Injection Mold 100% Visual Inspection - Short Shots and Debris not being found
Avogel
I have been in the automotive industry for 12 years now. I always seem to run into the same issues. My new employer (non union) is having an issue with short shots and debris not being found in-process and turning up at the customer.
The process is 100% visual inspection and in alot of cases, because of internal and external containment requirements, it is 200% sometimes 300% visual.
In my experience I would look at this as a systemic issue and would want to ensure that the operators and inspectors are given proper training, tools, lighting, and time to do their visual job. I would look at the process itself and implement 5s Lean, and quality alerts.
Ultimatly the I weed out the bad performers based on evaluations.
After that I always seem to scratch my head. I know that it could be a reflection of the culture, or executive commitment, but how do I report that to the Operations Manager and Owner?
I posted this to hopfully start a thread of ideas and brain storming.
Thanks,
Proud Liberal
From one injection molding quality mgr to another, I think you're looking in the wrong place. The problem isn't the detection rate, it's the occurrence rate. There is something wrong with your process. Talk to your molding technicians.
I've been down your path. The problem is there isn't a big enough stick to beat the operators with. Quality is not an inspection process, it's a design process. There's something in the design of your molding process not up to the task. Check your cushion.
Big Jim
Its the same old story. You don't inspect quality into a part.
That said, I feel you do indeed have something wrong with the operators or inspectors. Can't you track back to the offenders from lot of batch code information? You should be able to pin down the shift, operators, and even machine. If you can't, you need some effort given to set up a more responsive traceability program.
bobdoering
Stop X-bar/R Madness!!
You have pretty much proven your current system is ineffective, so continuing to use it is not going to resolve the issue. It's like having a gas tank with a leak, and you add more gas gages on the dash to fix it. You still need to deal with the process issues that are the root cause of the problem. Sounds like that line item of the FMEA needs some serious review.
Beyond that, you may want to consider other systems for inspecting the parts. Are these issues capable of being detected by weight or other physical attribute? Can they be seen by cameras? Have you tried to get any help from people in the vision system field?
somashekar
Process setting and then uninterrupted cycles are the key things to look for. We had flaps that could be set to divert first few shots into RED bin and the inspector would clear parts in the run when the flap then diverts parts to GREEN bin, and a confirmation inspection is made. Any stop for any reason, and then when start, the flap is set to RED bin again for inspection. 100% inspection is such a waste of time, let alone 200% or 300%. You need to build it into your moulding process based on your tool complexity and tool condition.
tbsiva
In terms of injection moulding process, if the melt cushion of the machine is consistent, the most probable reason for shortfill could be the interruptions in moulding cycle... Better to look into your start/stop procedures of moulding machine and also the effeciency of detection controls available in the moulding shop whenever there are interruptions
P
Phil Fields
Thanks,
Can you convert your findings into $$$$? What is the cost of 100, 200,300% inspection? Cost of possible loss of work due to poor quality?
What is the opportunity cost for improving the process (install cavity pressure transducer), 5s, and training?
Phil
trainerbob
I would be checking the consistency of your injection cylinder strokes. The issue sounds like it is in the equipment, not in the money wasting inspection processes. You are not pushing enough or you are pushing too much material into the mold. Inspection cannot fix that. Machinery PM, setup, etc. That is where I would be looking.
shantelwhite
You can not inspect quality into a part. Look at the process to see if there is anything that can be done to fix the issues.
