Including all Processes in Risk Management - ISO 13485:2016
Hello everybody,
In the new EN ISO 13485:2016, Risk Management must be included in all processes in the Quality Management System (QMS). How would the QMS be updated to include Risk Management in all process? Is it enough to have a general Risk management SOP or should the Risk Management be considered in each SOP separately?
Thanks in advance for your help
Crusader
Hello everybody,
I have a risk item in each SOP and I am creating a master list of them for easy reference. In that master list, I will assign a severity level (Lo, Med, Hi) kind of thing and list the appropriate actions for each in the next column. This should be sufficient. (from what I am told)
yodon
This could be an interesting discussion!
If you look back in section 0.2, Clarification of Concepts, they say:
When the term “risk” is used, the application of the term within the scope of this International Standard pertains to safety or performance requirements of the medical device or meeting applicable regulatory requirements.
Somehow, lo/med/hi need to relate to how those processes can impact the safety or performance of the device or in meeting regulatory requirements.
Taking 6.2, Human Resources for example, one could argue that a a software developer and a solderer on the assembly line would both fall in the 'hi' category depending on the work they're doing. Or they may both fall into the 'lo' category if what they're doing has little impact. Clearly, though, the actions taken to ensure and maintain competence are different in all of the above cases.
I'm not saying the 3-level categorization can't work; it just need to be framed around what the risks to performance or safety or meeting regulatory requirements are.
Q
QAMTY
Crusader
Say, I detected a risk in delivery product to client (delivery process), for the treatment, I will rent an additional truck for transporting the product, and such risk is registered in a master list of risk of all the processes.
As you say, should I include in the SOP , that Im having an additional resource for transportation? duplicating the information?
Note that from time to time, risks are changing, then I will have to change the SOP every time a new risk appears.
Is it not better that in the SOP I only refer the list of risk?, thus saving time and paperwork?
Crusader
Crusader
Our procedures mention the "risk" as a general statement. What we do with that statement is handled in a separate document right now. Only 1 doc needs updating and that is the separate risk document. The SOP's stay as-is without needing any updates unless you add a new risk or revise a risk to the procedure/process. It is much easier to make that separate document a living document and revise it as necessary.
I can see that mentioning or referring to the separate document of risks is another method of reducing the amount of revisions to paperwork. That should work as well.
You still need to.. or.. should point out where specifically in the SOP that the risk needs to be considered.
Q
QAMTY
Thanks Cruzader
The separate risk document is the General list of Identified Risks?
Thank you so much
Q
QAMTY
Hey Crusader
If you refer risks in each Sop, what do you do q
With processes wich doesnt have a sop?
B QMS Conversion including Documentation and Understanding our Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Process Required - NC for not including HR and Maintenance in our Processes Sequence IATF 16949 - Automotive Quality Systems Standard 2
M Informational TGA – Submissions received: Regulation of software, including Software as a Medical Device (SaMD) Medical Device and FDA Regulations and Standards News 1
J Requirements for Layered Process Audits including Maintenance, Shipping, Receiving IATF 16949 - Automotive Quality Systems Standard 4
M Informational Several US FDA draft guidances, including some specific device guidances for the Safety and Performance Based Pathway Medical Device and FDA Regulations and Standards News 0
B Design of fixture checking including Position of hole and slot General Measurement Device and Calibration Topics 5
M Informational TGA – Webinar: An update on the consultation for the Regulation of Software, including Software as a Medical Device (SaMD) Medical Device and FDA Regulations and Standards News 0
J Including Repeats in DoE using Minitab Using Minitab Software 5
M Informational TGA Consultation: Proposed regulatory scheme for personalised medical devices, including 3D-printed devices Medical Device and FDA Regulations and Standards News 0
M Informational TGA Consultation: Regulation of software, including Software as a Medical Device (SaMD) Medical Device and FDA Regulations and Standards News 0
