In our quest to gain ISO 9001:2000 certification I have run into this obstacle.
We are a company that prints folding cartons and pressure sensitive labels with approximately 50 employees.
Our raw materials used are basically ink and a substrate to print on.
The substrate that we use for pressure sensitive labels comes from a large international company. We use several different kinds. All of their data sheets state:
Shelf Life:
One year when stored at 72°F at 50%RH
The material identification includes the production date.
The problem is that we have material on hand (and probably always will have from time to time) that has surpassed the shelf life date. Purchasing substrates always leaves you with some on hand and it’s too expensive to throw away. The material always checks out to be ok and we have always used it in production. Basically if the ink adheres to the substrate and the adhesive is sufficient that’s all there is to it. Naturally we will not use any bad material in our jobs.
The auditors have seen the data sheet and have seen the material. Of course they say that the material should not be used (its nonconforming since it’s shelf life has expired).
The auditors say that in order to use the material that we should write an “internal concession”.
Try as I might, I have been unable to find any information relative to an “internal concession” for this purpose.
My questions to the forum are:
1. Do we need to have these data sheets on file (so as to prevent even messing with this)?
2. What is an “internal concession” and how do you go about it?
3. Are there other ways that someone might know of to handle this problem?
Naturally we do not want to create additional procedures, extra forms, more records, etc. to work around a problem that we feel does not exist in the first place.
We have talked to the supplier about this and they say that the shelf life is to primarily reduce any quality claims to a manageable time frame. They will not put this in writing.
We also do not want to broach the topic with our customers as you can imagine what a can of worms that would open up.
If anyone has any examples of “internal concessions” that might help please email them to my home office:
Thanks in advance for your help.
John Jewell
Shelf Life:
John Jewell
