Industry Standard for Correcting Dates on Documents
K
kerkhoffrm
I'm wondering if anyone knows of an industry standard for correcting dates. For example, I recently dated a document with the year as "07" (I know I'm behind, but I had no idea that far!), and it wasn't caught until about a week later. What is the proper procedure for correcting the date on a date different from when the activity was actually performed? Thanks in advance for any assistance you can provide.
Marc
If you want to be clear of the correction, draw one line through the incorrect date so it is not obscured or unreadable. Then put in the correct date and initial.
I don't know of any industry standards. Someone else may be aware of one.
Jen Kirley
Quality and Auditing Expert
I don't know of an industry standard either. Industry expectations are to be able to see what was originally written. That would mean no whiteout, no blackouts and no scribbling allowed. In my experience, specifics are set out by the QMS.
While doing records for submarine inspections, the rule we followed for changes was: single line through the text, then initials of the correcting person (usually to the upper right) and the date correction was made.
Allan66
Let's think about what the concern would be as an auditor - namely that someone is trying to hide / falsify / etc a record. For this reason any use of whiteout fluid or other opaque medium will get you into some interesting discussions.
The simple use of a one-line cross out so that the original text remains visible along with a correction and either initials or name of the corrector together with date the correction was made will show that someone made an error; someone spotted it and someone fixed it. The original inforation is visible so there is no question of impropriety. The name and date relating to the correction is recorded so we have traceability.
As a complete closed loop you can include the statement in your document management procedure that corrections are allowed with a single strike out with initials and dates being recoreded next to the correction.
K
kerkhoffrm
Thank you all for your responses. I am very familiar with the standards for normal corrections. My question specifically applies to dates that are corrected on a different date. Once you cross out the incorrect date, do you replace it with the original date that the work was performed, or do you replace it with the current date? In either case, it would be accompanied by a note that says "for work performed on <original date>". However, while I argue that the first option seems like backdating, the other party is arguing that I didn't really perform the work today, so today's date would be incorrect.
yodon
What we've done / seen is cross out the original then annotate the change with something like "incorrect date originally entered, correct date is Mon-day-Yr" and then initial the annotation and date the annotation with the current date.
To generalize what Allan66 said: any appearance of date manipulation can get you into some interesting discussions. In this case, some added annotation is well worth the trouble.
Wes Bucey
This solution has "legs" for me - the idea of full disclosure of what is going on goes a long way toward making life easier for everyone.
Ajit Basrur
May be this is a good chance for me to post this procedure on "Good Documentation Practices" that I have written solely for the Pharmaceuticals / Medical devices background.
Btw, I received couple of requests from covers requesting me to give them my procedure.
Do let me know if you have any comments.
szohar
Ajit - your GDP SOP is very much like the one we use at my current employer.
Yodon - your description of error correction procedures is consistent with what I learned in an FDA/ISO9001 Internal Audit course earlier this year.
SZ
N Program or application for standard time measurement in industry from video surveillance? Human Factors and Ergonomics in Engineering 1
D Need Resource for Industry Data - standard metrics for machine shops Lean in Manufacturing and Service Industries 3
Paul Simpson ISO TS 22163 - New Rail Industry Standard Other ISO and International Standards and European Regulations 11
R What is the typical industry standard for documenting Usability Risk? Human Factors and Ergonomics in Engineering 16
S Is there a minimum industry standard for PpK ? Statistical Analysis Tools, Techniques and SPC 8
0 Standard that is the equivalent to ISO 22000 but for the non-food industry Food Safety - ISO 22000, HACCP (21 CFR 120) 7
W Where to get French standard RCC-M (Nuclear Industry) The Reading Room 2
C Mitutoyo SJ210 Settings - Is there an Industry Standard Surface Measurement Setting? General Measurement Device and Calibration Topics 4