S Source of QMS templates including templates for design verification/design validation Document Control Systems, Procedures, Forms and Templates 2
qualprod Including services in quality policy? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Russia - Medical Device Regulation Including Definitions Needed Other Medical Device Regulations World-Wide 3
M Employee Motivation 7.3.2 & Training including Awareness 7.2.1 IATF 16949 - Automotive Quality Systems Standard 6
Uriel Alejandro Including "Internal Rules" as Controlled Documents in a QMS Document Control Systems, Procedures, Forms and Templates 7
Q Including the Word "Risk" into the Quality Policy (ISO 9001:2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Software Test Report including IEC 62304 classification IEC 62304 - Medical Device Software Life Cycle Processes 4
T Including two Class 1 Medical Devices as one 'promo' item Other US Medical Device Regulations 2
R Inconsistent Form Content including User Changes Document Control Systems, Procedures, Forms and Templates 3
R Labeling, translation requirements including software interface: EU & other markets EU Medical Device Regulations 2
K Including ISO 13485 Audit JPAL Registration Japan Medical Device Regulations 3
bio_subbu MHRA issues guidance on Medical Device stand-alone software (including apps) EU Medical Device Regulations 1
B Including the Non Automotive Customer in our TS 16949 QMS IATF 16949 - Automotive Quality Systems Standard 7
S Justification of Lifetime of a Medical Device including Component Aspects ISO 13485:2016 - Medical Device Quality Management Systems 13
B Form to use for Rework including Verification of Effectiveness of the Rework Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
AnaMariaVR2 FDA Regulates Lasers including Toys with Lasers US Food and Drug Administration (FDA) 4
L Do all non-random patterns apply to attributes and variable charts including R chart? Statistical Analysis Tools, Techniques and SPC 5
V Evaluation of Paint Specifications including such as GM 9984123 and GM 14671 APQP and PPAP 1
I 820.75 Process Validation including Suppliers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 12
V PPAP Requirements including GMW 3179 Zinc Plating Specification Requirements APQP and PPAP 3
R Separation of Network Port from other Circuits including Patient Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P Can an outside consultant audit all the AS9100 requirements including Internal Audit? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
D Tracking Updated Standards (EN/IEC...) including Ammendments EU Medical Device Regulations 2
J 7.4.2g ?flow down to the supply chain the applicable requirements including customer AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q Non Conformance Closure by including it on another Corrective Action ISO 13485:2016 - Medical Device Quality Management Systems 8
C IEC 62304 conformity for 510k submission legacy product including software IEC 62304 - Medical Device Software Life Cycle Processes 2
C Does anyone have the Ford Supplier Requirements Manual (including Q1)? Customer and Company Specific Requirements 2
Marc Copyright - Including Copyrighted Material from other Websites or Sources in Posts Elsmar Cove Forum ToS and Forum Policies 12
M Customer wants each dimension, including reference, in PFMEA FMEA and Control Plans 6
Sam Lazzara Citing Revision Dates for External Documents including Standards Other ISO and International Standards and European Regulations 8
P Quality Engineer's Role in Cost Management (including UMC) Misc. Quality Assurance and Business Systems Related Topics 3
J Supplier Warranty and Product Responsibility including Failure Analysis Design and Development of Products and Processes 9
A SPC Software Packages - Real Time and can link to Databases including Oracle Statistical Analysis Tools, Techniques and SPC 7
M PPAP including FAI Parts - Customer is requiring 5000 measurements APQP and PPAP 15
Q Notification to Registrar Concerning Continuous Dynamics including Restructuring ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Including the Accounting Department in our Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Including Product Trade-Ins in our Quality Management System (QMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R IMDS Clarification - Including Raw Material Supplier IMDS Information RoHS, REACH, ELV, IMDS and Restricted Substances 6
somashekar Customer Feedback System including Customer Complaints - Documented Procedure ISO 13485:2016 - Medical Device Quality Management Systems 10
S Linearity Calculation Worksheet (including formula) General Measurement Device and Calibration Topics 1
