cfordyce05
What is the industry standard for the method of inspecting a die cut gasket? We are trying to inspect with an optical CMM. Our customer provided a drawing with a parasolid file for the gasket but the profiles are made up of splines instead of lines and arcs. The software cannot inspect a surface profile with splines. Should the drawing really have a line profile tolerance instead of the surface profile tolerance? The gasket is only .015in thick. The only dimensions on the drawing are a true position on 4 bolt holes and an all around profile tolerance of .010 on the inner and outer gasket profiles.
Thank you,
Casey
Thank you,
Casey
