo Medical Device into the US US Food and Drug Administration (FDA) 3
J Requirements for Importing Research Use Only Medical Devices into Japan Japan Medical Device Regulations 1
J Importing a Finished Medical Device from China (tooth whitener w/ peroxide) China Medical Device Regulations 2
O Importing Data via Script - Assign Column as Text (Minitab) Using Minitab Software 3
W What Information is provided when Importing Products into USA US Food and Drug Administration (FDA) 1
T Importing Non-Electromedical Device (PACS Software) into South Africa Other Medical Device Regulations World-Wide 2
P Requirements for Importing Hydrocolloid Bandages into the US from China Other US Medical Device Regulations 2
Q FDA Registration and Importing Medical Device Components 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M South Korea Importing Rules for Privately Labeled Medical Devices Advice wanted Other Medical Device Regulations World-Wide 5
N Importing Diagnostic kit from US, UK Other Medical Device Regulations World-Wide 5
B Class I Medical Device Importing for OEM Requirements EU Medical Device Regulations 3
A Importing Sample Medical Devices into South Korea ISO 13485:2016 - Medical Device Quality Management Systems 2
M Importing Material before the 510(k) is Approved 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M Importing CE marked Syringes Into the US Other US Medical Device Regulations 2
I Importing Medical Devices into the USA from Germany (Drop Shipments) US Food and Drug Administration (FDA) 2
D Importing Class II Male Latex Condoms From China to US Other US Medical Device Regulations 2
L Importing exempt Class I device from non-registered manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R Importing Breathalyzers into the USA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Stijloor Importing Address Books (Thunderbird and Outlook Express) into Windows Live Mail After Work and Weekend Discussion Topics 3
G Importing Medical Device Software to India - Diagnostic Imaging Application Other Medical Device Regulations World-Wide 8
L Importing CSV (comma separated values) / Excel process steps into Visio diagram Excel .xls Spreadsheet Templates and Tools 2
S Exporting then re-Importing 510(k) device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S Regulations for importing an IVD diagnostic test in India Other Medical Device Regulations World-Wide 16
bio_subbu CDSCO?s checklist on importing non-critical IVD products in India Other Medical Device Regulations World-Wide 1
amjadrana Importing Medical Devices with Computers as part of the device in Turkey Other ISO and International Standards and European Regulations 1
D Medical Device Regulations - Importing to Singapore - Orthodontic brackets Other Medical Device Regulations World-Wide 5
D How to obtain NOC from DCGI (Drug Controller General of India) for importing drugs Manufacturing and Related Processes 6
G Portocal II - Importing procedures Calibration and Metrology Software and Hardware 2
H Regulation in Australia - Importing medical device (class IIa as per MDD 93/42/EEC) ISO 13485:2016 - Medical Device Quality Management Systems 3
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
A PFMEA for DC Motor FMEA and Control Plans 5
K MSA for Torque Dynamometer in Stepping Motor Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Ford Motor Company new CSR document - May 2014 Customer and Company Specific Requirements 1
A Implementing a Grease Analysis Program for a Pulley Sheave and Motor Bearings Preventive Action and Continuous Improvement 2
S Ford Motor Engineering Change Level definition Customer and Company Specific Requirements 6
S Common Electric Fan Motor Problems Reliability Analysis - Predictions, Testing and Standards 3
S Root Cause Analysis of Motor Performance Failure Manufacturing and Related Processes 5
R Single Fault Condition - Motor Test IEC 60601 - Medical Electrical Equipment Safety Standards Series 17
S Motor Stall Torque Failure after Changing Supply of Cyclindrical Gears Manufacturing and Related Processes 1
V PPAPing an end of line Motor Tester APQP and PPAP 2
6 Engineering Controls for a Noisy Motor Manufacturing and Related Processes 9
somashekar Information sharing: Week 24, 2010 (INDUCTION MOTOR) The Reading Room 0
