Re: Indefinite Shelf Life
The shelf life can be defined as indefinite, if you have data to support that the material does not deteriorate over time. However can you provide me with a test that provide absolute evidence that the material will not deteriorate ever :. Even sand deteriorate if you look at attributes like particle size and roughness. Therefore you have to look for the justification by the supplier.
With two of the same materials with different shelf lives I can imagine that it will raise the auditors eye brows. It may be correct, based on the (amount of) data each supplier has collected and the assumptions made to support a shelf life. My guess is that based on the specification of the material, the auditor assumed the indefinite shelf life was incorrect. And based on Freddie’s additional posts he seems to be right, even though it is a incorrect way to write down his finding.
Expiry dates of materials used in your product are critical as the define your products shelf life. That is not an ISO jail, but a critical aspect in assuring product meeting its specifications during the shelf life you have put on your final product. I do not only have issues with how the supplier handles the shelf life determination of the component, but also with the purchasing controls and product design controls applied by Freddie’s company.
