Inspection Dimensional Check Sheets - Over 500 part numbers
K
kmyers
I have created a generic forum for operators to fill out as the are doing thier dimensional checks. On this form the operator fills in all the pertinent info(part#, dim., tol. etc.). We want to go to a preprinted document that is of the same template that will have all the pertinent info already on it. This will print when a job packet for that specific part # is created.
Now the question. We have over 500 part numbers, and what I need to know is, do we have to do anything in regard to document numbering since these will be prepreinted with all info on them but will still have the controlled # for the generic inspection sheet on them. It may sound a little confusing so if you need more clarification please let me know.
Thanks,
Kris
F
Frank T.
Re: Inspection Sheets
Kris,
The only control you have to have is on the blank (generic) inspection sheet. The information (part #, dim., tol., etc.) added does not change the original, so numbering each inspection sheet is not necessary.
The only downside to doing this, is if you revise the blank (generic) inspection sheet, then every sheet needs to be revised. Unless you start with the generic being a template (i.e. Word 2007 Template <.dot>) then when the template is revised all the sheets that were created with it are automatically updated.
Hope this is of some help...
Wes Bucey
Prophet of Profit
FWIW:
In our high tech contract machining business (all custom work for other manufacturers), each part had a Control Plan.
In addition to all the other stuff in a Control Plan (agreed to in advance by each customer), we included an Inspection Process specific to the individual part. At first we did hand measurement and recording - later, automated measuring and direct input of readings to a computer.
Among other things, the Inspection Process included:
  1. an engineering drawing of the part with each dimension to be inspected tagged with a number (in the order in which the dimension was to be inspected.)
  2. A part-specific inspection check list with each dimension numbered in the order it was to be inspected, listing the target dimension with tolerance (column 1), together with the type of instrument (column 2), and the actual dimension measured (column 3), and a 4th column for a redundant check of the same sample by another inspector.
  3. The measured sample was tagged and traveled with the rest of the documentation in the order traveler (the document package which traveled with each step in processing to final shipment.)
We specifically designed each part-specific inspection process for the most efficient use of instruments and operator time. The numbering directed a consistent measuring process on each sample, designed to identify most likely N/C (from the FMEA) first, before wasting time on subsequent measures. Often different parts of the same part had the same dimension, but had been produced in a separate operation and thus had to be measured separately and DISTINCTLY (to identify which process went with which dimension as an aid in problem solving in the event of an N/C.)
Different inspection sheets were created for in-process SPC charting and for both First Article and Final Inspection. Above all, we wanted to eliminate opportunities for error and to make the inspection processes as efficient and capable of being replicated as possible - either by our own in-house folks doing redundant inspections or by customers doing receiving inspection.
The identity of the type of instrument used on each dimension was important. We had a chart to identify each instrument used in an inspection of a sample by serial number, thus the instrument itself could be recalled if there was a suspicion a faulty instrument out of calibration was the cause of any N/C reading.
Anybody and everybody in our organization was empowered to halt manufacture if a N/C were suspected, calling in as much help as necessary to affirm or deny the suspicion before the manufacture was restarted.
Elsewhere in the Cove, over the years, I have described how our operation evolved from traditional manufacture and inspection departments to the point where manufacturing folk performed the routine inspections and quality department folk acted as designers of each part's inspection process in collaboration with each customer, then would act as trainers for the manufacturing folk to perform those inspections, and act as arbiters if a redundant inspection was required.
Everything was slanted to make every part of the manufacturing process flow as smoothly and efficiently as possible, removing bottlenecks and choke points along the way, making liberal use of mistake proofing concepts on every aspect of our operation.
If it's important, we could probably find links to those posts.
N Dimensional Inspection - Symbology cheat sheet Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Slotted Hole Dimensional Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
P Dimensional Mechanical Inspection only as a Service - ISO17025 or ISO17020 ISO 17025 related Discussions 5
H Dimensional Measurement Uncertainity - Inspection of a component Measurement Uncertainty (MU) 5
H Dimensional Inspection Procedure - Sample wanted Document Control Systems, Procedures, Forms and Templates 2
L Acceptance Activities-Dimensional Inspection was missed. Parts already assembled 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
K Dimensional Inspection of Molded Plastic Parts in Seoul, Korea Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
I Contract Visual, Basic Dimensional Inspection Services Service Industry Specific Topics 2
A X-Ray for Dimensional Inspection and Scanning for Defects within Polyurethane Foam Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Q Measurement Uncertainty (MU) in Dimensional Inspection in a QC Laboratory Measurement Uncertainty (MU) 2
S Dimensional Inspection Technique for a small Silicone Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
S Layout and Dimensional Inspection Training Training - Internal, External, Online and Distance Learning 0
T General convention used for dimensional inspection - 4x Accuracy? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Just accredited!!! CMM Dimensional Inspection Laboratory General Measurement Device and Calibration Topics 8
E Looking for Dimensional Inspection Service Service Industry Specific Topics 15
N Dimensional Inspection Business Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M Detection rank for sampling vs 100% inspection & 15x vs 400x magnification FMEA and Control Plans 4
S In process inspection Manufacturing and Related Processes 2
S Brexit 100% inspection during in process inspection Manufacturing and Related Processes 11
briteme4 AS9102 First Article Inspection - do I need a second reviewer and signer? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Max and Min form diameter inspection IATF 16949 - Automotive Quality Systems Standard 4
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
K Visual Inspection Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
B 4DINSPEC Inspection Equipment General Measurement Device and Calibration Topics 0
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Industrial RX inspection of welds (Oil&Gas industry) Reliability Analysis - Predictions, Testing and Standards 0
C In-process inspection - Tooling and assembly lines for automotive companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D FAA inspection at my repair station - Rating Check Federal Aviation Administration (FAA) Standards and Requirements 0
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
R Inspection and Work order process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
Y What are different Special Inspection Level 1-4 and General spesification 1-3 ? AQL - Acceptable Quality Level 0
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
B GM GP-12 Exit Criteria - Additional Safe Launch Inspection - (Also see GM1927-28 ) Customer and Company Specific Requirements 2
S Process Inspection -Sub assembly process inspection sheet Lean in Manufacturing and Service Industries 3
C OEE and In-process Inspection Manufacturing and Related Processes 2
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
I Mother bobbin final inspection criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
G Inspection Logs - Asked to remove an Inspection Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Skooma Receiving Inspection - Boss trying to save money AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
T Nonconforming product at customer detected by a routine inspection by field service Nonconformance and Corrective Action 9
