Infusion Pump Power Failure Alarm IEC 60601-2-24
  • Thread starter Michael_ME Engineer
  • Start date
Michael_ME Engineer
Based off my interpretation of clause 201.11.8.101.2, it requires a high priority alarm when both supply mains and the internal battery fails. This alarm shall last for a minimum of 3 minutes.
My question is, how are people meeting this requirement?
It seems to me that to satisfy this requirement there would need to be:
1. An indication that the external DC supply cable was plugged in (charger present)
2. A voltage monitor for the charger voltage input
3. A voltage monitor for the battery voltage (with a reliable threshold of battery fail)
4. A visual indication
5. An audible indication
6. A method of detecting malfunction of the monitor circuit
7. A means of powering this additional circuit such as a capacitor or additional battery
Peter Selvey
It might seem like overkill but this is a critical requirement. Bigger battery packs often fail in a way where they work for a bit but the voltage dies quickly, meaning there is no time for a low battery alarm. This has been a common cause of serious events including death if the infusion pump is delivering a critical drug. It was one of the problems behind the worldwide recall of 250,000 Baxter Colleague infusion pumps.
So, yes in practice this would mean a dedicated independent circuit for the situation, often powered by a smaller NiMH battery or a supercap with a simple piezo beeper type alarm and maybe a pulsed light to save on power. From memory the standard has relaxed requirements for this kind of power failure alarm.
The original designs had batteries that watched themselves, which did not always work - a good lesson on why independence is important in safety designs.
sivasuryan
Hi Peter,
Can you provide me information where exactly the standard had relaxed requirement (so that we can use simple beeper type buzzer) for this kind of power failure alarm. can you recollect it from memory.
Thanks and regards,
R.Sivasuryan
N Dataset for Academic Research - Infusion pump flow IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R Why was Drip-Rate Infusion Pump removed from IEC 60601-2-24:2012? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Infusion Pump - Pre-Clearance Inspections Learnings US Food and Drug Administration (FDA) 4
W How can I test the Patient Leakage Current of an Infusion Pump? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
T Plastic of an infusion pump enclosure and ISO 10993 ISO 13485:2016 - Medical Device Quality Management Systems 2
C Equipotential Grounding Post on an Infusion Pump IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C Casual Contact With Exposed Metal - Infusion Pump - Type CF Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
T Infusion Pump and IEC 60601 2nd edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
R How to Design a Protective System for Infusion Pump IEC 60601 - Medical Electrical Equipment Safety Standards Series 48
F FDA Infusion Pump Public Meeting in Silver Springs, MD - May 2010 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R What Class are Syringe Pump and Infusion Pump? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
A Mechanical Design Procedure - Infusion pump incorporating software - Medical Device Design and Development of Products and Processes 1
R Can the same Biocompatibility Report for Infusion Set be used for its Components? ISO 13485:2016 - Medical Device Quality Management Systems 7
M IEC 60601-2-24 Ed 2.0 (Infusion Pumps Particular Std.) - Redlines IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
T IEC 60601-2-24 for the Safety of Infusion Pumps IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
M What is the Release Date for IEC 60601-2-24 for Infusion Pumps? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
M Medical Device News INMETRO (Brazil) Certification for Syringes, Needles and Infusion Sets Other Medical Device Regulations World-Wide 7
M Infusion Pumps Japan - JIS T 0601-2-24 Japan Medical Device Regulations 5
P Continuous Spinal Infusion Investigational Device Exemption 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
P Biocompatability (ISO 10993 Series) Testing for Infusion Systems ISO 13485:2016 - Medical Device Quality Management Systems 4
R Breast Pump under MDR classified as medical device? EU Medical Device Regulations 9
P Production Line Pump Cleaning Validation Method Question Qualification and Validation (including 21 CFR Part 11) 0
N Applied Parts Classification Clarification - Breast Pump IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Applicability of the standard IEC 60601-2-18 to an arthroscopy pump IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
P 2x MOOP for type B AP - Therapeutic device - Heater/cooler with pump IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
C Device Labeling - Safety Symbols for Washbasin with a Submerged Pump EU Medical Device Regulations 5
C Reliability Testing Protocol on a new Peristaltic Pump Reliability Analysis - Predictions, Testing and Standards 14
C Measuring Flatness of a Pump Cover General Measurement Device and Calibration Topics 14
kedarg6500 Gage R&R for Attribute Data - Pump Noise Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D API Specification Q1 for Pump Jack Oil and Gas Industry Standards and Regulations 1
D Windows CE Operating System - Implantable Blood Pump and a Software Accessory Device IEC 62304 - Medical Device Software Life Cycle Processes 8
D Battery Powered Disposable Pump - What IEC 60601 testing is required, if any? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
P Accessories or Spare Parts need CE MARK? Breast Pump Feed Containers EU Medical Device Regulations 2
G Leak Test - Building a master pump to calibrate pump tester Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Design For Six Sigma (DFSS) Example For Pump Design and Tolerance Quality Assurance and Compliance Software Tools and Solutions 2
Ajit Basrur My iPod, My Cell, My Insulin Pump - Advances of Diabetics Management ISO 13485:2016 - Medical Device Quality Management Systems 1
M Vibration Measurement - Pump Driven by an Electric Motor Misc. Quality Assurance and Business Systems Related Topics 8
K Transport of fuel primed fuel pump, rail lines/ hoses - Legal? Customer and Company Specific Requirements 5
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Judy Abbott The impact of laser power on biocompatibility of the products Manufacturing and Related Processes 6
C Power Supply EN60601-1 vs EN62368-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S DC-AC Power inverter with two MOPPs IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Surge Protectors and other power protection Manufacturing and Related Processes 7
Sidney Vianna Informational APQP4Wind - Advanced Product Quality Planning for the Wind Power Supply Chain APQP and PPAP 3
U Power supply - Change From 160 to 300 Watts - Significant change? EU Medical Device Regulations 2
M MS Power Automate/Sharepoint Files Document Control Systems, Procedures, Forms and Templates 1
O Are power distribution units Multiple Socket Outlets (MSOs)? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
L Medical-grade power adapter labeling Other US Medical Device Regulations 2
