Inspection Checksheets (Records) Requirements
L
Lougee
Does all checksheets on a manufacturing company needs a document control stamp? That was the advised of our internal audit trainor. Is there any other way suggestion for efficient control of it? Since most of the time we revised our checksheet.
hogheavenfarm
It should be a controlled document with a revision and date however, especially since you say you "revise them all the time", in that case, how do you know the latest revision to use and be sure everyone uses it instead of some old (outdated) sheets?
howste
Thaumaturge
I'm assuming that you were being trained to audit to ISO 9001 since that's what you posted in your other questions. Document control stamps are not required in ISO 9001, AS9100, ISO 14001, IATF 16949, etc. The trainer's advice is very dated. In this age where most documents and many records are controlled electronically, forcing people to use stamps would be a huge mistake in my opinion.
L
Lougee
Yes, and this is my first time to encounter checksheet with stamp. The idea for controlled evidence is solid but on my previous work,checksheets were usually electronically used by the operators. But on my current work now, management wanted to have all document on hard copy form since using electronical way is much expensive according to them:confused:
howste
Thaumaturge
Now I'm confused. It sounds like you are talking about inspection stamps or production operator stamps now, not document control stamps. Stamps to show completion of operations on a traveler document or acceptance of inspections are common in some industries. If you need the traceability back to the person performing the work this can be a good method. ISO 9001 doesn't require traceability to personnel in this case, except for those who are releasing product (see clause 8.6b). For others you can choose to record their identity if you want in any way you want. Other than stamps, I've also frequently seen companies use handwritten employee numbers or employee initials (make sure they're legible) on these type of documents.
L
Lougee
I was referring to the document center stamp (controlled copy for checksheet)
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
K Visual Inspection Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
B 4DINSPEC Inspection Equipment General Measurement Device and Calibration Topics 0
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Industrial RX inspection of welds (Oil&Gas industry) Reliability Analysis - Predictions, Testing and Standards 0
C In-process inspection - Tooling and assembly lines for automotive companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D FAA inspection at my repair station - Rating Check Federal Aviation Administration (FAA) Standards and Requirements 0
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
R Inspection and Work order process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
Y What are different Special Inspection Level 1-4 and General spesification 1-3 ? AQL - Acceptable Quality Level 0
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
B GM GP-12 Exit Criteria - Additional Safe Launch Inspection - (Also see GM1927-28 ) Customer and Company Specific Requirements 2
S Process Inspection -Sub assembly process inspection sheet Lean in Manufacturing and Service Industries 3
C OEE and In-process Inspection Manufacturing and Related Processes 2
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
I Mother bobbin final inspection criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
G Inspection Logs - Asked to remove an Inspection Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Skooma Receiving Inspection - Boss trying to save money AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
T Nonconforming product at customer detected by a routine inspection by field service Nonconformance and Corrective Action 9
A Definition of customer in ITP (Inspection & Test Plan) Contract Review Process 3
A DCMA inspection for a drop-shipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S QUALITY OBJECTIVEs for third party garments factory inspection ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Lean and Elimination of QC Inspection Points in a New factory Lean in Manufacturing and Service Industries 9
F FDA-registration and inspection cost 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
I Receiving Inspection Requirement in IATF IATF 16949 - Automotive Quality Systems Standard 3
R Supplier related drawings and verification of process requirements - Source Inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Good Acceptance Activity/Inspection flowchart for reference - Wanted Please Process Maps, Process Mapping and Turtle Diagrams 2
K Inspection Certificate EN 10204 2.1 - Distribution company Other ISO and International Standards and European Regulations 4
S Improving Quality inspection gate in one piece flow manufacturing process Manufacturing and Related Processes 0
M Loss of a Quality Record - FDA Inspection Records and Data - Quality, Legal and Other Evidence 4
S Need Assistance in Visual Inspection - Tiny electronic components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S Is an Annual Layout Inspection the same as an Annual Re-validation? Internal Auditing 1
D Incoming (Receiving) Inspection - General form for incoming part inspection Document Control Systems, Procedures, Forms and Templates 17
K First Article Inspection (FAI) - Equipment used - Dimensions vs. Go/No-Go ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Informational USFDA Draft Guidance – Review and Update of Device Establishment Inspection Processes and Standards Medical Device and FDA Regulations and Standards News 0
S Inspection/sampling economics Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Is a First Article Inspection (FAI) Procedure required by ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
T EN 10204 3.1 Inspection Certificate - Machine Shop Various Other Specifications, Standards, and related Requirements 4
