Increasing PFMEA occurrence ranking after non-conformance
blile
We recently had a few claims for an issue and I think that should affect the occurrence ranking. That is, I don't think our previously stated ranking is accurate anymore since we had a few cases. Even though we have implemented a corrective action that will help detection, I am wondering if I should make adjustments to the occurrence ranking. Any feedback would be appreciated.
It depends. If your initial rating was based on insufficient data, or if the occurrence has increased since it was done, I think you are justified in revising the rating. However, if the recent claims are still in line with the original rating, I would leave it as is.
mmasiddiqui
Are your documents revision controlled?
According to the practice, you may change the occurrence rating now (revision control-reason to update document), the second part is after the action items are updated/ completed, you may update the new occurrence rating after validation. Some time you may validate using x number of pieces or x number of months of production.
Sebastian
IATF 16949 10.2.3 f)
You shall review, so you have reviewed.
You shall update when necessary, but what does it mean?
E.g. you put in PFMEA rank 1 as per criteria described on page 93 of PFMEA manual and now your customer detected 1 nonconforming part.
Updating is necessary and you can't leave 1 there.
Count how much parts you've made since moment when rank 1 was given and then you will get new rank value. 2, 3, ...
Same applies - you gave 2, re-calculated and then maybe 2 still would be adequate, or alternatively 3, 4, ...
blile
Thanks for the great feedback everyone. Yes - our document is revision controlled. I like your suggestion as I am not so confident our current countermeasure is very strong.
Edward Reesor Role of increased regulatory costs in increasing risk ISO 13485:2016 - Medical Device Quality Management Systems 10
B Increasing Customer Satisfaction While Decreasing Employee Workload Customer Complaints 4
P Increasing Numbers of Harmonised Standards Other Medical Device Related Standards 1
M AQL and the impact of increasing Batch Size, or changing Inspection Level AQL - Acceptable Quality Level 2
smryan Increasing PC Glitches Coffee Break and Water Cooler Discussions 10
C ASQ Examination Fees Increasing for Select Certifications Professional Certifications and Degrees 1
S TPM increasing employee overtime costs - How to reduce costs? Quality Tools, Improvement and Analysis 6
T Increasing Quality: Cost vs. Value Added Misc. Quality Assurance and Business Systems Related Topics 3
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
A PFMEA new AIAG FMEA and Control Plans 0
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 23
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
A PFMEA English language question IATF 16949 - Automotive Quality Systems Standard 4
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
T DFMEA/PFMEA and SCCAF alignment FMEA and Control Plans 19
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
A PFMEA - How long should the recommended actions remain in the recommended actions column? APQP and PPAP 3
S How to fulfill PFMEA "requirement" column? FMEA and Control Plans 2
T Informational Family or Baseline PFMEA Rules FMEA and Control Plans 22
A PFMEA severity score different applications FMEA and Control Plans 11
M Control Method correspondence between PFMEA and CP FMEA and Control Plans 8
W Is the RPN (risk priority number) in the PFMEA really a RPN without the detectability ISO 14971 - Medical Device Risk Management 4
I Making a process PFMEA, no DFMEA (non-automotive toll manufacturer) FMEA and Control Plans 1
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
N PQC (Product Quality Characteristics) and PFMEA FMEA and Control Plans 3
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
M I need a sample Reverse PFMEA Process Checklist FMEA and Control Plans 2
C PFMEA example with machining (lathe+mill) FMEA and Control Plans 1
L Simple Example for PFMEA / Control Plan Training Training - Internal, External, Online and Distance Learning 1
B Proactive efforts to reduce risk - PFMEA risk reduction activities IATF 16949 - Automotive Quality Systems Standard 8
