In-house device calibration record - Actual values obtained required?
H
Helifreak
Hi all,
My first post on the Cove...
Are actual values obtained during device calibration required on the in-house calibration record or are reference to standards used in calibration and traceablity to NIST sufficient?
Rick
Ninja
Looking for Reality
Up to you, really...but it is hard to question recorded actual vs. known good (standard) data.
It would be easy to question "We used this standard and the gage passed".
H
Helifreak
Thanks Ninja!
I'm guessing it's safe to assume measurement results from device calibration would be of no use on the device record.
Hi all,
Rick
Hi Rick: Welcome!
Firstly, if we understand WHY we calibrate that helps. Calibration is the act of determining how far from a value (spec), the measuring instrument value is reading. Based on that understanding of the comparison, you can make 2 fundamental decisions - based on the value reported: is the product (feature) in spec? How reliable is the measuring equipment?
Without recording that value when calibrating, how will you be able to make valid decisions?
Ninja
Looking for Reality
100% agreed (with the whole post, not just this snippet)...
While calibrating/validating/assessing, the values have to be known...and typically that means recorded either visibly or within some piece of equipment.
...and they have to be compared to the known standard...
...and a decision must be made based upon the differences seen...
All of that MUST be part of the calibration.
Whether or not all of that needs to be part of the calibration record, though...I don't see the Shall.
@ the OP: All the same, is there a reason why you are trying to avoid keeping the data?
It seems such an easy thing to keep to avoid any future question that it seems odd to be looking for a loophole here. What drives your question as to whether to keep the data used for the decision?
Ninja
Looking for Reality
Not sure I'd say that...
I've looked back on cal data for trends and to revisit calibration periods.
Having a record of Pass, Pass, Pass, Pass, Fail does nothing for me in determining why the fail happened, or whether to replace the gage with the same model or to look elsewhere.
I've also looked back at "Passed by how much" to lengthen or shorten calibration intervals (and to defend a gage cal cycle to customers).
While you may not HAVE to keep the data...I would require it in my shop. It would never occur to me to discard data used as the basis of a decision...especially if it was directly related to Acceptance Criteria like calibration.
Another, often overlooked part of an effective calibration scheme is trend analysis. Capturing the "as found" values of the measuring equipment gives information on drift, stability and, hence, adjustments to calibration frequency. If the concern is the maintenance of such records over time, compare that to the cost of scrap/rework/repair/recall associated with NOT keeping records...
H
Helifreak
OK I'm convinced. After reading your helpful responses, I've decided to include the calibration data on the record. Now I need a calibration record with provision for recorded data; do you know where I can get a sample form?
TBH,and depending on the population of measuring devices you have, a better solution to management of gauges is a database - you can find free ones on the interwebs, but investment in Gagetrak or similar might be best in the long run...
Ninja
Looking for Reality
Andy already gave some guidance...I would simply point out that a "Form" is not required.
Most of the time I kept my in house cal data in XL (or in whatever form it originally output...csv, .txt, whatever).
I would print a copy of the data from the XL file for our cal records simply because they were still on paper at the time.
Computer storage is cheap...as long as you can find it when you look for it.
\\Network drive\calibration records\Gage number\raw data 072018.xlsx
Pretty easy to find...
...and easy to copy/paste for trend analysis...
