Industry Standard for turning in gages to the Calibration Lab?
jeremiah
Is there a Industry standard for turning in gages to the Metrology lab for calibration? We have 5000 + gages that must circulate through our metrology lab and I wonder what the percentage of gages should be. Gages lost, stolen or for whatever reason do not get to the lab when they are due. Is there any information available? Can someone help? Thanks:bighug:
G
Grizz1345
Calibration Cycle times.
Welcome to the Cove. You will be amazed at the wealth of information found here. There are many variables involved with this decision. Alot has to do with how much a gage is used and what type of gage it is. I have my thread plug gage on a 6 month cycle unless it is assigned to a floor inspector. Those are on a three month cycle. Some companies have those on even a shorter cycle. Most manufacturers recommend 1 year or less for calibration. The tools that cannot be found or are not turned in on time I show as being lost. This will cover me during an audit and when the tool is turned in I move it to an active status. Also by showing it lost any tool found by an auditor with an outdates sticker saves me. Most of my measuring tools are on a one year cycle unless experience shows a failure of cal when they come into the lab. I would shorten the cycle time.:cool:
Jerry Eldred
Very good previous reply to which I couldn't add much. But since I haven't posted in a while, I'll throw in my two cents.
You asked in terms of percentage that should cycle through the metrology lab. The two part answer is that what percentage of them cycle through the lab at a given time is based on workload management and the variables of how well the customers do at turning them in on time.
The second part is how often they should be calibrated. There are a number of philosophies on this. I would recommend checking NCSL recommended practices for the establishment and adjustment of calibration intervals. They cover the various industry-accepted methods.
My personal view is that you establish intervals between calibrations based on gage types (there are many ways to break that down). Some types might need an interval of 6 months, others 12 months, etc. Then, based on history of in-tolerance performance, adjust either individual or families of gage types based on that history. A common rule of thumb is 95% in-tolerance. You increase interval (as appropriate for your context) for better than 95%, and shorten for worse than 95%. There is some freeware available in which you can enter basic numbers, and it will tell you what to adjust the interval to.
As far as gages that do not show up when they are due, that is a quality policy issue. Depending on how strict your customer context is (FAA, FDA, QS9000, ISO, etc.), you may want to consider documentation. In some very strict contexts, any instrument that does not show up on time for cal, documentation is produced in which the issue is escalated through the management chain. If a gage is lost, appropriate management would have to sign off. And when it is eventually found, management would also need to sign off on documentation describing circumstances. The goal is to assure that past due items can not be used beyond their due date. If an item is "LOST" but in actuality it is still in use, there may be serious risk potential (in some strict customer environments). You'll have to decide how strict your environment is to decide what measures need to be taken.
I've seen circumstances in which government auditors can require that proof be given regarding"LOST" gages to assure that management has adequate control.
As it's late and I am exhausted, I'll end there. Bottom line regarding lost items etc., what is your customer quality system requirement. Based on that, I (or others here) may be able to give some inputs on how strict to be.