A How to set up Continuous CpK monitoring of an injection mold process Reliability Analysis - Predictions, Testing and Standards 7
R Can somone walk me through the IQ/OQ/PQ process for a new injection molding mold? Manufacturing and Related Processes 3
A Plastic Injection Molding - Post Mold Labeling Manufacturing and Related Processes 3
F Capability for a Injection Mold Machine (35 Cavities) Capability, Accuracy and Stability - Processes, Machines, etc. 17
V PPAP 7 of 8 Cavities after an injection mold die repair? APQP and PPAP 7
H How to integrate ISO/TS 16949 & ISO9001 Quality Systems - Plastic Injection Mold IATF 16949 - Automotive Quality Systems Standard 7
L Injection Moulding - Definitions of T0, T1 Samples produced from new mold tooling Manufacturing and Related Processes 11
triathlonx13 Injection Mold Processing Temperature for Vythene 11UMB-68 Manufacturing and Related Processes 1
P Short Molding Issue - Plastic Injection Molding from a Multi Cavity Mold Quality Manager and Management Related Issues 13
J Plastic Injection Molding Mold Change - PPAP Process Question APQP and PPAP 8
K Plastic mold injection manufacturing - Quality Manual examples please Quality Management System (QMS) Manuals 7
D Measurables for Plastic Injection molding process Manufacturing and Related Processes 1
D Continuous Improvement Plan - Plastic injection molding IATF 16949 - Automotive Quality Systems Standard 1
L Purge - Injection Molding Processes Manufacturing and Related Processes 5
D Classification of Syringe (nozzle) of needle free injection system. EU Medical Device Regulations 8
C Clean room injection molding, raw material mixing requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
C Raw material Mixing / Preparation for clean room class C injection molding Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
Z Operational Qualification for Injection Molding Supplier Quality Assurance and other Supplier Issues 6
J Looking for FMEA plastic injection molding FMEA and Control Plans 8
L Injection Moulding Process (Special Process) Validation Food Safety - ISO 22000, HACCP (21 CFR 120) 2
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
J Injection molding: specific perimeters Manufacturing and Related Processes 14
S Change notice while switching to injection molding technique for manufacturing EU Medical Device Regulations 1
J Help with Arburg Allround 320s Injection Molding Machine Manufacturing and Related Processes 3
P Injection Molding Machine Validation Scope Capability, Accuracy and Stability - Processes, Machines, etc. 6
J Dimension control on injection molding parts Manufacturing and Related Processes 19
J Initial capability for injection molding part Capability, Accuracy and Stability - Processes, Machines, etc. 6
A Maximum bubble volume for subcutaneous injection IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
V Clarification of Injection part shrinkage ratio Manufacturing and Related Processes 1
A Plastic Injection Molding Process Troubleshooting Guide Manufacturing and Related Processes 1
L Injection & Extrusion Process FMEA FMEA and Control Plans 1
N Injection Molding - Median individual control charts Statistical Analysis Tools, Techniques and SPC 6
S What is appropriate PPM level for a Plastic Injection Moulding Supplier Quality Tools, Improvement and Analysis 4
J Validating multiple injection molding machines efficiently ISO 13485:2016 - Medical Device Quality Management Systems 5
F Plastic Injection Moulder - Design exemption from AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
M Interpretation of Plus/Minus Draft - Injection Molded Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
P Cosmetic Inspection of Plastic Injection Molded Parts Manufacturing and Related Processes 5
P Retrospective Plastics Injection Molding Process Validation Quality Manager and Management Related Issues 2
D What to look for in a well run Injection Molder Manufacturing and Related Processes 11
M Injection Molding Machine Software Validation Calibration and Metrology Software and Hardware 2
J Rheumatology Injection Device Other Medical Device and Orthopedic Related Topics 6
J SPC for Plastic Injection Molded parts Capability, Accuracy and Stability - Processes, Machines, etc. 8
M SMED - 2750 Ton Injection Molding Machine Benchmark Benchmarking 3
A Root Cause of Injection Part Chipped with AS (SAN) Material Manufacturing and Related Processes 3
M Injection Moulding Minitab DOE - All P Values are 0 Using Minitab Software 7
B FDA Guidance on Metal Injection Molding process validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
A Determining Critical Tests for my Injection Plastic Molding Supplier Reliability Analysis - Predictions, Testing and Standards 4
D Risk Based Inspection: Injection Molding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
N Injection Molded Nylon Part Tolerances Manufacturing and Related Processes 6
E Piping for Injection Water - Regulated or not & can welded or seamless pipe be used? US Food and Drug Administration (FDA) 9
