Inspection and Work order process
Help,
So Where I work they have been using the prints to document their inspection results - forever. I had never seen since coming here. I want to create a simplified Inspection approach where CNC only measures what is necessary (affected by their process) and Weld only inspects what is affected by their process.
1) What approach has any here taken? Mind you all the operators are self taught - hired straight off the street with no prior experience; albeit 20 to 30 here only.
There is no true Work order/traveler process. we have the ability to create Line Item Work Orders to follow each process with a sign-off - yet this would be a major undertaking.
2) Start small go big? Any other approach to improve the ability to truly follow the process?
1) We want to establish "Inspection at the source". Most of the operators have never been required to document their Inspection results. I do not want to hand them a print of 50 dimensions - where only 10 of those 50 are dimensions their operation affects. What is the typical approach and or best practice when it comes to machined parts and welded parts inspection? They need to get in a habit of verifying their own work, but not be held up from producing as well.
2) We have over 8k items we produced and/or have produced over time. the operations is 1994 mentality when approaching documentation and traceability. (slightly improved since I started revamping the process 6 months ago). A Work Order/Traveler does not go out to the floor. The Production Manager gets the WO in his office and then prints out the prints and gives to the operator to produce said product. - I want to improve this process, mainly due to traceability issues. What Best practices are there that I could consider?
Mike S.
Happy to be Alive
Maybe....bubble the print, attach a simple numbered sheet and ask them to record the data for the 10 items they affect.
hogheavenfarm
We use a notebook for a traveler, with pages for each operation, welding, bending, stamping, etc. Each person doing the work records the dimensions of the first piece and every "x" piece they do directly on the print page of the traveler, but only for the operation they do. Then they pass to book to the next operation. Sometimes, two or more operations has to share the book, but its not really an issue since they are not using it constantly, only every "x" pieces, which can be differenty depending on teh department and how much variation can creep in between quantities of parts produced, for example, parts going through a CNC milling process may need less frequent inspection than a bending operation done manually on each piece.
I like the log concept - however, how do you deal with traceability and data analysis for trends and improvement?
toniriazor
Define what are the most critical characteristics to inspect based on product drawing and create an inspection sheet for them. You define how many/ when/ who/ how to inspect/ with what and etc. Use as an input lessons learned, PFMEA, recent failures and etc. What about customer requirements, what your customers or company procedures require to inspect at minimum ? Use the output of your Control Plan as Input for creating inspection standards and sheets and work instructions.
I worked at a CNC place and utilized Discus to balloon prints, then you assign the balloons to specific inspection reports for an operation. Discus helps to streamline the process of breaking down the entire print and separating out the applicative checks by operations. I understand your issue, where I work now, prints are not released to production. We break down each step on work instructions. But this does add time to clerical, and you will need support in revising and controlling the work instructions.
L Client's Order Dock Inspection before Shipping Manufacturing and Related Processes 5
P Source Inspection vs. Right of Access clause in a Purchase Order - Differences AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 6
K Visual Inspection Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
B 4DINSPEC Inspection Equipment General Measurement Device and Calibration Topics 0
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Industrial RX inspection of welds (Oil&Gas industry) Reliability Analysis - Predictions, Testing and Standards 0
C In-process inspection - Tooling and assembly lines for automotive companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D FAA inspection at my repair station - Rating Check Federal Aviation Administration (FAA) Standards and Requirements 0
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
Y What are different Special Inspection Level 1-4 and General spesification 1-3 ? AQL - Acceptable Quality Level 0
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
B GM GP-12 Exit Criteria - Additional Safe Launch Inspection - (Also see GM1927-28 ) Customer and Company Specific Requirements 2
S Process Inspection -Sub assembly process inspection sheet Lean in Manufacturing and Service Industries 3
C OEE and In-process Inspection Manufacturing and Related Processes 2
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
I Mother bobbin final inspection criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
G Inspection Logs - Asked to remove an Inspection Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Skooma Receiving Inspection - Boss trying to save money AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
T Nonconforming product at customer detected by a routine inspection by field service Nonconformance and Corrective Action 9
A Definition of customer in ITP (Inspection & Test Plan) Contract Review Process 3
A DCMA inspection for a drop-shipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S QUALITY OBJECTIVEs for third party garments factory inspection ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Lean and Elimination of QC Inspection Points in a New factory Lean in Manufacturing and Service Industries 9
F FDA-registration and inspection cost 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
I Receiving Inspection Requirement in IATF IATF 16949 - Automotive Quality Systems Standard 3
R Supplier related drawings and verification of process requirements - Source Inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Good Acceptance Activity/Inspection flowchart for reference - Wanted Please Process Maps, Process Mapping and Turtle Diagrams 2
K Inspection Certificate EN 10204 2.1 - Distribution company Other ISO and International Standards and European Regulations 4
S Improving Quality inspection gate in one piece flow manufacturing process Manufacturing and Related Processes 0
M Loss of a Quality Record - FDA Inspection Records and Data - Quality, Legal and Other Evidence 4
S Need Assistance in Visual Inspection - Tiny electronic components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S Is an Annual Layout Inspection the same as an Annual Re-validation? Internal Auditing 1
D Incoming (Receiving) Inspection - General form for incoming part inspection Document Control Systems, Procedures, Forms and Templates 17
K First Article Inspection (FAI) - Equipment used - Dimensions vs. Go/No-Go ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Informational USFDA Draft Guidance – Review and Update of Device Establishment Inspection Processes and Standards Medical Device and FDA Regulations and Standards News 0
S Inspection/sampling economics Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Is a First Article Inspection (FAI) Procedure required by ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
T EN 10204 3.1 Inspection Certificate - Machine Shop Various Other Specifications, Standards, and related Requirements 4
A Doubt on multiple inspection carrying out for same balloon number during Stage Inspection and Final Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