N Program or application for standard time measurement in industry from video surveillance? Human Factors and Ergonomics in Engineering 1
D Need Resource for Industry Data - standard metrics for machine shops Lean in Manufacturing and Service Industries 3
Paul Simpson ISO TS 22163 - New Rail Industry Standard Other ISO and International Standards and European Regulations 11
R What is the typical industry standard for documenting Usability Risk? Human Factors and Ergonomics in Engineering 16
S Is there a minimum industry standard for PpK ? Statistical Analysis Tools, Techniques and SPC 8
0 Standard that is the equivalent to ISO 22000 but for the non-food industry Food Safety - ISO 22000, HACCP (21 CFR 120) 7
W Where to get French standard RCC-M (Nuclear Industry) The Reading Room 2
C Mitutoyo SJ210 Settings - Is there an Industry Standard Surface Measurement Setting? General Measurement Device and Calibration Topics 4
J Looking for reference to Electronics Industry's Standard Scrap Rates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Cleaning Industry Management Standard (CIMS) Various Other Specifications, Standards, and related Requirements 4
Q Industry Standard for Supplier Tolerences - Sheet Metal Steel and Beams Manufacturing and Related Processes 4
E International Railway Industry Standard (IRIS) Auditor Training Requirements Other ISO and International Standards and European Regulations 13
J Meaning of Business Management System in IRIS (International Rail Industry Standard)? Various Other Specifications, Standards, and related Requirements 4
M International Rail Industry Standard (IRIS) GM/RT2450 Other ISO and International Standards and European Regulations 3
D FMEA with 2 or 3 criteria? Standard applicable to the Medical Device industry ISO 14971 - Medical Device Risk Management 13
M Auditing and harmonization? Determining what is an "industry standard" ISO 13485:2016 - Medical Device Quality Management Systems 6
N CIMS - Cleaning Industry Management Standard Other ISO and International Standards and European Regulations 5
S Recruitment Industry Service Delivery Standard (RCSA-SDS) - getting started Various Other Specifications, Standards, and related Requirements 3
D Industry Standard or rules or best practices pertaining to Automotive Process Flows? APQP and PPAP 3
R Industry inter-lot variation standard for Enzyme Linked Immuno Sorbent Assay (ELISA) Other Medical Device and Orthopedic Related Topics 2
S When (criteria) to Require a Corrective/Preventive Action? (Industry Standard?) Nonconformance and Corrective Action 11
hogheavenfarm ISO then International Railway Industry Standard (IRIS) Or straight to IRIS? Other ISO and International Standards and European Regulations 3
K Industry Standard for Correcting Dates on Documents US Food and Drug Administration (FDA) 9
D UL / Safety Testing Oscillators - Is there an "Industry Standard"? Reliability Analysis - Predictions, Testing and Standards 3
S Usability standard IEC 60601-1-6 in the Medical Device Industry IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J How to get the International Railway Industry Standard (IRIS) Various Other Specifications, Standards, and related Requirements 5
T International Railway Industry Standard (IRIS) Other ISO and International Standards and European Regulations 4
D Industry Standard for Brazed Joint Integrity - Customer Specification Various Other Specifications, Standards, and related Requirements 1
K What the industry standard is for attribute gage tolerances - In Writing General Measurement Device and Calibration Topics 7
Q ISO/TS 16949 - The Quality Standard for the Automotive Industry IATF 16949 - Automotive Quality Systems Standard 3
Q Industry Standard burr on stamping-is there such a thing? Manufacturing and Related Processes 6
G DPPM Industry Standard - Metal fabrication (Job shop) Misc. Quality Assurance and Business Systems Related Topics 3
P Visual Standard for Watch Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Has anyone heard anything about the Financial Industry standard FS9000 Various Other Specifications, Standards, and related Requirements 5
T QSF 2000 in UK and the US (Australian food industry Standard) - Withdrawn? Food Safety - ISO 22000, HACCP (21 CFR 120) 2
Marc SIC vs. NAICS vs. NACE - Standard Industry Codes Misc. Quality Assurance and Business Systems Related Topics 2
gramps What do you think about automated QA testing For software app industry? Misc. Quality Assurance and Business Systems Related Topics 5
V Certified Auditor - Need of additional certification specific to industry ( GMPs) ASQ vs ECA vs others Professional Certifications and Degrees 1
B Industrial RX inspection of welds (Oil&Gas industry) Reliability Analysis - Predictions, Testing and Standards 0
Revision36 Engineering Change Order Industry Standards Other Medical Device and Orthopedic Related Topics 4
B Quality manual for automotive industry wanted Quality Management System (QMS) Manuals 2
E Non-GMP examples in Pharmaceutical industry Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
DuncanGibbons Are the IQ OQ & PQ procedures applicable to the aerospace industry? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Marc Security in Health Industry Software - February 2020 IEC 27001 - Information Security Management Systems (ISMS) 0
A Complaint alert levels - Industry standards pertaining to alert levels for complaints Customer Complaints 5
S Industry Labelling Standards - non medical Manufacturing and Related Processes 0
C Looking for APQP Training recommendations preferably in the aerospace industry APQP and PPAP 2
R Bill of Materials for a complex product - Industry best practice ISO 13485:2016 - Medical Device Quality Management Systems 2
R Risk Management in the Medical Device Industry ISO 14971 - Medical Device Risk Management 4
