Inspection Equipment for Checking Serrated Steel Tubing Depths
jonerenberg
My company uses steel tubing in its product that has serrations or grooves in it. Some tubing has it on the outside diameter and some has it on the inside diameter. Currently two methods are used to check the depth are using a depth gauge and a micro-vue. Both of these methods have limits to the accuracy of their measurements. I am intrested to know if any one has any other ideas for quipment that coud be used to check the depth. Attached is a representative drawing of the serrated tubing.
Stijloor
Can someone help?
Thank you!
Stijloor.
Wes Bucey
I'm curious to know the ultimate function of the serrations that measurement by micro-vue doesn't seem to offer enough accuracy for a relatively loose tolerance of +/- .003. Do internal and external grooves mate in some applications?
What are you experiencing in terms of conformance/nonconformance during inspection?
I presume you buy this from a supplier - how does he measure in-house?
B 4DINSPEC Inspection Equipment General Measurement Device and Calibration Topics 0
K First Article Inspection (FAI) - Equipment used - Dimensions vs. Go/No-Go ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B 7.1.5.1.1 MSA for inline dimension vision inspection equipment IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 Clause 7.1.5.1.1 - What are "inspection equipment systems"? IATF 16949 - Automotive Quality Systems Standard 4
A Quality Plan - Inspection method, equipment list for inspection of a Spur Gear Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L Inspection Equipment Accuracy - Measuring the diameters of small holes Measurement Uncertainty (MU) 5
V Handling decomissioned line/equipment during 1st time product-based inspection US Food and Drug Administration (FDA) 1
C Gage R&R on In-Process Automated Inspection Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
S How to do Adjustments & Repairs on Common Inspection Equipment General Measurement Device and Calibration Topics 7
F Aged Inspection Equipment Software has no Audit Trail - Validation of Software Qualification and Validation (including 21 CFR Part 11) 5
J Calibrate before use required? Inspection Gages and Measurement Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
AnaMariaVR2 Laboratory Equipment Quality System - Calibration, Maintenance and Inspection Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 10
T CP: Is it feasible to define the inspection equipment as final function tester? APQP and PPAP 12
B Attribute MSA of Automatic Inspection Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M Accuracy of Inspection Equipment - How precise does the measurment device need to be? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M Calibration Procedures for Inspection Equipment? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
D CSA Inspection - Process equipment shipped elsewhere to process product Various Other Specifications, Standards, and related Requirements 9
R Construction: Does new Inspection and Measurement Equipment require calibration? General Measurement Device and Calibration Topics 22
D Manufacturer' Service Provider - Calibration of inspection test equipment General Measurement Device and Calibration Topics 6
A Final Inspection - Calibrated M&TE (Measurement and Test Equipment)? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Employee Owned Inspection Equipment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
A Calibration of inspection, measuring and test equipment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
A Method of Disposition on Damaged Inspection,Measuring Test Equipment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M 4.11 Control of Inspection Measurement and Test Equipment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
K Visual Inspection Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Industrial RX inspection of welds (Oil&Gas industry) Reliability Analysis - Predictions, Testing and Standards 0
C In-process inspection - Tooling and assembly lines for automotive companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D FAA inspection at my repair station - Rating Check Federal Aviation Administration (FAA) Standards and Requirements 0
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
R Inspection and Work order process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
Y What are different Special Inspection Level 1-4 and General spesification 1-3 ? AQL - Acceptable Quality Level 0
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
B GM GP-12 Exit Criteria - Additional Safe Launch Inspection - (Also see GM1927-28 ) Customer and Company Specific Requirements 2
S Process Inspection -Sub assembly process inspection sheet Lean in Manufacturing and Service Industries 3
C OEE and In-process Inspection Manufacturing and Related Processes 2
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
I Mother bobbin final inspection criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
G Inspection Logs - Asked to remove an Inspection Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Skooma Receiving Inspection - Boss trying to save money AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
