In-Process Sampling Plan for a Secondary Package Adjustment Process
BERMUDEC
Dear All,
I would be grateful if you could help me with a couple of questions:
1) There is a sampling plan for a secondary package adjustment process:
a. Process description:
Remove the original leaflet from the box (package), place alternative leaflet, place warning labels on the box (the quantity of these labels depends on the product (2/3/4)). Each one of these steps will be dubbed as "process stage".
There a 13 different products, different sizes, different number of stages.
b. In-process sampling plan description:
Every 2 hours a QC samples the packages according to this pattern: in a process composed of up to 2 stages - 3 packages must be sampled, in a process composed of up to 4 stages - 5 packages must be sampled, in a process composed of more than 4 stages - 6 packages must be sampled.
I fail to see the logic behind this plan - there's no mention whatsoever of the total quantity of the product in the batch. During 2 hours, different quantities of different products could be adjusted (even if some of the products require the same ammount of stages).
Another thing I don't quite get where do the relationship between the ammount of stages to the sampling sizes come from - I couldn't find a standard or any historical data that justifies these values.
2) Do you know any standards/techniques deals with similar in-process sampling?
Thank you in advance.
First: the appropriate inspection sample sizes are not based on the lot size. (even tho the popular ANSI tables use them, they are not statistically correct)
The plan you are describing sounds it was developed to increase the units inspected as the opportunities for a defect (more process steps) increases. While teh logic for this was no doubt well intentioned it is in contradiction to the reality that the ability to detect a defect increases as the defect rate increases.
statistically based sample plans would be based ont eh defect rate that one wants to detect and reject and the probability of detectign that rate (or worse) if present. Plans can be augmented by aslo specifying the defect rate that is acceptable to ship and the probability of accepting a lot at that rate or better...
On teh hand the situation you describe sounds like a 'dock audit' and these are typically not statistically based. Just take a random small sample; you are looking for catastrophic large defect rates at this point.
E Sampling plan for orthopedic implant - Process Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M Manufacturing Process Validation Destructive Testing Sampling Plan Advice Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
G Sampling Plan - Sample Size Justification for a Bottling Cleaning Process Validation Qualification and Validation (including 21 CFR Part 11) 2
V Sampling Plan for Final Inspection and Process Verification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 21
B AS9100 Process Sampling Plan Basics and Requirements Document Control Systems, Procedures, Forms and Templates 3
J Sampling Strategy for Process Control - How to develop a Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Sampling Plan on a Centerless Grinding Process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 27
P AQL and Sampling Plan as they relate to Functional In-Process Inspections AQL - Acceptable Quality Level 4
Manix Automotive Sampling Plans. HELP! Working on an Automotive process control plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
R Sampling Plan - The process involves verification of employment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
C Work Sampling Method for Induction Melting Process Improvement Six Sigma 3
N In-Process Inspection Sampling Quantity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
0 Standards for Sampling a Continuous Process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Process Stability & Sampling - Can Sampling detect an Unstable Process? AQL - Acceptable Quality Level 10
I Sampling Plans - Guidance to Sampling a Process during Validation Qualification and Validation (including 21 CFR Part 11) 12
J Determining sufficient data points to commence sampling for in-process inspections Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Z Reduced Sampling based on Process Capability (AS9100 Standard) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Random Sampling for in-process inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
bobdoering Statistical process control for precision machining - Part 3 - Sampling Error Imported Legacy Blogs 0
H How to define process sampling frequency? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Gage R&R - Sampling rule and process range Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
D Project to Reduce Destructive Sampling in Crimping Process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Internal Process Audit Sampling using MIL-STD-105-E - 500 operators on 3 shifts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M Sampling a continuous process - How to use AQL with a continuous process AQL - Acceptable Quality Level 6
F SPC/Sampling on Bulk Material (Continuous Nonwoven process - total weight) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A When someone refuses to follow a process.... Misc. Quality Assurance and Business Systems Related Topics 21
R MDEL Process Canada Medical Device Regulations 4
optomist1 Rates Daily or Hourly Process Improvement Training Consultants and Consulting 2
B Toyota PPAP Process - Three Questions APQP and PPAP 3
R Changes vs CMO - How can we simplify this process? Supplier Quality Assurance and other Supplier Issues 3
A Ethics Committee Review Process for IVD Products EU Medical Device Regulations 2
V Laser Welding Process - Impact on Electrical Properties Reliability Analysis - Predictions, Testing and Standards 4
R MRB (Material Review Board) Process using MS Sharepoint or MS Teams Manufacturing and Related Processes 2
M Clinical Benefit of device that only aids in a process for managing or treating disease EU Medical Device Regulations 2
C In-process inspection - Tooling and assembly lines for automotive companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Efficacy of an IT process after a cyber attack ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