O Hospital-Developed, In-House Device - FDA Clearance? Other US Medical Device Regulations 19
Ed Panek Small Medical Device company - Bring production in-house ISO 13485:2016 - Medical Device Quality Management Systems 1
J IEC 60601 Medical Device Testing House Costs IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
K ISO 14971 and IEC 62304 - Medical Device Software House ISO 14971 - Medical Device Risk Management 9
JoCam Approving a Test House on a Medical Device as a part of a 510k Submission 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
B In house NIOSH pre Testing accepted by NIOSH? US Food and Drug Administration (FDA) 1
M Guidance for health institutions on in-house manufacture and use UK Medical Device Regulations 1
T Training recommendations? Bringing our RoHS and REACH compliance efforts in-house REACH and RoHS Conversations 2
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
J Looking for a training organization that can provide in house DFMEA training FMEA and Control Plans 4
I Help: QFD House of Quality Quality Tools, Improvement and Analysis 1
J Conflict of Interest Registrar/Notified Body/Testing House Quality Manager and Management Related Issues 4
W ASTM F1929 dye penetration test - Validation for in-house testing ISO 13485:2016 - Medical Device Quality Management Systems 16
L In house calibration - Our CMM's are outside certified can I use them to certify our standards General Measurement Device and Calibration Topics 4
T Was Just told we could ONLY buy material for AS9100 customers if the DISTRIBUTION house is AS9100 / AS9120 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Ed Panek Bringing Production In house ISO 13485:2016 - Medical Device Quality Management Systems 10
Ed Panek Moving from Contract Manufacturing to Production In-House ISO 13485:2016 - Medical Device Quality Management Systems 3
M Informational Understanding Costs And Risks For HFE Usability Studies — Part 1: Testing In-House Medical Device and FDA Regulations and Standards News 0
Ed Panek Bringing Production in house from Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 3
S Assembly House Process Chart ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Ed Panek ISOTECH TTI-10 found out of calibration - Calibration house was wrong? General Measurement Device and Calibration Topics 7
supadrai Prop 65 - A (former) litigation attorney's (now in-house counsel at a MD manufacturer) perspective. RoHS, REACH, ELV, IMDS and Restricted Substances 18
M Bringing blending in-house - Verification or full validation? (Disinfectants) ISO 13485:2016 - Medical Device Quality Management Systems 3
smryan Chemistry and physics of plastic behavior - Any plastics experts in the house? Coffee Break and Water Cooler Discussions 1
T In house Calibration? Measurement equipment traceability requirements - ISO9001 General Measurement Device and Calibration Topics 12
S ISO 9001:2015 Gap Analysis - In-House or 3rd Party? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Standards Needed In House - Determining what standards are applicable Various Other Specifications, Standards, and related Requirements 3
R Sterilization Adoption - Design House - Adoption Letter from Contract Manufacturer EU Medical Device Regulations 3
KyloDen Checking Threads - Discrepancy in threads that are machined In-House vs. Outsourced General Measurement Device and Calibration Topics 11
B ISO/TS16949 In-House Non-Product Laboratory IATF 16949 - Automotive Quality Systems Standard 3
G In-House Calibration of Gas Flow Meters General Measurement Device and Calibration Topics 6
X Neutral Electrode IEC 60601-2-1 Test House IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
4 In-House Thread Wire Calibration General Measurement Device and Calibration Topics 5
C ISO17025 for In-House Calibration Labs: Is it required? ISO 17025 related Discussions 30
P House of Quality Functional Requirement question Six Sigma 4
P "House of Quality" Excel template wanted Document Control Systems, Procedures, Forms and Templates 6
A Is NIST traceability required if a Refractometer calibration is done in-house? Calibration Frequency (Interval) 6
D Measurable objectives for our in-house calibration department General Measurement Device and Calibration Topics 6
P Need GD&T Training - In-house preferably Training - Internal, External, Online and Distance Learning 7
Y Identifying lighting requirements for in house Calibrations General Measurement Device and Calibration Topics 8
Z Repository of In-House Improvement Projects - Engineering Service Provider Lean in Manufacturing and Service Industries 1
M In house Volt Meter Calibration General Measurement Device and Calibration Topics 5
M Calibrating Digital Pressure Gages In-House General Measurement Device and Calibration Topics 10
N ISO 17025 Requirements for Environmental Conditions for In-House Calibration ISO 17025 related Discussions 5
R Test House Transport and Storage Conditions Verified IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
C Verifying In House Laboratory Weight Sets General Measurement Device and Calibration Topics 2
P HACCP for Poultry Slaughter House Food Safety - ISO 22000, HACCP (21 CFR 120) 2
P Flower Packing House Certification for ISO 22000 Food Safety - ISO 22000, HACCP (21 CFR 120) 4
N Government Help to Clean Up Credit to Buy A House? Coffee Break and Water Cooler Discussions 24
