Initial Capability study on N50 parts - Subgroup Size?
Manix
Get Involved!!!
HI I am really asleep today and I have come across a bit of a confusing situation.
If I am doing an Initial Capability study on N50 parts. Should my subgroups be 5 (so 10 subgroups) or 10 (so 5 subgroups)?
I am really trying to figure out the logic, I know it's there but seriously I am still asleep.
I know this is a silly question but please HELP! :eek:
D.Scott
Re: Subgroup Size?
Assuming you have already decided to use an x-bar, range chart, you would typically use a subset of 5. You could use fewer or more in each sample depending on what you wanted to find in the process.
I am assuming you are only looking for the simple answer so I would say 10 sets of 5.
Dave
Manix
Get Involved!!!
Re: Subgroup Size?
Yeah Thanks D Scott.
Just had a coffee and woken up a bit. The confusion arose because I have a form that actually arranges the data into 5 subgroups of 10! Which I would almost never use!
I need to change that! I will use 10 subgroups of 5 :biglaugh:
Statistical Steven
Statistician
Your subsgroup size should be based on some rationale of the production process. Deciding you want to sample 50 pieces then looking for a subgroup size is not necessarily representative of the process. If the process generates 3 pieces an hour, then you might select 3 as your subgroup size since it represents an hour of production. In this case, you might have 20 subgroups each have 3 samples. Let your process dictate your subgroup size. I call this concept (as many of call it too) Rational Subgrouping. Since the variability within subgroups and across subgroups has a meaning (Cpk or Ppk), then the selection of subgroup size is critical!
Darius
:agree1: with Statistical Steven.
Read first about rational subgroup size, the subgroup size must not be taken without taking in account the "rationale" to subgroup and the size of it.
A wrong subgroup size could make the between sample variation smaller than the within sample variation ( as Donald Wheeler said ). In some industries even subgroup of one could be a good option, without any previous knoledge of the kind of industy and sampling conditions one can not safety say to use 5 (the magical number for SPC practitioners:truce:).
Can you elaborate on the kind of industry or process?
How is the sampling, samples per hour,shift,product?
Steven is "spot on" about the rational subgrouping...
A second angle to ponder is the phrase "initial capability". In the States this often means either a random sample of 50 untis with the capability index calculated using the formula with the total standard deviation; NO subgrouping. This approach is typically used on an established process that has little or no historical data or the data is not used in control charts.
The other approach for an intitial study uses the same formula but the sample is not random and the process is not established - it is brand new and the 50 units are often from the initial running of the process.
In both cases subgrouping is not done.
L Basic Need:Initial Capability Study:No critical characteristic on print Statistical Analysis Tools, Techniques and SPC 6
J Initial capability for injection molding part Capability, Accuracy and Stability - Processes, Machines, etc. 6
J How much to charge for helping a startup company with initial ISO 13485 certification? Consultants and Consulting 3
J ISO 13485 System 'soft start' - How to best reflect this in initial audits, management review minutes and other records? ISO 13485:2016 - Medical Device Quality Management Systems 3
H CQI-15 2nd Edition - Date of initial assessment? IATF 16949 - Automotive Quality Systems Standard 3
MrTetris How to qualitatively assess initial probability ISO 14971 - Medical Device Risk Management 4
S Private Label Requirements, Manufacturer's Registration & Initial Importers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Medical Device Initial Importer (DII) Requirements - Delivery Address 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
J AIAG PPAP: 2.2.11.3 Acceptance Criteria for Initial Study (page 9, 4th edition) APQP and PPAP 1
L Why is initial production units, lots, or batches, or their equivalents required for Design Validation? US Food and Drug Administration (FDA) 3
S Initial Importer and ISO 13485 (MDSAP) - Will the US company be included? ISO 13485:2016 - Medical Device Quality Management Systems 1
S Should an Initial Importer separately do Establishment Registration? US Food and Drug Administration (FDA) 1
Y Time gap for First Surveillance Audit of AS9100D after initial certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
T Customer special status and initial IATF certification IATF 16949 - Automotive Quality Systems Standard 12
A Setting initial Expiry Date of an IVD per BS EN 23640:2015 Other Medical Device Related Standards 12
S Registration/Listing; Initial Importer - Private Label w/ Foreign Establishment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
V Inspection of Initial Importer/ Distributor Products and Materials 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
GURU SDI Cleanliness Requirements for Initial Samples Customer Complaints 4
dubrizo Initial Supplier Identification, Review and Controls ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
dubrizo Initial Impressions of Newly Released IATF 16949 Standard IATF 16949 - Automotive Quality Systems Standard 43
C Service and maintenance in an initial importer facility USA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A We passed our ISO TS 16949 initial certification Covegratulations 3
K Initial Samples with dimensional deviation in Serial Production Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
E Addition of Label by Initial Importer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S Struggling with definition of Initial Importer and First Title 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A API Q1 5.6.1.2 - Initial Supplier Evaluation Oil and Gas Industry Standards and Regulations 9
W AS9100C registration - How long does the system have to run before initial audit? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
J Required Audit Days for TS 16949 Initial Certification Audit IATF 16949 - Automotive Quality Systems Standard 1
JodiB Is DCR (Document Change Request) Needed for Initial QMS Procedures? Document Control Systems, Procedures, Forms and Templates 16
4 Initial Environmental Review and Gap Analysis, difference? Miscellaneous Environmental Standards and EMS Related Discussions 8
C DCN or ECN for Initial Release of FMEA & CP and subsequent changes? FMEA and Control Plans 3
JoCam NADCAP Initial Audit Cancellation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
E Initial Registration of an Establishment with FDA US Food and Drug Administration (FDA) 5
W Contract Initial Importer and Order Handling for a Class I Medical Device Service Industry Specific Topics 2
L How to change the status of "Initial Importer" on the FURLS site US Food and Drug Administration (FDA) 1
Q Engineering purchased a new Caliper - 7.6 - Initial Calibration Required? General Measurement Device and Calibration Topics 6
J Customer wants a P-value with our initial Process Studies Statistical Analysis Tools, Techniques and SPC 4
C Is an Initial Environmental Review a must while implementing ISO 14001 ISO 14001:2015 Specific Discussions 5
M 7.5.1.3 Should mentioned examples such as initial run be verified or validated? IATF 16949 - Automotive Quality Systems Standard 1
W How do you determine the initial recall date for instrumentation? General Measurement Device and Calibration Topics 1
K 820.180(b) Record Retention - Does it apply here? We act as the initial Importer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
X General Motors' initial process study requirements APQP and PPAP 1
H Design Control Requirement - Initial Distributor of a Class I Video Laryngoscope US Food and Drug Administration (FDA) 4
M AS9100 Rev C Initial Certification - Determination of Competence AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
N Initial Status Review - Certification to OHSAS 18001 Occupational Health & Safety Management Standards 4
S What's the difference between prototype and initial samples? APQP and PPAP 5
B Fabricated Dry Powder Storage Tank - Initial Cleaning Food Safety - ISO 22000, HACCP (21 CFR 120) 5
I ISO 10993-1:2009 Sensitization (Initial Evaluation Test) vs. USP Other Medical Device Related Standards 3
L IS/TS 16949 Initial Cert. Audit - placed on 3rd party containment with Customer IATF 16949 - Automotive Quality Systems Standard 3
quality1 Initial Supplier Evaluation Method - 7.4.1 Purchasing Process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
