In-Process Production Test Stations in PFMEA (Process FMEA)
N
nitros1
Hi all greetings.
Working in one of my first PFMEAs I come across with tester stations. My question is how are these stations treated? They are part of the process but no operation is being made, or modifications are being made to the product they are just testing some characteristics of the process, using sensors for example, so the failure modes of these stations would just be not testing well? if these is the case then why in other non tester stations the malfunction of sensors is not considered failure modes? or for example if I want to the test the presence of a screw, should I include the failure mode * absence of screw* even though I considered this stations before in the station that indeed puts the screw on?
Secondly, what is the best way to use * visual inspection* as a detection method? An engineer told me that I shouldnt use visual inspection unless I had somebody inspecting the condition, what about if the operator of the next station in the paragraph above notices the lack of screw even though is not an inspector checking 100 per cent that condition.
Thank you for your help.
When including an inspection control in a PFMEA as a process step, the potential failure modes are:
  • Accepting a bad part
  • Rejecting a good part
A specific malfunction of a sensor (e.g., failed open) would then be a potential failure cause for these failure modes.
When sensors are a built in part of another operation considered in the PFMEA, they are considered part of the process controls for the specific failure mode/cause for which they were included to check. If there is a high failure rate for the sensors, I would downgrade the Detection rating accordingly.
Visual inspection, both at the station itself, or by successive checks (next station), is a control, just not a very effective control. Reducing it from 100% to x% further reduces its effectiveness. Again, you can include it in the PFMEA as a control, but you should downgrade the Detection rating accordingly.
yodon
Just to add on a bit to Miner's excellent post, you asked how test stations are treated. You do want to be sure that the test stations do identify the defects they're intended to identify. You can (should) do a validation of the test station to provide confidence that they perform as expected.
N
nitros1
Thank you pretty much for your help, but if a test station has the risks/potential failure modes you mentioned, what do I put as a detection method since its already a detection station? A loop can go forever.
N
nitros1
Thanks yodon.
For what I know R&Rs and CPks are a way, what else, would I need to validate?
The most common control for an inspection process would be a calibration program. Others might include an R&R study, red rabbit testing, etc. You would stop at this point because these are no longer unique process steps.
yodon
Thanks yodon.
R&R is close... you want to validate that the station detects bad product and passes good. There are often a lot of 'edge' cases that can be assessed in a test station.
Of course, if your test station has software, that needs to be validated as well, ensuring it's under proper control, etc.
N
nitros1
ok, but what kind of controls would these be? Im guessing prevention controls, but what do I fill the detection controls column with? a detection for the detection...
It depends. Some are both, like calibration. Done up front it is preventive, but it can also be detection when you find the gage out of calibration. Red Rabbit tests are definitely detection.
Cephissus
In my company there is a rule (which is not extracted from any book/guideline as far as I'm concern) to split the testing stations in two categories:
1 - Non-touching test items: Camera/Sensors
2 - Touching test items: detection pins (feelers)
The first category is never described as a process step, under the assumption that the product is not being modified at that step (although one could argue that the information related to it has increased).
The second category is always included as a Process Step in order to assess the possibility that it damages the product while testing (ex: when you need to insert an electrical connector, or need to actuate the part a bit).
We do not use: Accept good part/Reject bad part. We take into account the reliability of this detection action in its D rating.
We have a general rule (and I think this is written in some of the guidelines) that we do not study "cumulated" failures, like two failures in a row or two simultaneous failures. As such studying the failure of a detection tool to detect a failure is not part of our typical scope.
