Inspecting Total Runout
Q
qcchick
I am I silly for requiring the Total Runout be checked 100% on a new build prototype of a welded assembly? The assembly has many variables that contols cannot be determined in a single build cycle. Due to the complexity of the welded assembly and the fact that the runout tolerance is critical I feel it should be checked on each part. There are only 36 pcs. I am having a hard time conveying this point to one of our new engineers who thinks that if we build one part that "in theory" the next one will be exactly the same. (booksmart with very little practical experience). I feel if we can ensure that in the first build we are meeting the runout requirement that then we can establish process contols and decide on a sampling size for future builds. This assembly involves welding a rectangluar part that consists of 2 seperate parts with 2 welded inserts that hold a machined shaft. The shaft mounts to a bearing and the whole assembly will spin. The total runout tolerance is only .030" which isn't much granted the variables that could occur in the manufacutring process. Just would like opinions on how I can convey this properly with tact. This person's opion is that we should only have to check it one time and if it is good then the rest will also be good. (If it was that easy we wouldn't need process controls right?)
The Specialist
You are correct that you cannot rely on 'in theory' methodology for quality control.
It is possible that a small % (in process checks) could be used instead of 100% inspection, however, you will first have had to demonstrate through documented testing that you have a stable process (validation excersise).
IPC (% checking) can then be used mearly to demonstrate that the process is maintained (stable) during a specific process run.
If you intend to do a lot of these process runs, it may be worth taking this route.
If this is a one-off or rare process, it may be easier/less time-consuming to carry on with your current 100% inspection method.
Markaich
My understanding is that this would relate to the introduction of a new product to manufacturing.
As part of this introduction, you would need to collect sufficient data regarding the processes' capability (Cp & Cpk) of consistently achieving the 0.030" tolerance. While 100% may seem a large sample, on only 36 parts the sample size would need to be of this order to ensure that the statistical analysis was relevant.
If the process can be shown to be capable, then the number of parts measured can be reduced, with occaional samples taken using SPC to 1) show the continued capability of the process and 2) to warn if the process was going out of control.
In my experience, 'engineers' (particuarly those of the design rather than manufacturing variety) do not understand the concept of natural variation, irrespective of book learning or experience.
One way of reducing variation would be to machine the bearing holes after welding so that the variation intruduced through that rather variable process is eliminated.
Hope this helps
We've often heard of busy managers telling their underlings, "Don't come to me with problems--come to me with solutions." My experience has been that when it comes to engineers in general, and design engineers especially, the reverse is true. Even if you know the answer, it's usually best to let the engineer think it was his idea. While it might be too late in this instance, what you should do is go to the engineer with a dilemma--you have this runout requirement and there are multiple variables to deal with--and let her (with a little directing help from you) develop the solution.
As it stands presently, the best you can do is explain the variables and how before you can settle on a verification strategy you have to understand--through measurement--how they all should be controlled.
Aliveguy
I agree with you qcchick !! It is always wise to add inspections in an effort to show process stability and efficacy.
I suggest being easy on your work associates, as booksmart can help in some areas where field experience falls short. You may need their help later.
I like the fact that you posted your thoughts first instead of taking immediate actions. That is a lesson in of itself....
Good Luck...
bobdoering
Stop X-bar/R Madness!!
I am I silly for requiring the Total Runout be checked 100% on a new build prototype of a welded assembly? The assembly has many variables that controls cannot be determined in a single build cycle. Due to the complexity of the welded assembly and the fact that the runout tolerance is critical I feel it should be checked on each part. There are only 36 pcs. I am having a hard time conveying this point to one of our new engineers who thinks that if we build one part that "in theory" the next one will be exactly the same. (booksmart with very little practical experience).
Wow. 1 pc. capability study. Thank you engineering schools. I feel a Charlie Sheen quote coming on here.
I feel if we can ensure that in the first build we are meeting the runout requirement that then we can establish process controls and decide on a sampling size for future builds. This assembly involves welding a rectangular part that consists of 2 separate parts with 2 welded inserts that hold a machined shaft. The shaft mounts to a bearing and the whole assembly will spin. The total runout tolerance is only .030" which isn't much granted the variables that could occur in the manufacturing process. Just would like opinions on how I can convey this properly with tact. This person's opinion is that we should only have to check it one time and if it is good then the rest will also be good. (If it was that easy we wouldn't need process controls right?)
Even a 36 pc build is not sufficient to determine capability on that process - unless that is going to be the typical lot size. Not only that, runout is a unilateral tolerance with a hard limit (zero), so capability is tricky. It is non-normal, and usually falls into a Weibull or beta distribution. Bottom line: not intuitively obvious.
I guess the natural question I would ask - and any customer would ask, also - how do you know ever other part is going to be the same? Has the engineer developed a total variance equation to prove that point? Has the engineer considered process controls?
