Influence of the Coverage Factor - Worksheets based on the Average and Range Method
Depo74
Good morning everyone
I dicovered this forum two weeks ago and it helped me a lot to understand this manual. :thanx:
But, since I try to make my own worksheets based on the Average and Range Method, I need need some help. Indeed, I don't see clearly how the coverage coefficient k (5.15 or 6 for instance) affects the results of the %GRR.
According to the formulas p191, %GRR based on Process variation is given by (k * sigma_measure)/(6 * sigma_observed)*100%
So, i would like to know if the number 6 is always constant or if it depends on the value of this k
I assume the formulas given in %GRR report p.114 are already simplified with a k=6 and this is why %GRR is equal to sigma_meausre/sigma_observed but i would like someone to confirme that
And at last, are these observations true for the Anova Method ?
Thanks for your help ( and sorry for my English)
Hershal
Metrologist-Auditor
Re: Influence of the coverage factor
I suspect someone with more knowledge in this application will answer soon.
I assume the formulas given in %GRR report p.114 are already simplified with a k=6 and this is why %GRR is equal to sigma_meausre/sigma_observed but i would like someone to confirm that
The value of k depends on the number (5.15 or 6). 5.15 represents 99% of the measurement variation and is older usage. The current usage is 6, and you are correct, the formulae have been update to take 6 into account.
The ANOVA method does not use the k factors. It calculates sigma directly rather than estimating it from the Ranges.
Depo74
Thanks for your answer, but i was asking about the 6 of the denominator of the formula (k*sigma_measurement)/(6* sigma_observed).
And thanks fot the information on the Anova. Actually, I made a confusion between the Variance estimated and the spread of the standard deviation (where k is used to evaluate this spread it seems to me)
Re: Influence of the Coverage Factor - Worksheets based on the Average and Range Meth
For the AIAG MSA manual 2nd edition: The k in the numerator is tied to the 6 (or 5.15) used in the denominator
In the 3rd edition, they simplified the formula by removing the 6 in the denominator. The k factors were adjusted to result in the same answer.
Depo74
Ok, so does it mean the %GRR for process variation will stay the same regardless the K choosen.
It will only affect the %GRR based on the tolerance ?
Correct. The formula for %GGR (% Study Variation) is a straight ratio of standard deviations. Any multipliers such as 6 would appear in both numerator and denominator and would cancel out.
Depo74
Thanks to you, i managed to put the right formulae in my worksheet (I suppose)
I let my work here so, if you mind, you can check it, and since this worksheet has been done be able to do the study with any number of appraisers, parts and tests (even if there is a max), i think it could be useful for some people here
I just hope you understand French
J Tool to measure influence of Quality on Services Rendered ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
N ISO 14001 Control vs. Influence - Environmental Aspects Identification ISO 14001:2015 Specific Discussions 6
J Develop a Customer Survey for Quality - The influence of Quality (ISO) on our Service ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
O The Influence of Environmental Aspects on the Employee Miscellaneous Environmental Standards and EMS Related Discussions 11
Sidney Vianna Should customers influence a supplier's registrar selection? Registrars and Notified Bodies 88
D Purchasing clarification - Processes with indirect influence on product delivery Design and Development of Products and Processes 12
B ISO9001 - A business case (selling the idea) to influence a management committee ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
G Environmental Issues - Indirect (influence)/ Direct Aspects Miscellaneous Environmental Standards and EMS Related Discussions 6
P What influence have Juran Deming & Crosby had on the retail sector Philosophy, Gurus, Innovation and Evolution 1
J To Decide Which Factor has the Highest Influence on the Results Using Minitab Software 3
Sidney Vianna Cultural influence and "lineage" of Quality Systems Misc. Quality Assurance and Business Systems Related Topics 26
S Aspects which an organisation can influence - ISO 14001 ISO 14001:2015 Specific Discussions 2
B Gage R&R for Automatic Test Systems - No operator influence on readings Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Coverage and differences: EN 60601-1:2006+A12:2014 Vs AAMI/IEC 60601-1:2005+AMD1:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Impact of an MDSAP certificate with all countries coverage Other Medical Device Regulations World-Wide 8
A Internal Audit - Coverage for ISO 9001:2015 Internal Auditing 4
A Coverage factor in calibration certificate for a multimeter General Measurement Device and Calibration Topics 4
B ISMS Certified - Any requirement for Insurance Coverage for Infrastructure Assets? IEC 27001 - Information Security Management Systems (ISMS) 4
K ISO9001:2008 Internal Audit Period Coverage Internal Auditing 18
J Code Coverage in VHDL and Verilog for Medical Devices IEC 62304 - Medical Device Software Life Cycle Processes 17
V Coverage of Process Failures in dFMEA (Scope/Boundaries for Inclusion) & vice versa Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
DanteCaspian Operator Break Coverage - Custom injection mould shop Manufacturing and Related Processes 9
G Coverage of ISO 14001 within an organization - Implementation ISO 14001:2015 Specific Discussions 5
N Painting experts: Coverage area for each litre of paint and thinner mix Manufacturing and Related Processes 5
C ISO 14001 Coverage and exclusion - Testing of electonics devices ISO 14001:2015 Specific Discussions 2
B Opinions on the best conference to go to in terms of ISO 14001 coverage ISO 14001:2015 Specific Discussions 7
S Minitab - Factor Analysis: Label on second series of data for Biplot Using Minitab Software 4
S Is Human Factor Testing required as part of Design Control Validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
V Using K-Factor(Tolerance Interval) Analysis for Design Verification Statistical Analysis Tools, Techniques and SPC 3
C FOS (Factor of Safety) Medical Device Other Medical Device and Orthopedic Related Topics 4
E IEC 60601-1 Tensile Load Safety Factor IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E GR&R ANOVA 3rd Factor for Fixture Nests Using Minitab Software 3
N 3 factor - 3 level experiment with DoE and Minitab Using Minitab Software 10
S Human Factor Summative Study Class III Device RA Checklist wanted Human Factors and Ergonomics in Engineering 2
M DOE: Significant factor or not Using Minitab Software 2
F Can be several measurement in a repl considered as nested factor in Minitab analysis Using Minitab Software 14
M Taguchi Analysis of Discrete Factor Using Minitab Software 10
N Minimum Design factor for CE Marking for machinery CE Marking (Conformité Européene) / CB Scheme 2
G Setting up a 3 Factor, 2 Level,2 response DOE in Minitab Using Minitab Software 7
Z A DOE in Minitab - 3 factors and 3 levels for each factor Using Minitab Software 12
R How do I extend Correction factor of Calibration cert to compute instrument accuracy Measurement Uncertainty (MU) 1
B DOE Question: 3 factors with 2 levels and 1 factor with 3 levels Six Sigma 2
Z Help with running 3 factor DOE factor optimization Using Minitab Software 2
P Help Setting Up and Analyzing 3 Factor 2 Level Full Factorial Design for DOE Using Minitab Software 3
C 3 Factor DOE (Design of Experiments) Template Document Control Systems, Procedures, Forms and Templates 0
P How to analyze DOE: 2 Factor, 4 Level Experiment Six Sigma 7
J DOE Analysis Experiment, 5 factors, 4 factors having 3 levels, and 1 factor having 5 Using Minitab Software 38
M Multi-factor Anova with Minitab Using Minitab Software 1
K Human Factor Assessment for IRB (Institutional Review Board) Approval? EU Medical Device Regulations 7
I Multiple Comparisons for a Random Factor Using Minitab Software 2
