Information about Testing for Microcracking wanted
Ron Rompen
First, a bit of background. We purchase (and assemble) a retainer ring manufactured in NA and also in Europe. We have a history of failure (fracture of the retainer ring) on the NA parts, but not on the EU parts.
Part design is identical, material is different (1075 vs C67S respectively) and heat treat is identical (HV 440-520)
Due to ongoing issues with the NA rings, we are performing some in-depth analysis, one component of which is testing (before and after assembly) for microcracking. This is not a test with which I have any familiarity.
Is there anyone here in the group that could provide some information, and perhaps (offline via private email) act as a sounding board for some of our ideas and conclusions?
Thanks for your help guys.
Stijloor
Can someone help Ron?
Thank you!
Stijloor.
achorste
I wouldn't say I was an expert in this sort of product, however there are a number of NDT methods to detect surface discontinuities.
What surface condition are thae parts supplied in? How big are the cracks you are wanting to detect?
Fluorescent penetrant inspection is a relatively cheap method that could detect surface cracks etc. and magnetic particle inspection also may be an option?
Ron Rompen
Achorste: Surface condition of the parts is not really called out. The parts go through a heat treat (austemper) process, and (for the EU parts) get a subsequent Phos & Oil coating, which would involve a precleaning operation as a part of the process. NA parts do not get the Phos & Oil, so are received 'as-quenched'.
The size of the cracks is part of the concern. My (very limited) exposure to LPI is that it will detect cracks at the macroscopic level (i.e. they are visible to the naked eye if examined under appropriate lighting conditions), the LPI simply serves as an agent to enhance the contrast of the crack to the surrounding surface.
Eddy current testing, from what I have been able to discover, would be more suitable for detecting cracking at the microscopic level, however due to the configuration of the assembly (retainer ring pressed into place over the end of a cross tube, holding a side panel in place, with contact between all three surfaces) I do not believe that it will be very effective.
Thanks for your response, looking forward to hearing more.
achorste
Hmmm.. it would seem that LPI/MPI may not be sensitive enough for your purposes.
I've not had many dealings with anythign more sensitive, so I will bow out at this point, sorry I couldn't be of more help!
PS - I have heard a few mentions of ultrasonic thermography (applying an ultrasonic vibration to a metal & measuring heat changes that develop from material defects due to friction). It may be something to look into but I couldn't give you any more detail than that.
hogheavenfarm
We had a similar situation - we checked out LP, MP, UT, and RT. Of all RT was best but also most expensive, could only be used in small samplings, not on the entire lot.
UT was ok, but required a skilled operator and a specially designed tip for each shape of part, depending on where you wanted the inspection. We ended up using LP, not flourescent, which worked pretty well. Even though the cracks could not be seen, the LP enhanced them enough to be seen with magnification. The surface condition is pretty critical for this however. Ours were polished parts, so they were pretty smooth, if you have a rougher finish, it will be harder to detect what is a crack and what isnt. MP will only work if the part can be magnetized, and even then, will suffer from the same issues as LP (and require degaussing)
M Informational USFDA final guidance – Recommended Content and Format of Non-Clinical Bench Performance Testing Information in Premarket Submissions Medical Device and FDA Regulations and Standards News 0
R Tip Load Testing Information Reliability Analysis - Predictions, Testing and Standards 2
K Where to obtain General Concepts of Total Organic Carbon (TOC) testing information? US Food and Drug Administration (FDA) 2
D Information on Heavy Metal testing in Medical Devices Other Medical Device and Orthopedic Related Topics 6
E Documenting Titration Testing - How much information do I need to include? Other ISO and International Standards and European Regulations 8
D Looking for information on calibration proficiency testing (dimensional) Training - Internal, External, Online and Distance Learning 1
A Can a organization use a disclaimer "pending AS9100 Certification" in Marketing Information? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Watchcat Summary of De Novo Biocompatibility Information, 2015-2018 Other US Medical Device Regulations 0
Q Self-assessment audit information Quality Management System (QMS) Manuals 6
Sidney Vianna Release of ISO 10013:2021, Quality management systems – Guidance for documented information Other ISO and International Standards and European Regulations 0
W How long do you keep information about equipment no longer used? Document Control Systems, Procedures, Forms and Templates 2
R What information do i need to get from the device manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
T Types of confidential information ISO 17025 related Discussions 8
D Preservation of Electronic Data / Information Technology ISO 13485:2016 - Medical Device Quality Management Systems 5
S API Spec.Q1 Standards Version in Purchasing Information Oil and Gas Industry Standards and Regulations 1
R Information on obtaining a market authorization for China China Medical Device Regulations 2
B SN95 Respirator Approval Information Other Medical Device Related Standards 0
R Risk assessment on IT containers and the information they contain IEC 27001 - Information Security Management Systems (ISMS) 4
O EN 301 489-1 and EN 301 489-17 - Where do we get the information of the Published versions? CE Marking (Conformité Européene) / CB Scheme 1
K Article 18: Implant Card and information to be communicated. EU Medical Device Regulations 5
K EU MDR Annex 1 Chapter III: Information in the Instructions for Use-23.4 (e) the performance characteristics of the device; EU Medical Device Regulations 1
A GMDN Registration Basic preliminary Information EU Medical Device Regulations 0
J Controlled information versus defined documents / records ISO 13485:2016 - Medical Device Quality Management Systems 3
A Medical device Reporting : Good Faith Effort for Additional information Other US Medical Device Regulations 2
P Cenelec updated standard information CE Marking (Conformité Européene) / CB Scheme 1
Richard Regalado Automotive News TISAX - VDA ISA (information security assessment) VDA Standards - Germany's Automotive Standards 5
JoCam False information provided for Medical Device Registration - What are the implications? Other Medical Device Related Standards 3
adir88 Information of safety can reduce risk now? ISO 14971 - Medical Device Risk Management 12
Richard Regalado What could go wrong with information: Ransomware statistics and facts (2018 to present) IEC 27001 - Information Security Management Systems (ISMS) 0
Q LOT or Serial Number Symbol not used when the information is contained in the UDI? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Information about Medical Device Test Laboratories Other Medical Device and Orthopedic Related Topics 4
C Missing routers/documented information Nonconformance and Corrective Action 5
MrTetris Unacceptable risk and information for safety ISO 14971 - Medical Device Risk Management 16
M Is Harmonised EN 1041 (Information Supplied By Manufacturer) Worth Looking At? EU Medical Device Regulations 7
P Predicate Device Information for 510(k) Submission Medical Device and FDA Regulations and Standards News 4
A Medical Device Contract Manufacturing Requirements and Information - Help wanted ISO 13485:2016 - Medical Device Quality Management Systems 5
H Analog Pressure Gauge with no EN837 accuracy class information General Measurement Device and Calibration Topics 5
M Informational EU – MDCG 2019-12 Designating authority’s final assessment form: Key Information Medical Device and FDA Regulations and Standards News 0
G What information to put on measurement Dimensional Results APQP and PPAP 7
L MDR - Information in the instructions for use - clausole 23.4.(z) EU Medical Device Regulations 2
K AS9100D Clause 7.5.2.a) - What is considered to be "documented information"? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A Information on good laboratory practices (GLP) for the non-medical or food industry wanted Manufacturing and Related Processes 1
I What kind of information needs to be in a calibration record? General Measurement Device and Calibration Topics 25
M Informational TGA – Medical device patient information leaflets and implant cards Medical Device and FDA Regulations and Standards News 0