Q
qcchick
I managed to convince everyone involved that we needed to check total runout on all 36 pcs to establish capability. It was a difficult process but thanks to all for good ideas to help. It was much appreciated!
K
Ka Pilo
Try The Square Root of N Plus One Sampling Rule
optomist1 Automotive News The Cost of Inspecting In Quality IATF 16949 - Automotive Quality Systems Standard 7
O Inspecting paint and having workable standards in the supply chain Supplier Quality Assurance and other Supplier Issues 1
R Inspecting straightness tolerance of .00005" on a shaft Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
T Inspecting Full Thread Depth with a Plug Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S AS9102 FAI requirements - Inspecting with fixtures, templates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
P Inspecting a difficult part - Measuring the centre of a hole to the edge of a rod Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
F How to convert inches to degrees - Inspecting the perpendicularity of 2 lines Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Inspecting a Profile Tolerance for a Die Cut Gasket Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Is Rework "Inspecting Quality In"? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
K Inspecting a Length of Weld - High Reject Rates Manufacturing and Related Processes 7
K Probe on CNC machine - Inspecting on cnc machine tools vs. CMM Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
U Which Sampling Plan should I use? Inspecting & Dimensionally Measuring Products Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
C What to look for when inspecting incoming packaging goods such as empty retail boxes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Inspecting Outside Radii of a Small Steel Stamping Inspection, Prints (Drawings), Testing, Sampling and Related Topics 26
K Inspecting subcontracted manufacturing of garments, wearing apparel Manufacturing and Related Processes 5
ScottK Inspecting surface finish on SS on a piece that can't be measured with current equip. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Sampling - Measuring and Inspecting a part with both Variable & Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
D DNV Standards for inspecting offshore containers and baskets Various Other Specifications, Standards, and related Requirements 5
Y Inspecting Glued Components - Bubble size - Medical Device Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Y Inspecting Quality into Product - How to react? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
J Inspecting one at a time is quicker? Lean in Manufacturing and Service Industries 6
Claes Gefvenberg What if the inspector isn't inspecting? NASA inspector indicted Inspection, Prints (Drawings), Testing, Sampling and Related Topics 26
N Proper use of the Blueing process when inspecting the taper of bushings General Measurement Device and Calibration Topics 6
J Proper use of gauge pins - Inspecting thru holes of plastic parts General Measurement Device and Calibration Topics 19
B Total Productive Maintenance - Company Transport IATF 16949 - Automotive Quality Systems Standard 2
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
J Implementation of Total Quality Management/Starting a Quality Department Reliability Analysis - Predictions, Testing and Standards 9
K IATF16949 8.5.1.5 Total Productive Maintenance IATF 16949 - Automotive Quality Systems Standard 9
B IATF 16949 Section 8.5.1.5 (Total Productive Maintenance) IATF 16949 - Automotive Quality Systems Standard 19
P Total Variation in Data - Overall Importance of the Principal Components Reliability Analysis - Predictions, Testing and Standards 1
M Total number of Requirements for ISO 9001:2008 vs. ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J One third of the total audit days on manufacturing (TS 16949) General Auditing Discussions 2
M Total Productive Maintenance vs. Lean, Six sigma, Business Process Reengineering, etc Quality Tools, Improvement and Analysis 9
F What is the scope for "Total Numbers of Employees on site" per ISO/TS 16949 ? IATF 16949 - Automotive Quality Systems Standard 4
Marc Total Lunar Eclipse Visible in North America - 15 April 2014 Coffee Break and Water Cooler Discussions 4
K Can I use ANSI/AQL for the Total Number of Containers for the entire Lot? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
I Supplier Selection based on Total Cost question Supplier Quality Assurance and other Supplier Issues 4
B Total Resolution of an Measurement Instrument Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Pls hlep me understand the "Total Anaerobic Plate Count" Food Safety - ISO 22000, HACCP (21 CFR 120) 1
G How can Total Quality help a company or business compete in the world market? Preventive Action and Continuous Improvement 2
M How many documents total do you currently have? Document Control Systems, Procedures, Forms and Templates 6
5 Reasonable GRR result for a 0-1" micrometer with a total tolerance of .002" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
C A total newbie to AS 9101 needs general help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
B Total Productive Maintenance Templates to Drive TPM Forward Lean in Manufacturing and Service Industries 1
N Total Productive Maintenance (TPM) Portuguese Definitions and Terms Quality Tools, Improvement and Analysis 4
V Differences between Business Process Reengineering (BPR) and Total Quality Management Quality Manager and Management Related Issues 3
Z KPI Formula Issue - "Change Requests Managed" = Changed/Total ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
optomist1 Circular Runout vs. Total Runout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S Ppk & Cpk - Within Subgroup Variation is always smaller than Total Variation Capability, Accuracy and Stability - Processes, Machines, etc. 18
optomist1 Circular or Total Runout Gears and Splines? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