C Validation of process for production and servicing 5.7.1.5 API Spec Q1, 9th Edition Oil and Gas Industry Standards and Regulations 9
DuncanGibbons Process flow & PFMEA for production planning and simulation activities? Process Maps, Process Mapping and Turtle Diagrams 7
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
Sidney Vianna AS9100 News PPAP in the Aerospace Sector - What is it? AS9145 - Requirements for Advanced Product Quality Planning and Production Part Approval Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
H Informational What is PPAP (Production Part Approval Process)? APQP and PPAP 26
K AS9100D production process scheduling requirements Internal Auditing 14
A Statistical Process Control and Inspection in Footwear Production Statistical Analysis Tools, Techniques and SPC 0
J Differences between a Risk Management Plan vs. Production Part Approval Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K FAI (First Article Inspection) vs PPAP (Production Part Approval Process) APQP and PPAP 15
M Cement Production Process Audit Process Audits and Layered Process Audits 3
I Where to find VDA 6.3 Robust Production Process (rpp) PDF file ? VDA Standards - Germany's Automotive Standards 1
S Production Process Sheet Review Meetings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
R Calibration of processing equipment - 21 CFR 820.70 Production and process controls 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Q Form for Managing Coating Process Parameter Changes during Production Document Control Systems, Procedures, Forms and Templates 2
Q Introducing Process based approach on Production Floor Manufacturing and Related Processes 6
J PPAP (Production Part Approval Process) Requirements for Annual Revalidations APQP and PPAP 1
B Example of Production Process Change having Significant Consequences AS9100C 7.5.1.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
V Production Development Process APQP Methodology APQP and PPAP 9
M Changes Assessment as per AS9100 Clause 7.5.1.2 Control of Production Process Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
V Supplier?s PPAP - Production Process Control Plan Review, Evaluation and Approval? FMEA and Control Plans 5
G AS9100 Clause 7.5.1.1 Production Process Verification Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T How to link Process Design Changes in Serial Production to Design & Development? Design and Development of Products and Processes 6
P Risk Assessment Production Process Milling for Implantable Joints EU Medical Device Regulations 2
B ISO 9001 Clause 7.5.2 - Validation of Process for Production and Service Provision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Production Process Verification - AS9100 Clause 7.5.1.1 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
J Production Process vs. Manufacturing Process - Differences IATF 16949 - Automotive Quality Systems Standard 2
P Production Process deviated from Documented Procedure ISO 13485:2016 - Medical Device Quality Management Systems 2
T Nylon Fiber Production - Job Interview - New to this type of process Manufacturing and Related Processes 1
R Suppliers Defects found during Production Process - Supplier Scorecards Quality Tools, Improvement and Analysis 6
B Complicated Production Process - Sub-Process Documentation Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Part Marking: When in the production process to mark parts? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S Validation of Production Process - Practical Example ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Methods for doing Production Process Risk Analysis ISO 14971 - Medical Device Risk Management 4
A LPA's (Layered Process Audits) for Non-Production Support Processes Process Audits and Layered Process Audits 13
M Correlation Production Time Study on a Process on an Assembly Line Manufacturing and Related Processes 3
R Starting In-Process Quality Inspection in the Production Shopfloor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
W Process of Pre-Production under Mass Production Conditions IATF 16949 - Automotive Quality Systems Standard 6
P Robots in a Production Line - Control Plan and Process FMEA Manufacturing and Related Processes 9
M PPAP (Production Part Approval Process) files for Ford APQP and PPAP 11
K Process Validation of Low Volume Production of Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 9
R Line Leader Assessment form - Qualification process for production line leader Training - Internal, External, Online and Distance Learning 1
A Production Process Planning - Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
S Quality Control during the Production Process (Space Constraints for QC Inspectors) Misc. Quality Assurance and Business Systems Related Topics 8
S Forms for changing process specifications during production Document Control Systems, Procedures, Forms and Templates 5
A Self-controlled production process - OK according to ISO 9001 requirements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A What is PPAP (Production Part Approval Process) Why submit it and/with PSW APQP and PPAP 2
B Help for beginner - PPAP (Production Part Approval Process) APQP and PPAP 9
S APQP Application - Product/process modification and production transfer APQP and PPAP 6
D Production Process in Ceramics - Toyota Production System Process Maps, Process Mapping and Turtle Diagrams 3
R Is Kappa Study Required during PPAP (Production Part Approval Process)? IATF 16949 - Automotive Quality Systems Standard 9
