Injection Molding Machine Validation Scope
Can someone provide list of requirements needed to validate molding machine only?
Or provide a document or link for the information?
Thanks,
Golfman25
If I was only concerned about the machine I would want validation that it can maintain temps., injection speeds, and transfer positions.
Marc
Hunkered Down for the Duration
Agree - Been there - Done that. Were it me, yes. OP - Think of it this way - What are your critical process equipment parameters.
I can't speak to software validation in this scenario. Hopefully someone else can.
Typically, you need to verify all the "usual suspects" safety, power supplied, etc. Also, modern injection molding machines (IMM) that I've worked with and validated include PLC software which typically must be validated also. This software is typically validated by a "Black Box Test", essentially ensuring that the machine output is what's expected give specific machine inputs. The first step in this software validation would be to determine what you consider to be critical parameters. I would suggest that injection location (distance), screw rotational velocity, perhaps a pressure and a temperature that are setpoints. Then you need to determine how you will ensure that you are getting the desired output for a given input setting. For most machines, your input will be translated by the software into an analog signal that controls the necessary servos, etc., but you may need to check with the machine manufacture to determine how and where to measure this and how the analog signal relates to the input. For example, on one of our Milacron IMMs there is an analog card where the signal can be measures and the signal ranges from 0 to 10 volts linearly with minimum and maximum screw rotational velocity, etc.
leftoverture
Thanks,
The first question I have for you before replying is what are you trying to validate and for whom? In other words, what is your goal for validation? If you can tell us that, I think we can better hone in on what the requirements for your specific scenario might be.
J Help with Arburg Allround 320s Injection Molding Machine Manufacturing and Related Processes 3
M Injection Molding Machine Software Validation Calibration and Metrology Software and Hardware 2
M SMED - 2750 Ton Injection Molding Machine Benchmark Benchmarking 3
D Is there any software for making an Injection Molding Machine Schedule? Lean in Manufacturing and Service Industries 5
S Machine Capability (Cm) for Plastic Injection Molding Capability, Accuracy and Stability - Processes, Machines, etc. 1
R Robust Test for Two Data Sets - Tooling on an Injection Molding Machine Statistical Analysis Tools, Techniques and SPC 2
M SPC from Each Cavity? Small Plastic Parts using Injection Molding Machine Statistical Analysis Tools, Techniques and SPC 5
L Purge - Injection Molding Processes Manufacturing and Related Processes 5
C Clean room injection molding, raw material mixing requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
C Raw material Mixing / Preparation for clean room class C injection molding Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
Z Operational Qualification for Injection Molding Supplier Quality Assurance and other Supplier Issues 6
JT3M Looking for FMEA plastic injection molding FMEA and Control Plans 6
J Injection molding: specific perimeters Manufacturing and Related Processes 14
S Change notice while switching to injection molding technique for manufacturing EU Medical Device Regulations 1
J Dimension control on injection molding parts Manufacturing and Related Processes 19
J Initial capability for injection molding part Capability, Accuracy and Stability - Processes, Machines, etc. 6
A Plastic Injection Molding Process Troubleshooting Guide Manufacturing and Related Processes 1
N Injection Molding - Median individual control charts Statistical Analysis Tools, Techniques and SPC 6
R Can somone walk me through the IQ/OQ/PQ process for a new injection molding mold? Manufacturing and Related Processes 3
J Validating multiple injection molding machines efficiently ISO 13485:2016 - Medical Device Quality Management Systems 5
A Plastic Injection Molding - Post Mold Labeling Manufacturing and Related Processes 3
P Retrospective Plastics Injection Molding Process Validation Quality Manager and Management Related Issues 2
B FDA Guidance on Metal Injection Molding process validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
A Determining Critical Tests for my Injection Plastic Molding Supplier Reliability Analysis - Predictions, Testing and Standards 4
D Risk Based Inspection: Injection Molding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
F Injection Molding Weight Control Systems Document Control Systems, Procedures, Forms and Templates 2
A Molding Release for Medical Plastic Injection Molded Parts 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Plastic Injection Tooling - Understanding Plastic Injection Molding Terms Manufacturing and Related Processes 4
K Which chart to use and how to plot it? Injection Molding Production Statistical Analysis Tools, Techniques and SPC 5
K Defect Detection for Fresh Injection Molding Solid Parts Manufacturing and Related Processes 5
W Injection Molding Validation Required or Not - FDA QSR 820.75 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
K How to start Implement SPC for Injection Molding Process? Statistical Analysis Tools, Techniques and SPC 24
R Injection Molding - Resin Drying Specification for EASTMAN Tenite Propionate 385A Manufacturing and Related Processes 6
L Interpreting Injection Molding Tooling Documents - Cavities Manufacturing and Related Processes 3
A Moving Equipment (Injection Molding Machines) in the Plant - Revalidation Required? ISO 13485:2016 - Medical Device Quality Management Systems 7
A TQPC (Total Quality Process Control) for Injection Molding Quality Manager and Management Related Issues 4
M Injection Molding Engineering Process Control Statistical Analysis Tools, Techniques and SPC 19
H Checklist to Audit an Injection Molding Process needed Supplier Quality Assurance and other Supplier Issues 6
D Plastic Injection Molding: ISO9001 or ISO13485? Manufacturing and Related Processes 10
B Injection Molding Capability Studies for PPAP Submission Capability, Accuracy and Stability - Processes, Machines, etc. 19
triathlonx13 Plastic Injection Molding Specification (Purchasing, Qualifying, validation) examples Document Control Systems, Procedures, Forms and Templates 2
B Process Validation Protocol for Injection Molding - Looking for training resource Book, Video, Blog and Web Site Reviews and Recommendations 1
S Operational Qualification for injection molding process Qualification and Validation (including 21 CFR Part 11) 2
M PFMEA for an injection molding process FMEA and Control Plans 1
B Injection / Blow Molding Process Evaluation Document Control Systems, Procedures, Forms and Templates 5
Q Validation Guidance - Plastic Injection Molding Process Qualification and Validation (including 21 CFR Part 11) 34
T Value of Regression Analysis in a plastic injection molding atmosphere Statistical Analysis Tools, Techniques and SPC 4
H ISO 13485 for customer injection molding ISO 13485:2016 - Medical Device Quality Management Systems 8
O Significant Environmental Aspect - Emissions to the Air (injection molding process) Miscellaneous Environmental Standards and EMS Related Discussions 8
CalRich How to display color chips - Injection molding color verification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