J Looking for reference to Electronics Industry's Standard Scrap Rates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Cleaning Industry Management Standard (CIMS) Various Other Specifications, Standards, and related Requirements 4
Q Industry Standard for Supplier Tolerences - Sheet Metal Steel and Beams Manufacturing and Related Processes 4
E International Railway Industry Standard (IRIS) Auditor Training Requirements Other ISO and International Standards and European Regulations 13
J Meaning of Business Management System in IRIS (International Rail Industry Standard)? Various Other Specifications, Standards, and related Requirements 4
M International Rail Industry Standard (IRIS) GM/RT2450 Other ISO and International Standards and European Regulations 3
D FMEA with 2 or 3 criteria? Standard applicable to the Medical Device industry ISO 14971 - Medical Device Risk Management 13
M Auditing and harmonization? Determining what is an "industry standard" ISO 13485:2016 - Medical Device Quality Management Systems 6
N CIMS - Cleaning Industry Management Standard Other ISO and International Standards and European Regulations 5
S Recruitment Industry Service Delivery Standard (RCSA-SDS) - getting started Various Other Specifications, Standards, and related Requirements 3
D Industry Standard or rules or best practices pertaining to Automotive Process Flows? APQP and PPAP 3
R Industry inter-lot variation standard for Enzyme Linked Immuno Sorbent Assay (ELISA) Other Medical Device and Orthopedic Related Topics 2
S When (criteria) to Require a Corrective/Preventive Action? (Industry Standard?) Nonconformance and Corrective Action 11
hogheavenfarm ISO then International Railway Industry Standard (IRIS) Or straight to IRIS? Other ISO and International Standards and European Regulations 3
D UL / Safety Testing Oscillators - Is there an "Industry Standard"? Reliability Analysis - Predictions, Testing and Standards 3
S Usability standard IEC 60601-1-6 in the Medical Device Industry IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J How to get the International Railway Industry Standard (IRIS) Various Other Specifications, Standards, and related Requirements 5
T International Railway Industry Standard (IRIS) Other ISO and International Standards and European Regulations 4
D Industry Standard for Brazed Joint Integrity - Customer Specification Various Other Specifications, Standards, and related Requirements 1
J Industry Standard for turning in gages to the Calibration Lab? General Measurement Device and Calibration Topics 2
K What the industry standard is for attribute gage tolerances - In Writing General Measurement Device and Calibration Topics 7
Q ISO/TS 16949 - The Quality Standard for the Automotive Industry IATF 16949 - Automotive Quality Systems Standard 3
Q Industry Standard burr on stamping-is there such a thing? Manufacturing and Related Processes 6
G DPPM Industry Standard - Metal fabrication (Job shop) Misc. Quality Assurance and Business Systems Related Topics 3
P Visual Standard for Watch Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Has anyone heard anything about the Financial Industry standard FS9000 Various Other Specifications, Standards, and related Requirements 5
T QSF 2000 in UK and the US (Australian food industry Standard) - Withdrawn? Food Safety - ISO 22000, HACCP (21 CFR 120) 2
Marc SIC vs. NAICS vs. NACE - Standard Industry Codes Misc. Quality Assurance and Business Systems Related Topics 2
gramps What do you think about automated QA testing For software app industry? Misc. Quality Assurance and Business Systems Related Topics 5
V Certified Auditor - Need of additional certification specific to industry ( GMPs) ASQ vs ECA vs others Professional Certifications and Degrees 1
B Industrial RX inspection of welds (Oil&Gas industry) Reliability Analysis - Predictions, Testing and Standards 0
Revision36 Engineering Change Order Industry Standards Other Medical Device and Orthopedic Related Topics 4
B Quality manual for automotive industry wanted Quality Management System (QMS) Manuals 2
E Non-GMP examples in Pharmaceutical industry Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
DuncanGibbons Are the IQ OQ & PQ procedures applicable to the aerospace industry? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Marc Security in Health Industry Software - February 2020 IEC 27001 - Information Security Management Systems (ISMS) 0
A Complaint alert levels - Industry standards pertaining to alert levels for complaints Customer Complaints 5
S Industry Labelling Standards - non medical Manufacturing and Related Processes 0
C Looking for APQP Training recommendations preferably in the aerospace industry APQP and PPAP 2
R Bill of Materials for a complex product - Industry best practice ISO 13485:2016 - Medical Device Quality Management Systems 2
R Risk Management in the Medical Device Industry ISO 14971 - Medical Device Risk Management 4
