Inspecting Full Thread Depth with a Plug Gage
Thetree
Hello all,
What is the correct way to use a thread plug gage to inspect the depth of a threaded hole? One of my guys thinks you should check to the end of the plug gage because the truncated thread is basically replicating the same engagement length you would get with a threaded part with a chamfer on it. My inspector always puts the gage on the comparator to check the length of the plug gage from the start of the truncated thread. His reasoning is that the print calls for example ".88 min full thread" so you have to inspect from the start of a full thread. I can see both arguments as being reasonable but I was hoping for some guidance.
Thanks for any input you can offer. -Dan
Michael_M
Re: Inspecting full thread depth with plug gage
I always measure from the first thread. The 'lead' on the thread gage may or may not be the same depth as the chamfer and that would only count if you 'count turns' not use a comparator to measure overall length.
H
Hodgepodge
Hello all,
...My inspector always puts the gage on the comparator to check the length of the plug gage from the start of the truncated thread. His reasoning is that the print calls for example ".88 min full thread" so you have to inspect from the start of a full thread. I can see both arguments as being reasonable but I was hoping for some guidance.
If you do it this way you won't mistakenly accept a thread that is out of tolerance.
Thetree
We also get "max full thread" so that is not exactly the case.
Is there a written guideline anywhere that could be printed as a "gauging instruction" and posted in inspection or put into our quality manual that specifically spells out the proper way to use a plug gage to inspect a thread depth?
"two guys on this forum say it is the right way to do it" rarely goes over well.
Maybe we could check all the gages and etch them with the gage length to save a step? Do you guys do this or just check them every time?
Thanks, Dan
O Inspecting paint and having workable standards in the supply chain Supplier Quality Assurance and other Supplier Issues 1
R Inspecting straightness tolerance of .00005" on a shaft Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
S AS9102 FAI requirements - Inspecting with fixtures, templates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
P Inspecting a difficult part - Measuring the centre of a hole to the edge of a rod Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
F How to convert inches to degrees - Inspecting the perpendicularity of 2 lines Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Inspecting a Profile Tolerance for a Die Cut Gasket Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Is Rework "Inspecting Quality In"? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
Q Inspecting Total Runout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
K Inspecting a Length of Weld - High Reject Rates Manufacturing and Related Processes 7
K Probe on CNC machine - Inspecting on cnc machine tools vs. CMM Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
U Which Sampling Plan should I use? Inspecting & Dimensionally Measuring Products Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
C What to look for when inspecting incoming packaging goods such as empty retail boxes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Inspecting Outside Radii of a Small Steel Stamping Inspection, Prints (Drawings), Testing, Sampling and Related Topics 26
K Inspecting subcontracted manufacturing of garments, wearing apparel Manufacturing and Related Processes 5
ScottK Inspecting surface finish on SS on a piece that can't be measured with current equip. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Sampling - Measuring and Inspecting a part with both Variable & Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
D DNV Standards for inspecting offshore containers and baskets Various Other Specifications, Standards, and related Requirements 5
Y Inspecting Glued Components - Bubble size - Medical Device Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Y Inspecting Quality into Product - How to react? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
J Inspecting one at a time is quicker? Lean in Manufacturing and Service Industries 6
Claes Gefvenberg What if the inspector isn't inspecting? NASA inspector indicted Inspection, Prints (Drawings), Testing, Sampling and Related Topics 26
N Proper use of the Blueing process when inspecting the taper of bushings General Measurement Device and Calibration Topics 6
J Proper use of gauge pins - Inspecting thru holes of plastic parts General Measurement Device and Calibration Topics 19
Q Full or Partial FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
F Grand Avenue Software, Q-Pulse or Qualio - which for a full eQMS? Medical Information Technology, Medical Software and Health Informatics 1
V Process, component or full product re-qualification: leaded to unleaded solder Qualification and Validation (including 21 CFR Part 11) 8
A When there is a 2 year lapse in production, is a full FAI required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K Implant Card - Full Manufacturer's Address - Space issues EU Medical Device Regulations 4
A ISO 9001 lead auditor as Full time career India Career and Occupation Discussions 2
Sidney Vianna ANSI acquires full ownership of ANAB - December 2018 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 0
P AS9102 full FAl or a partial FAI after production inactivity period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L Is writing out the ISO9001:2015 standard full name a requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
Tagin Does ISO 9001:2015 require a full internal audit annually? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
M Bringing blending in-house - Verification or full validation? (Disinfectants) ISO 13485:2016 - Medical Device Quality Management Systems 3
R ISO 13485:2016 Registration - NC on full cycle of internal audits ISO 13485:2016 - Medical Device Quality Management Systems 7
H Do you have to perform an full internal prior to IATF 16949 audit? IATF 16949 - Automotive Quality Systems Standard 21
C Full QMS Audit and Internal Audit Question ISO 13485:2016 - Medical Device Quality Management Systems 16
F MDSAP vs "Full" FDA Requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Malaysia - Full Labelling Local Language Translation Other Medical Device Regulations World-Wide 1
Marc How did you "get" a full-time job? (A 2017 discussion) Career and Occupation Discussions 11
J Use of Harmonised Standards (Full or Partial) ISO 13485:2016 - Medical Device Quality Management Systems 1
O AS9100 AQMS AEA Qualification Audits 4 Full QMS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S OBL (Own Brand Labeling) - Full Quality to Production Quality EU Medical Device Regulations 5
S IEC 60601-2-27: What does "linear within ±20% of the full scale output" mean? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
S When to switch from a Partial AS9102 back to a Full AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Y Is CFDA registration required if the full system is registered by our distributors? China Medical Device Regulations 2
V General Full Factorial - Optimal Design Six Sigma 2
O Is a full Internal Audit cycle every year required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
K Half-Fractional vs. Full Factorial Central Composite Design Using Minitab Software 6
K Experiments Using Full Factorial Design Using Minitab Software 12
