In-house Calibration - Verniers using gauge blocks
H
Hamed
How can we calibrate verniers using block gauges, and can we find with any one a templete for data registeration, how we decide if the vernier is ok calibrated or not.
Kind Regards.
Hamed
Stijloor
Re: In-house calibration
Kind Regards.
Hamed
Hamed,
You may want to start by looking here. I did an advanced search for you on "Calibrating Vernier Calipers."
I hope that you can find the specific information you need.
Stijloor.
Z
zancky
Hi Hamed,
try ISO 6906 and ISO 3599.
In Italy there is UNI 10699-8:1999 just for vernier calibration.
Nevertheless what iso says If You wont to check a caliper use cylinder or spherical gauges not block gauges so You can control if the side of caliper are parallel!
good luck
CliffK
If you're dealing with plastics, ASTM D 5947 details the requirments for calipers and micrometers, including calibration thereof.
stefanhg
Hi Hamed,
you can try VDI/VDE/DGQ 2618 Part 9.1 Test instructions for callipers for external, internal and depth dimensions.
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
L In house calibration - Our CMM's are outside certified can I use them to certify our standards General Measurement Device and Calibration Topics 4
Ed Panek ISOTECH TTI-10 found out of calibration - Calibration house was wrong? General Measurement Device and Calibration Topics 7
H In-house device calibration record - Actual values obtained required? General Measurement Device and Calibration Topics 9
T In house Calibration? Measurement equipment traceability requirements - ISO9001 General Measurement Device and Calibration Topics 12
G In-House Calibration of Gas Flow Meters General Measurement Device and Calibration Topics 6
4 In-House Thread Wire Calibration General Measurement Device and Calibration Topics 5
C ISO17025 for In-House Calibration Labs: Is it required? ISO 17025 related Discussions 30
A Is NIST traceability required if a Refractometer calibration is done in-house? Calibration Frequency (Interval) 6
D Measurable objectives for our in-house calibration department General Measurement Device and Calibration Topics 6
M In house Volt Meter Calibration General Measurement Device and Calibration Topics 5
N ISO 17025 Requirements for Environmental Conditions for In-House Calibration ISO 17025 related Discussions 5
W Force Calibration - In-House Load Cell Calibration General Measurement Device and Calibration Topics 7
M Looking for a copy or template of a In House Calibration Report for a Dial Indicator General Measurement Device and Calibration Topics 1
C Flow Meter Calibration - Outside Calibration Service vs. In-House Calibration General Measurement Device and Calibration Topics 3
S Using Prepared In-House Reference Materials (RM) for Equipment Calibration & Verifica General Measurement Device and Calibration Topics 3
S In-House Equipment Calibration Report Format & Template Example Needed Document Control Systems, Procedures, Forms and Templates 1
1 Pharma Industry stance on ISO 17025 Accreditation - In-House Calibration Laboratories ISO 17025 related Discussions 3
T Reference Spectrum Generator for In-House Calibration General Measurement Device and Calibration Topics 2
G OEM (Original Equipment Manufacturer) Calibration of In-House Measurement Equipment General Measurement Device and Calibration Topics 18
F Temperature Requirements for an In-House Calibration Laboratory General Measurement Device and Calibration Topics 8
T In-House Calibration of Thread Plugs/Rings to achieve a 4:1 Ratio Measurement Uncertainty (MU) 4
R In-House Calibration Facility Requirements - Setting up a new in-house laboratory General Measurement Device and Calibration Topics 4
B In-House pH Meter Calibration General Measurement Device and Calibration Topics 13
B Developing In-House Calibration Capacities General Measurement Device and Calibration Topics 5
E Gauge Block Grade recommended use for in house calibration General Measurement Device and Calibration Topics 1
C Setting up Pressure Calibration In-House Lab General Measurement Device and Calibration Topics 7
J In-House Calibration Requirements - Use of Grade 2 set of gage blocks General Measurement Device and Calibration Topics 2
D TS 16949 In-House Calibration Requirements - Certification Required? IATF 16949 - Automotive Quality Systems Standard 26
T In-House Calibration - Digital Micrometer found Out of Calibration General Measurement Device and Calibration Topics 10
R Self (In-House) Calibration of Measuring Tools (vernier, micrometers etc.) General Measurement Device and Calibration Topics 17
D Calibration vs. Verification - Can we calibrate dial indicators in-house? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
ScottK Soliciting recommendations for a fast turnaround calibration house - Mass Flow Meter Manufacturing and Related Processes 1
M Gage Block In-House Calibration - Blocks lost and users keep exchanging blocks General Measurement Device and Calibration Topics 2
V Is permission from Registrar needed for deciding on in-house calibration? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J Thread Gage Calibration: In-House or Outsourced? General Measurement Device and Calibration Topics 7
E Can anyone recommend a good/inexpensive calibration house? General Measurement Device and Calibration Topics 9
S Calibration System was In-House now Outside (External Service Provider) General Measurement Device and Calibration Topics 14
U Calibration House - Where I can get a PG 13.5 Gut thread ring gage calibrated? General Measurement Device and Calibration Topics 1
T In-house Calibration Procedures in our FAA Approved Repair Station Federal Aviation Administration (FAA) Standards and Requirements 11
BradM Certificate for In-House Calibration General Measurement Device and Calibration Topics 25
K What is the difference between in house calibration and verification? General Measurement Device and Calibration Topics 10
A Auditor has rejected our in-house gage verification - Calibration in 17025:2005 ISO 17025 related Discussions 21
J In-House Calibration Certificate wording - Confidence Level or Level of Confidence? Document Control Systems, Procedures, Forms and Templates 3
B In-House Calibration form needed Document Control Systems, Procedures, Forms and Templates 1
J Using Outside Accredited Calibration Laboratories vs. In-house Calibrations General Measurement Device and Calibration Topics 10
C In-House Particle Counter Calibration General Measurement Device and Calibration Topics 12
C Calibration Outsourcing vs. In House Calibration - Outrageous Costs of Calibration General Measurement Device and Calibration Topics 28
R In-house Calibration and still maintain my "we do not have a lab" status? IATF 16949 - Automotive Quality Systems Standard 10
J In-house calibration - Resource for calibration, adjustment of calipers, indicators General Measurement Device and Calibration Topics 2
