Incoming (Receiving) Inspection - General form for incoming part inspection
duff999
I am looking to create a general form for incoming part inspection that I can add to a quality plan for incoming receiving parts. I am struggling to put a form together that will also allow a field for the measured result for the part inspected. For example, I am checking the size of a screw with a tolerance level, and just want to record the result on the fo,r to ensure it falls between the tolerance measurements
Seems like a simple form but I need to allow enough space so all the measurements in the inspection plan can be written on the form. Sometime I will be inspecting 5 parts or other times many more than that depending on the AQL level. I just want to be sure all the measurements are listed on the form to show evidence that the part was inspected.
Eredhel
Quality Manager
Is there a standard or customer requirement you are trying to meet? Are you wanting to check every dimension on just one part and then spot check different dimensions on a sample of parts or are you wanting to check every dimension on every part in the sample size? Are you wanting to document select dimensions, document every dimension on every part in the sample, or just document every dimension on one part and then document the quantity of parts you inspected?
Sorry trying to get an idea of your need and goal.
duff999
Thanks for your reply. I have created a quality plan for each part of our BOM. For each part, I have come up with a requirement that I would like to be met. For instance, I have acceptance criteria of dimension length, dimension head diameter, dimension head height. along with a number of visual inspections, I am running.
I want to be able to record the actual measurement in the table for that specific requirement. If its only one sample its simple, I have enough space in the table I created to record the actual measurement. My problem is if the AQL ends up being saying 10 pieces to sample, I dont have enough space to record 10 measurements for the certain requirement.
hope that helps a bit
Cari Spears
Is it acceptable to indicate the number of pieces and record the range?
L How to define R & D Receiving (Incoming) Inspection Plan Design and Development of Products and Processes 18
M Partial Incoming (Receiving) Inspection Delivery Inspection. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M Incoming (Receiving) Inspection Procedure - Please Review Supplier Quality Assurance and other Supplier Issues 7
K Incoming (Receiving) Inspection for Commodity Items used in Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 11
C Medical Device On The Floor Receiving (Incoming) Quality Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
T Is Material Certification Required for Incoming Material (Receiving) Inspection? Supplier Quality Assurance and other Supplier Issues 10
N How to apply Incoming (Receiving) Inspection to Customer Supplied Material? IATF 16949 - Automotive Quality Systems Standard 18
L Critical Characteristics in Incoming (Receiving) Inspection - Inspection Levels Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
P Implement FAI process in my Incoming (Receiving) Inspection Procedure ISO 13485:2016 - Medical Device Quality Management Systems 6
S Incoming Receiving Inspection from Sister Plant IATF 16949 - Automotive Quality Systems Standard 7
M Incoming Quality Receiving Inspection Report sample Supplier Quality Assurance and other Supplier Issues 2
M Incoming (Receiving) Inspection of SMT components Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Which control chart for incoming (receiving) inspection - Sample size of 10 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
G IPC-Std-610D Component Incoming (Receiving) Visual Inspection Various Other Specifications, Standards, and related Requirements 16
K Incoming Receiving Inspection Form Document Control Systems, Procedures, Forms and Templates 6
T I would like to implement ISO 2859 standard for Incoming (Receiving) Inspection Other ISO and International Standards and European Regulations 3
E Should we do Incoming Inspection (Receiving Inspection)? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
Z How to handle Incoming (Receiving) Inspection as a PFMEA item? FMEA and Control Plans 36
B Process FMEA Scope - Does PFMEA cover Incoming (Receiving) Inspection & Dock Audit? FMEA and Control Plans 8
L Incoming (Receiving) Inspection - Is it really necessary that we follow the AQL? AQL - Acceptable Quality Level 7
N Incoming Product Quality - Receiving inspection for chemical substance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C ISO13485 Incoming Receiving Parts Verification ISO 13485:2016 - Medical Device Quality Management Systems 13
K LEAN in the Incoming/Receiving Department Lean in Manufacturing and Service Industries 9
F Supplier Measurements vs. Incoming (Receiving) Measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
B Sample Size for Incoming (Receiving) Materials and Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Incoming (Receiving) Quality Control Laboratory for Raw Paper Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P Incoming (Receiving) Components Inspections Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
W Incoming Certification Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
J Incoming Stock QC, where to start? Manufacturing and Related Processes 6
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
I Incoming insepction needs repair - sell as "new", "brand new", or something else Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T Primary & Secondary Inspection Definitions - Incoming, In-process & Final Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Ajit Basrur Incoming Inspection for Instructions for Use (IFU) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R Is pre-conditioning supplier component before incoming inspection tests allowed? Quality Manager and Management Related Issues 16
T How to identify requirements for 'Incoming inspection' Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J Incoming Inspection Plans under Design Control (part of DMR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
T Can incoming and outgoing areas be allocated inside the store? Other ISO and International Standards and European Regulations 1
R Policy Statement for FDA CFR 820 Acceptance Activities of Incoming Products. Other US Medical Device Regulations 1
M Incoming, In-Process, Final and Outgoing Quality Inspection Procedure examples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Incoming Inspection Database Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Incoming Material Quality Assurance Cell Document Control Systems, Procedures, Forms and Templates 4
R PFMEA (process FMEA) for Incoming Material stage FMEA and Control Plans 7
C Incoming Inspection Acceptance Sampling by Variables and Minitab Quality Tools, Improvement and Analysis 1
S Calibration/Certification requirements for an Incoming Inspection Fixture Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
T Incorporating incoming procedures (ISO9001:2008) with ISO 13485:2003 Supplier Quality Assurance and other Supplier Issues 3
S IQC (Incoming Quality Control) requirement on Electric Power Adaptor for US and CE Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
