Inspection Certificate EN 10204 2.1 - Distribution company
K
Katio
Hi All,
I am looking for help with regards to following:
1. Can the distribution company issue their own COCs with specific reference to EN 10204 2.1 (no manufacturing nor product testing taking place at the distributor site) or 2.1 cert can only be issued by the manufacturer?
2. Can the distributor issue their own 2.1 certification based on the material certs/COAs/COCs supplied by the manufacturer with the goods? If so, should it be clearly stated on distributor's COC that the certification is based on the manufacturer's cert?
3. Is it a common practice/is it acceptable that COC statement is on Delivery Docket, or should it be a separate document?
EN 10204, point 3.1 of the standard says that Type 2.1 declaration of compliance with the order is a "document in which the manufacturer declares that the products are in compliance with the requirements of the order, without inclusion of the test results". Also, in definitions section standard clearly distinguish the manufacturer and the intermediary (so distributor as well), and further in point 6 says that "An intermediary shall only pass on (...) of the inspection documents provided by the manufacturer (...). Based on this, I doubt that the distributor can provide their own 2.1 inspection docs., but want to confirm.
I appreciate any advises and thank you in advance.
Sidney Vianna
Post Responsibly
Counterfeit materials and certificates is a huge issue. No, the distributor can not issue the 2.1 certificates. They have to come from the mill/manufacturer.
In case a customer wants an independent certificate of conformity, a trustworthy third party inspector can issue a 3.2 certificate, after they witness a controlled sample be tested to demonstrate conformance with chemical, mechanical and metallurgical properties.
K
Katio
Even in case when the distributor is supplied with up to 3.1 certs from the manufacturer?
Sidney Vianna
Post Responsibly
You need to explain what you are looking for. If the distributor has access to the mill test certificates, who is asking for another certificate? What value would the distributor certificate add to the mill certificate?
The user of the material needs confidence that the material satisfies a set of requirements. If you have the original, traceable certificate of the material all the way to the mill, why would a distributor need to issue a meaningless certificate?
K
Katio
I agree with you Sidney, it doesn't make sense to me either. Just asking hypothetically: is it "legal" to issue 2.1 cert by distributor based on the 2.1 or 3.1 manufacturer cert?
T EN 10204 3.1 Inspection Certificate - Machine Shop Various Other Specifications, Standards, and related Requirements 4
B Inspection Certificate for EN10204 3.1b Standard VDA Standards - Germany's Automotive Standards 1
L Certificate of Conformity? Supplier incoming material inspection CE Marking (Conformité Européene) / CB Scheme 3
S Calibrated vs. Inspected - Calipers with a Certificate of Inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
K Visual Inspection Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
B 4DINSPEC Inspection Equipment General Measurement Device and Calibration Topics 0
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Industrial RX inspection of welds (Oil&Gas industry) Reliability Analysis - Predictions, Testing and Standards 0
C In-process inspection - Tooling and assembly lines for automotive companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D FAA inspection at my repair station - Rating Check Federal Aviation Administration (FAA) Standards and Requirements 0
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
R Inspection and Work order process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
Y What are different Special Inspection Level 1-4 and General spesification 1-3 ? AQL - Acceptable Quality Level 0
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
B GM GP-12 Exit Criteria - Additional Safe Launch Inspection - (Also see GM1927-28 ) Customer and Company Specific Requirements 2
S Process Inspection -Sub assembly process inspection sheet Lean in Manufacturing and Service Industries 3
C OEE and In-process Inspection Manufacturing and Related Processes 2
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
I Mother bobbin final inspection criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
G Inspection Logs - Asked to remove an Inspection Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Skooma Receiving Inspection - Boss trying to save money AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
T Nonconforming product at customer detected by a routine inspection by field service Nonconformance and Corrective Action 9
A Definition of customer in ITP (Inspection & Test Plan) Contract Review Process 3
A DCMA inspection for a drop-shipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S QUALITY OBJECTIVEs for third party garments factory inspection ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Lean and Elimination of QC Inspection Points in a New factory Lean in Manufacturing and Service Industries 9
F FDA-registration and inspection cost 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
I Receiving Inspection Requirement in IATF IATF 16949 - Automotive Quality Systems Standard 3
R Supplier related drawings and verification of process requirements - Source Inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Good Acceptance Activity/Inspection flowchart for reference - Wanted Please Process Maps, Process Mapping and Turtle Diagrams 2
S Improving Quality inspection gate in one piece flow manufacturing process Manufacturing and Related Processes 0
M Loss of a Quality Record - FDA Inspection Records and Data - Quality, Legal and Other Evidence 4
S Need Assistance in Visual Inspection - Tiny electronic components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S Is an Annual Layout Inspection the same as an Annual Re-validation? Internal Auditing 1
D Incoming (Receiving) Inspection - General form for incoming part inspection Document Control Systems, Procedures, Forms and Templates 17
K First Article Inspection (FAI) - Equipment used - Dimensions vs. Go/No-Go ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Informational USFDA Draft Guidance – Review and Update of Device Establishment Inspection Processes and Standards Medical Device and FDA Regulations and Standards News 0
