In a Print Shop the Products are Special Processes?
N
Northwoods
#11
QAMTY,
Are you applying the glue to the printed stock or are your purchasing label stock with glue adhered to it? already The glue (if you are applying) or label stocks have technical specifications sheets you can look up on-line or you can get it from the mill/paper merchants. This is their guarantees, chemical makeup, longevity specs and may answer some of your other questions.
Another thought- Test the Label. Apply the actual label to something and test it internally. You need to know what the label is being applied to (glossy/dull/varnish/ laminate/plastic/metal)If you do not know ASK the customer!! That is a big deal since longevity surface adherence is the source of how long the label will last. Sometimes customer will lend you the product you are adhering to so you can test it.
I have a feeling you are working with a large volume print run and you need assurance it will work. Testing label on actual surface of end product gives sound confidence it will work.
Some testing suggestions for glue & ink on label stock:
- Will product/label be in extreme hot/cold climates = longevity of stock/ink
- Product finish, label is being adhered to (Plastic/Vinyl can have petroleum in it)
- How long glue will lasts = How long product/paper will be around (shelf life)
- Durability - will be handled/touched a lot = fingerprinting/oil
- Will label be exposed to shipping (USPS/UPS) = Labels take a beating if they are on outside of box etc.
Let me know if I am close to what you are looking for. I think this will at least let you think of what angle to come in at for testing.
qualprod Automation in manufacturing - Print Shop ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
qualprod Criteria for print shop - How do you consider the cycle time in a print shop? Lean in Manufacturing and Service Industries 21
Q KPI's (key performance indicators) for a Print shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Changes to a Tool Drawing/Print in a Tool Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
N Printer Calibration Requirements - Documents and Pictures (Print Shop) Calibration and Metrology Software and Hardware 11
Q Procedure for New Product Introduction (NPI) - Build to print shop Various Other Specifications, Standards, and related Requirements 6
L Seeking Print Shop Quality Measures/Survey Quality Tools, Improvement and Analysis 6
S ISO 2768-mk print call out Other ISO and International Standards and European Regulations 11
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
J Gear Surface Finish - Print with the word "calibrated" Manufacturing and Related Processes 2
B FAI and ANSI Y14.5 Trailing Zeros and Print Tolerances Manufacturing and Related Processes 3
CycleMike GD&T - Hole pattern - Print (attached) has a single Datum Reference Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Yellow print VDA 4 VDA Standards - Germany's Automotive Standards 0
Ron Rompen Location of features identified on Print - Feature out of location Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
G ISO 9001 8.4 applied to 7.1.3 - Suppliers of infrastructure requirements - IT and Print solutions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
E Question on GD&T added to print - Positional callout for the small holes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
P Print Control Box - What does this dimension say? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
E Conflicting dimensions on customer print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
D Drawing (print) does not specify restrained or free state Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Decimal places on Drawing (Print) Callouts Measurement Uncertainty (MU) 7
E Print only has Reference Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S AS9102 - Clarification - PO asking for an Assembly at Rev B (Print at Rev C) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q Surface Roughness - Conversion of RS on a Print to RZ General Measurement Device and Calibration Topics 3
P New Yellow Print VDA 6.3 (2016) VDA Standards - Germany's Automotive Standards 10
E Position of a milled hex - Print Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D Multiple Features With Only One Toleranced on the Print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
K Assumed Alignment and Assumed Datum on a Print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
J Deformation specification not defined in print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K APQP requirement when a new print or spec is received from a customer - Existing Part APQP and PPAP 3
A Algorithm to Detect flaw and burr on print characters Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S FMEA's - Severity and Classification of Print Characteristics FMEA and Control Plans 1
V Do I need to add everything on print to control plan? FMEA and Control Plans 1
J Customer Complaint - PPAP - Issues not called out on the print APQP and PPAP 3
6 Print Callout for a Special Thread - 1.173-18 UNS-3A Major Dia. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M 4 Datums Referenced in a Print (Drawing) Feature Control Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J A Euro sign on a print tolerance? Manufacturing and Related Processes 8
T More than One Original Test Report - Original Print General Measurement Device and Calibration Topics 4
T Software that will overlay Old Revision and New Revision Print and Compare Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
R When a Part Print specifies 10 Rmax on a Surface - Rmax Settings & Standards? General Measurement Device and Calibration Topics 2
N Excel Bubble Print Utility - Bubble Prints/Roadmap Prints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Ensuring Print Dimensions are in Control Plans, WI's and Receiving Inspection Document Control Systems, Procedures, Forms and Templates 3
M Radius Measurement question - Print that calls out a 5.5-5.7mm Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Configuration Management for Build to Print Company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Print (Drawing) Bubble Techniques Document Control Systems, Procedures, Forms and Templates 45
H Example of Contract Review for Print Industry wanted Contract Review Process 4
Jim Wynne An Oldie but Goodie - A Print Block from 1937 Coffee Break and Water Cooler Discussions 1
J Perpendicularity-Axis and Plane - Perpendicularity call-out on the print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J Perpendicularity Callout on a Print - GD&T Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
