Injection Molding - Resin Drying Specification for EASTMAN Tenite Propionate 385A
rogerheffington
This might be a little off the subject here:
Does anyone happen to know where to find the injection molding drying specification for EASTMAN Tenite Propionate 385A? This information is not available on product their data sheet.
Check this out: I called EASTMAN and I was told, even though we're a customer (purchased through a vendor), I couldn't talk to their technical people. I applaud Eastman! They have so many customers that they afford to ostracize existing customers.
Venting over now. Seriously though, if anyone can help I'd really appreciate it.
rogerheffington
Thank you very much! I actually already have that doc. They do give typical drying times, but, unlike on their other specs sheets, they do not include the moisture spec.
I'm afraid that of we cannot qualify this material, we will have to turn to another mfg that is more willing to give us information.
"In the absence of facts, the mind indulges in fantasy."
K
Kevino
In processing the Eastman Tenite CAP you'd want the moisture content as measured after drying to be .04% or less. Following their suggested dry times which are dependent on 1) your building ambient temps & humidity, and 2)throughput per hour-- you should have no problems achieving a .03 or less consistently.
Obviously you'll need a moisture analyzer to measure moisture content.
Out of curiosity, what alternate materials are being considered?
rogerheffington
Kevin, thank you very much for your reply. There are many good folks at Elsmar!
I am still confused. Eastman did put out a little guide that says "generally" the resin should be dried to 0.25%. Other resins of a similar nature have a 0.1% spec. To add to the confusion, I have been unable to obtain a MSDS. Plus, now I have heard that it is a custom material. This is kind of a mess.
I guess that's why they pay me that $1/day, yes?
K
Kevino
I may have fat-fingered the keypad on my original note-- I meant the moisture content when dried would generally be less than .3 (the 0.25 Eastman shows rounded-up).
I believe the formulation you are considering the 385A is an Injection Molding "Basic" formula with added mold release agents and of the HT variety- (superstabilized for high-temp processing).
A typical use for this series is in manufacturing eyeglass frames/temples, etc. & most of the time a UV stabilizer is added to the base resin compound.
Additional info such as the MSDS can be retrieved at the Eastman website= http :// eastman .com /products/pages/polymers.aspx - DEAD - 404 - LINK UNLINKED
You should find the MSDS for #358/380/ & 385 almost identical.
Good luck with your search!
p.s. You should:whip: your resin distributor/supplier for not getting you this info sooner.
rogerheffington
I finally did get the MSDS from the vendor. Turns out, Eastman does not publish a drying spec for any of their materials. They have this brochure thing that says the "generally" the moisture should be <0.25%.
We some tests and came up with our own spec. We found that the Novatec dryer would dry the material way below our <0.10% specification for our other materials-so we went with that.
I really appreciate your help though-you gave me something to think about which lead to the answer!
D Measurables for Plastic Injection molding process Manufacturing and Related Processes 1
D Continuous Improvement Plan - Plastic injection molding IATF 16949 - Automotive Quality Systems Standard 1
L Purge - Injection Molding Processes Manufacturing and Related Processes 5
C Clean room injection molding, raw material mixing requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
C Raw material Mixing / Preparation for clean room class C injection molding Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
Z Operational Qualification for Injection Molding Supplier Quality Assurance and other Supplier Issues 6
J Looking for FMEA plastic injection molding FMEA and Control Plans 8
J Injection molding: specific perimeters Manufacturing and Related Processes 14
S Change notice while switching to injection molding technique for manufacturing EU Medical Device Regulations 1
J Help with Arburg Allround 320s Injection Molding Machine Manufacturing and Related Processes 3
P Injection Molding Machine Validation Scope Capability, Accuracy and Stability - Processes, Machines, etc. 6
J Dimension control on injection molding parts Manufacturing and Related Processes 19
J Initial capability for injection molding part Capability, Accuracy and Stability - Processes, Machines, etc. 6
A Plastic Injection Molding Process Troubleshooting Guide Manufacturing and Related Processes 1
N Injection Molding - Median individual control charts Statistical Analysis Tools, Techniques and SPC 6
R Can somone walk me through the IQ/OQ/PQ process for a new injection molding mold? Manufacturing and Related Processes 3
J Validating multiple injection molding machines efficiently ISO 13485:2016 - Medical Device Quality Management Systems 5
A Plastic Injection Molding - Post Mold Labeling Manufacturing and Related Processes 3
P Retrospective Plastics Injection Molding Process Validation Quality Manager and Management Related Issues 2
M Injection Molding Machine Software Validation Calibration and Metrology Software and Hardware 2
M SMED - 2750 Ton Injection Molding Machine Benchmark Benchmarking 3
B FDA Guidance on Metal Injection Molding process validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
A Determining Critical Tests for my Injection Plastic Molding Supplier Reliability Analysis - Predictions, Testing and Standards 4
D Risk Based Inspection: Injection Molding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
F Injection Molding Weight Control Systems Document Control Systems, Procedures, Forms and Templates 2
A Molding Release for Medical Plastic Injection Molded Parts 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Plastic Injection Tooling - Understanding Plastic Injection Molding Terms Manufacturing and Related Processes 4
K Which chart to use and how to plot it? Injection Molding Production Statistical Analysis Tools, Techniques and SPC 5
K Defect Detection for Fresh Injection Molding Solid Parts Manufacturing and Related Processes 5
W Injection Molding Validation Required or Not - FDA QSR 820.75 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
K How to start Implement SPC for Injection Molding Process? Statistical Analysis Tools, Techniques and SPC 24
L Interpreting Injection Molding Tooling Documents - Cavities Manufacturing and Related Processes 3
A Moving Equipment (Injection Molding Machines) in the Plant - Revalidation Required? ISO 13485:2016 - Medical Device Quality Management Systems 7
A TQPC (Total Quality Process Control) for Injection Molding Quality Manager and Management Related Issues 4
D Is there any software for making an Injection Molding Machine Schedule? Lean in Manufacturing and Service Industries 6
S Machine Capability (Cm) for Plastic Injection Molding Capability, Accuracy and Stability - Processes, Machines, etc. 1
M Injection Molding Engineering Process Control Statistical Analysis Tools, Techniques and SPC 19
H Checklist to Audit an Injection Molding Process needed Supplier Quality Assurance and other Supplier Issues 6
D Plastic Injection Molding: ISO9001 or ISO13485? Manufacturing and Related Processes 10
B Injection Molding Capability Studies for PPAP Submission Capability, Accuracy and Stability - Processes, Machines, etc. 19
triathlonx13 Plastic Injection Molding Specification (Purchasing, Qualifying, validation) examples Document Control Systems, Procedures, Forms and Templates 2
B Process Validation Protocol for Injection Molding - Looking for training resource Book, Video, Blog and Web Site Reviews and Recommendations 1
S Operational Qualification for injection molding process Qualification and Validation (including 21 CFR Part 11) 2
M PFMEA for an injection molding process FMEA and Control Plans 1
B Injection / Blow Molding Process Evaluation Document Control Systems, Procedures, Forms and Templates 5
Q Validation Guidance - Plastic Injection Molding Process Qualification and Validation (including 21 CFR Part 11) 40
T Value of Regression Analysis in a plastic injection molding atmosphere Statistical Analysis Tools, Techniques and SPC 4
H ISO 13485 for customer injection molding ISO 13485:2016 - Medical Device Quality Management Systems 8
O Significant Environmental Aspect - Emissions to the Air (injection molding process) Miscellaneous Environmental Standards and EMS Related Discussions 8
CalRich How to display color chips - Injection molding color verification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
